Here's the new small OTA for 2014, any brave testers still left out there for the XT912?
Update info here:
Posted 10 January 2014 - 06:30 AM
Update info here:
Posted 10 January 2014 - 06:52 AM
Do you have a link to the previous update kicking around? I want to check something for you guys before you all go blasting this onto your phones.
Posted 10 January 2014 - 07:03 AM
Well, if you can torrent, here are links to all the updates
I looked around for a bit but couldn't find a direct download for the previous update.
Posted 10 January 2014 - 07:07 AM
I couldn't either. I'm just grabbing the full FXZ for it. Sit tight...it's a SLOW download now since the FXZ site died and had to be rebuilt. I really only need the cdt.bin file from the previous update...
Posted 10 January 2014 - 07:30 AM
And of course for some reason the FXZ doesn't contain the cdt.bin file?? How does that work? If you OTA it increases the security but you skip the OTA and just use the FXZ to update it doesn't? Nice one, Moto. LMAO! I'm still hunting for the cdt.bin from the previous update. I BELIEVE the security on this new update wasn't increased but I'm not sure yet.
Posted 10 January 2014 - 08:31 AM
If security is the same then we don't really have to update any "utilities" now do we?
Posted 10 January 2014 - 08:32 AM
Confirmed. The security is the same. That means you can downgrade to the previous release should this one prove to be a pain in your rear end.
1. Does that mean that root isn't affected by this update? My XT912 Razr Maxx is currently rooted, with a Voodoo RootKeeper backup. Will I be able to / need to restore the root after the update?
2. Besides the two fixes Motorola mentioned (related to signals and roaming), is there a way to figure out if there are there any other changes made by this update, and what they might be? as I posted in the other thread (
), the language in their announcement ("you will notice some bug fixes, including: [the two listed bug fixes]") hints that there may be other fixes/changes in this update (or, they just don't care about grammar the way my high-school English teacher - may she rest in peace - did)Posted 10 January 2014 - 08:37 AM
Look inside the .zip and see what's changed. No apps are added and it doesn't seem to be changed much.
4.1.2/9.8.2O-72_VZW-16/58:user/release-keys
4.1.2/9.8.2O-72_VZW-16-5/5:user/release-keys
Posted 10 January 2014 - 08:44 AM
That was my thought. People can save root with Voodoo. If they screw something up, use your util or my House of Moto to put the previous version on, root/protect it, and run the upgrade again. Done.
Posted 10 January 2014 - 08:47 AM
I suspect some baseband changes given that the release notes seem to be connection related. I also highly expect that they patched the master key vulnerability while they were at it. That's just a guess though.
Posted 10 January 2014 - 09:42 AM
What's the "master key vulnerability"?
Posted 10 January 2014 - 09:48 AM
Posted 10 January 2014 - 02:43 PM
I can confirm that I had no issue installing and keeping root with RootKeeper.
Posted 10 January 2014 - 04:00 PM
Posted 10 January 2014 - 04:03 PM
Try the old root exploit.
Posted 10 January 2014 - 05:30 PM
I installed this update before reading this thread and I lost my root, now I have to wait for another root app to come out or my Razr Maxx is done!
Posted 10 January 2014 - 05:34 PM
yea... I've been trying Razr Blade multiple times and keep getting the following:
Posted 10 January 2014 - 05:38 PM
try RAZR Blade. If it fails, they did not up the security, so you should be able to downgrade, root with RAZR Blade, protect root, update, then restore root.I installed this update before reading this thread and I lost my root, now I have to wait for another root app to come out or my Razr Maxx is done!
Posted 10 January 2014 - 05:40 PM
Razr blade won't work as it needs fresh smart actions to do it's thing. You will need to downgrade.
