The Guide For Battery Life/ Performance
services.jar frozen apps CPU battery build.prop scripts battery draining apps ROMs mods
36 replies to this topic
#21 JJT211
JJT211
  • 246 posts
  • LocationNew Orleans, LA
Posted 26 August 2012 - 12:22 PM
Wifi: It's proven that having the "Wifi on while sleep" setting on improves battery life.
Do this by going into settings and under "Wifi" hit the menu button and go to "Advanced" and make sure "Keep Wifi on during sleep" says "Always". If you're using JuiceDefender then set this to "Never". It saves more battery.
I dont understand how this saves battery. Especially, if your phone is in your pocket while on the road or something.
Even if you are around Wifi....Still doesnt make sense.....I mean unless it just has something weird to do with the Android OS....
How?
#22 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 26 August 2012 - 12:27 PM
How?
Having that box checked means, that while you are connected to a wifi network and the screen gets turned off instead of going to data the phone will stay on wifi. Saving battery.
#23 JJT211
JJT211
  • 246 posts
Posted 26 August 2012 - 03:25 PM
Oh so its only while you are connected to Wifi....better to leave it on wifi rather than data....
One more Q:
Guide mentions using the Hotplug govenor (shuts off one core) as well as CPU sleep app....
I can see using both might cause problems as diff components are trying to simultaneously accomplish the same task. Wouldnt that possibly pose a problem. Or do you have both working for you? If not, and it does prose a problem, which one do you think would give you more battery savings? Govenor or the CPU sleep app? Or is the CPU sleep app basically a govenor?
LOL...sorry, im working this out in my head as I type. I just think using both CPU sleep and a govenor might pose problems people might not realize. Just wondering....Thanks!
#24 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 26 August 2012 - 05:02 PM
One more Q:
I honestly don't know, I only used that set up for a short time(Pegasusq FTW!) as I found Pegasusq, and I haven't updated the post yet. I don't think it would cause problems, but I COULD see it happening.
#25 twith70
twith70
  • 180 posts
Posted 28 August 2012 - 03:49 PM
I read through the OP and various assorted tweaks that were mentioned. I looked through the build prop on the ROM I am on and can't find half of the setting you mention. Do those tweaks have to entered in manually? If so, how would one go about doing it?
#26 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 28 August 2012 - 03:58 PM
I've noticed that Simplex and Eclipse don't have a whole lot of build.prop tweaks, but still manage to be pretty smooth, because of Nitro and EmericanX magic. Yes, if it's not there than you have to enter it maunually.
#27 smeekteek
smeekteek
  • 224 posts
Posted 30 August 2012 - 01:33 PM
Why not just have Smartactions shut off data whenever wifi is on? Then you can uncheck wifi staying on during sleep.
#28 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 30 August 2012 - 02:19 PM
I guess that could be a good substitute. In theory it would work the same way.
#29 twith70
twith70
  • 180 posts
Posted 30 August 2012 - 06:39 PM
under the section of build prop tweaks..can you use the debug.composition.type for both the cpu and gpu? I tried that but ended up with only one line in the build.prop.
#30 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 30 August 2012 - 07:19 PM
The system will use whatever is on the bottom. Because it reads it last. So lets say I have
In that case it would use the GPU because the system reads it last. It is the last defined value for that string.
#31 twith70
twith70
  • 180 posts
Posted 31 August 2012 - 11:51 AM
So, in a battery life thread..which one would save you the most battery the cpu or gpu? I would imagine like a computer the gpu is more effecient at rendering graphics as that is its designed purpose and frees the CPU to perform calculations and run programs. Thanks for clarifying about the lines read and how..
#32 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 31 August 2012 - 02:49 PM
The GPU would save more battery. Using the cpu would make the cpu work really hard.
#33 Gytole
Gytole
    The Hicks Boson!
  • 248 posts
  • LocationOhiyah!
  • Current Device(s):HTC ONE M8, Galaxy Note 3, Nexus 7 FLO
Posted 30 October 2012 - 08:07 AM
I like this write up, I posted a link to it in my ez guide under battery life savings. "You scratch my back, I scratch yours. haha"
Gyt-bauss stock wrecker
#34 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 05 December 2012 - 10:01 PM
I'm going to renovate this write up with Do-it-yourself tweaks I found and some from me. Along with updating of info and links tomorrow. Added CM10 Vs AOKP but plan to elaborate more.
#35 Centurion
Centurion
  • 71 posts
  • LocationFlorida
Posted 25 September 2013 - 05:11 PM
I know this is an old thread. And it has some great info. But is there anything new to help save on battery life.
Sent from my Xoom using Tapatalk 4
#36 cmh714
Posted 26 September 2013 - 07:49 AM
Get Greenify from the play store.
  • johnthehillbilly and iamhugger like this
#37 bluto
bluto
  • Current Device(s):XT912
Posted 12 June 2014 - 09:43 AM
Thanks for the write up, it helps clear up a few questions I had.  I'm running Aviator and loving my brand new phone.  Amazed at the new life to which my xt912 has been resurrected.
Also tagged with one or more of these keywords: services.jar, frozen apps, CPU, battery, build.prop, scripts, battery draining apps, ROMs, mods
