How do I find or what is the name of the folder that holds the advertising info on my phone, looking to delete it.
Also looking to set my os to not allow applications to make new folders
Posted 04 February 2014 - 01:32 PM
Posted 04 February 2014 - 02:18 PM
Not sure what advertising info you are referring to??? As for the other thing, you can look through the apps
. Doing what you are asking on a permanent basis could be cumbersome every time you want to add an email folder, contact group, picture folders, etc.
