[ROM][4.4.225][Kit-Kat][XT1060] Beanstalk 4.4.225
kit kat kit-kat 4.4 beanstalk moto x xt1060
32 replies to this topic
#1 pjgraber03
pjgraber03
  • 482 posts
  • Google+:pjgraber03
  • Current Device(s):LG G2 (vs980),Razr M (xt907), Galaxy S2(d710),Galaxy Tab 3 8.0 (sm-t310), Galaxy tab 2 (p3113)
Posted 21 January 2014 - 11:19 PM
post-103018-0-11429500-1388984908_thumb.
Requirements to flash:
An xt1060 (you never can tell)
You must be rooted!
You must have an unlocked bootloader
and you must have a custom recovery (I personally like TWRP)
Known bugs!
None that is know....that said I am human and may have missed something.  If you find something isn't working please let me know.
Features:
The features are quite extensive.  There is:
init.d support
init.d script tweaks
custom nav bar
custom status bar
active display
Halo
Build.prop mods
To see a full list of features go HERE <--
For Audio Mods Install Viper4android
To Install:
Wipe data, system, dalvik, cache 3x
flash rom
flash gapps
reboot
Gapps packages:
Pa Gapps
Special Thanks:
Beanstalk
Timpohladthomas
Tucstwo
DrDevs
Download Beanstalk HERE<--
Any questions or comments: pm me or contact me on hangouts pjgraber03@gmail.com
SEE MY OTHER POSTS FOR OTHER SUPPORTED DEVICES!!!!
Other support devices
Built by:
post-103018-0-84381400-1390374789_thumb.
  • canezila, satman80, matjmonk and 1 other like this
Donate To Show Your Support for Graber Roms
Currently supporting 17+ devices if you would like your device added PLEASE let me know.....pjgraber@gmail.com
#2 disturbed58
disturbed58
  • 55 posts
  • LocationLancaster, PA
Posted 22 January 2014 - 07:10 AM
This is posted in the "retail edition" section, should it be in the developer edition?  I didn't think the retail could have its bootloader unlocked.  Don't want people trying this with a locked bootloader recovery (safestrap).
#3 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 22 January 2014 - 07:32 AM
Agreed. Moved to Developer Edition section. Thanks for the head's up.
#4 pjgraber03
pjgraber03
  • 482 posts
Posted 23 January 2014 - 12:06 AM
O sorry Ya I just put it in the wrong section
Sent from my VS980 4G using Xparent BlueTapatalk 2
  • Memnoch73 likes this
#5 Memnoch73
  • 5,016 posts
Posted 23 January 2014 - 05:13 AM
No worries man... Glad to see some life in the X area. Great job throwing up a bunch of new roms...
#6 matjmonk
matjmonk
    Pack Leader to Bubba
  • 3,662 posts
  • Google+:matjmonk@gmail.com
  • Current Device(s):Nexus 6, Nexus 7 (2013)
Posted 27 January 2014 - 01:35 PM
I've been running this version for about a week now and it's been very, very good, thanks for all of you work on it! I've only notice two minor things, the screen will sometime either not come on at all or comes on very dimly. Usually this seems to happen when i'm listening to my Audible book and I found that if I relock the screen and try again once or twice, it will correct itself. The other small thing is that the BeanStalk OTA application will keep telling me there is a new version available but it's the 4.3 file from October. Neither is a big deal and the battery life on this is very good compared to stock (<3%/hour) and the Active Notifications seem to work very well also compared to Moto's!!!!
Thanks again for the great work!
  • pjgraber03 likes this
#7 pjgraber03
pjgraber03
  • 482 posts
Posted 27 January 2014 - 11:46 PM
Thanks for your input....the problems u have mentioned should be fixed by an update.....I hadn't had any feedback on this Rom yet now that I have I will get an update out tomorrow 4 u...thanks again
  • matjmonk likes this
#8 matjmonk
matjmonk
  • 3,662 posts
Posted 28 January 2014 - 05:56 AM
Well, not to be a complainer but I did find one other problem, apparently I'm not getting GPS data when running Beanstalk. I tried all the usual fixes such as wiping dalvick and cache and used the GPS Status utility from the playstore but couldn't get it to work. I think I remember reading that some of the other CM builds had this issue but don't remember what they did to correct it.
#9 BladeRunner
BladeRunner
    Chatroom Tech Support
  • 347 posts
  • LocationMaine
Posted 29 January 2014 - 03:10 AM
I think the fix was to make a back-up, flash back to stock and get a good gps fix then restore the back-up
#10 matjmonk
matjmonk
  • 3,662 posts
Posted 29 January 2014 - 04:38 AM
I'll give that a try, I assume that there are no wipes between the two restores?
#11 pjgraber03
pjgraber03
  • 482 posts
Posted 31 January 2014 - 12:08 AM
I'm building an update and the GPS should b fixed
Sent from my SM-T310 using Xparent BlueTapatalk 2
#12 pjgraber03
pjgraber03
  • 482 posts
Posted 31 January 2014 - 04:14 PM
UPDATE POSTED!!!!!
#13 pjgraber03
pjgraber03
  • 482 posts
Posted 10 February 2014 - 11:09 PM
UPDATE POSTED!!!!!!
  • canezila likes this
#14 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 February 2014 - 05:42 PM
UPDATE POSTED!!!!!!
So what's up with this ROM I herd people talk about it but not much going on here. Talk to me I'd like to try.
#15 pjgraber03
pjgraber03
  • 482 posts
Posted 16 February 2014 - 09:29 PM
It's completely stable.... Very customizable... Smooth and I update it quite often
#16 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 February 2014 - 09:36 PM
No sod's volume OK none of the other problems CM's are having? I'll give it a try tomorrow. Thanks for your response.
#17 pjgraber03
pjgraber03
  • 482 posts
Posted 16 February 2014 - 10:27 PM
No sods volume is good.... I run this ROM on my personal everyday device.... and no bugs... no random reboots.... No freezing.... if for some reason you happen to run into issues with Anything let me know... Thanks
#18 matjmonk
matjmonk
  • 3,662 posts
Posted 17 February 2014 - 09:03 AM
to echo PJ's comments, I've been running it as my DD for the last three weeks or so, it runs great, nice and smooth, good battery life and haven't seen a SOD yet. I don't know about the speakerphone issue some people are taking about in the CM, GUMMY forums at the "other" site since I mostly use the phone with my BT headset. All in all, great ROM, definitely give it a try.
#19 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 18 February 2014 - 05:08 AM
Finally got it down loaded so far so good. I'm a speed freak seems is there any to get a little more speed lol. Can you suggest a kernel. I hate chrome so I can installed aosp browser much better. I noticed there is no MMS I guess hangouts? Or 3rd party. Thanks for your work I'm gonna ride the hell out of her today.
#20 pjgraber03
pjgraber03
  • 482 posts
Posted 18 February 2014 - 07:49 AM
Well the only thing i can say for my speed is make sure that u turn on the init.d scripts in settings..as far as the kernel the one that is built with the rom is optimized for this rom
Sent from my LG-VS980 using Xparent BlueTapatalk 2
Also tagged with one or more of these keywords: kit kat, kit-kat, 4.4, beanstalk, moto x, xt1060
