question regarding bionic jb root
5 replies to this topic
#1 Nola
Nola
  • 85 posts
Posted 06 February 2014 - 07:15 AM
i sent this in a message to samurai too, but maybe somebody else can answer it so as not to bug him :)
"last year when dan finally obtained root for the jb builds it was great. although i believe i followed your
 and NEVER LOST root when installing (not ota updating) the new update.
so since i never lost root i never had to go through and use the new method. fast forward to today, fxz'd to a fresh start, and now i want to root of course. everything i'm reading however says only use a 32 bit linux, live disc,
whatever. so here's the question:
if i have a 64 bit windows - CAN i run a 32 bit linux? by way of either live disc or virtualbox? will it run? just getting all my ducks in a row before i attempt this.
thanks in advance for any insight you may have!
EDIT: well some simple googling revealed that i can do this.  i guess i'll leave this open if anyone wants to chime in or confirm that :)
#2 livinginkaos
Posted 06 February 2014 - 07:30 AM
There is another one step option that will be revealed as soon as the last omap update drops.
Sent From My DEV X
  • B.E.McAllister and johnthehillbilly like this
#3 Nola
Nola
  • 85 posts
Posted 06 February 2014 - 07:32 AM
Sent From My DEV X
thanks for the reply but samurai just sent me a different method :)  i will try and report back (it's the first time i've seen this used on the bionic)!
#4 livinginkaos
Posted 06 February 2014 - 08:25 AM
That's the one I was talking about.  Needs to stay under wraps for now.
  • johnthehillbilly likes this
#5 Nola
Nola
  • 85 posts
Posted 06 February 2014 - 08:44 AM
heard that.  you can delete this thread if needed.  root checker was being a brat, but titanium backup among others worked just fine.  thanks for all help!
#6 chrisp6825
chrisp6825
    Byaaah!
  • 78 posts
  • Current Device(s):Moto Droid Bionic
Posted 09 February 2014 - 01:58 AM
You are correct sir, it is possible.
