Ok found the script generator and I read the instructions; I think it worked; the last message said scripts generated. So, I just run house of MOTO again? Going to try it now.
Help! My Motorola Razr XT907 is Soft Bricked!
#21
Posted 24 January 2014 - 01:22 PM
#22
Posted 24 January 2014 - 01:24 PM
Its failing and I'm getting a low battery warning. gonna try to charge it up and then try again..
#23
Posted 24 January 2014 - 01:35 PM
Thanks a lot for your help; I feel like I'm closer to solving this problem.....
#24
Posted 24 January 2014 - 03:17 PM
Ok and ALRIGHTY THEN! The mighty droid razr is back up and running 'THOU ART THE MAN'......; THANK YOU FOR YOUR ASSISTANCE YOU'RE THE BEST......... House of MOTO ROCKS, and your script generator is what everything computer related "should" aspire..... It does what you say it does and it's got a gui that even a moron like me can figure out... It's simple to use; and it works.... THANKS AGAIN!! Now I can get some sleep.....
#25
Posted 27 April 2014 - 12:08 PM
Following these instructions helped fix my phone when other tutorials I found (using RSD Lite, etc) seemed ineffective. I just wanted to give props to those who developed this tool. Thanks.
- SamuriHL, livinginkaos and RikRong like this
