I HAVE A QUICK QUESTION, I HAVE A RAZR HD XT926 ANDD NOW ON VER 9.16.6, AV 4.1.2. WITH THE HELP OF SCRIPT (SamuriHL_Downgrade)I USED THE DOWNGRADE, INSTALL ROOT, AND PROECT ROOT. BUT WHEN I INSALL SAFE STRAP (RAZR-HD-Safestrap-3.12) I INSTALL A ROM . THE SCRIPT SAYS IT INSTALLED BUT DONT BOOT, NOT SURE WHY. ANY IDEAS?
THX
Posted 07 January 2014 - 02:07 PM
Posted 07 January 2014 - 04:06 PM
My ROM never Boo's either.
I believe you are using the wrong version. Hashs webpage shows the current version as 3.60 and in his folders while I do see a 3.12, there is also 3.60 and 3.63
I would try 3.60 or 63.
EDIT: hmmm, although the goo link only has 3.12 the crackflasher site has the 3 I mentioned above. very interesting.
Posted 07 January 2014 - 04:11 PM
To Hash's site if you werent aware:
Posted 07 January 2014 - 04:20 PM
Sent From My DEV X
Posted 07 January 2014 - 05:45 PM
Fixed the title
Sent From My DEV X
THX I TRIED BUT COULDNT FIGURE IT OUT. LOL
THX
ILL TRY IT THX
Posted 07 January 2014 - 06:32 PM
OK UPDATED TO 3.63 AND STILL TTHE SAMETHING SHOWS SUCSFULL INSTALL ...HMM
Posted 07 January 2014 - 06:50 PM
Sent From My DEV X
Posted 07 January 2014 - 07:59 PM
What ROM are you trying to install? There are only a few stock based roms that work for safe strap.
Sent From My DEV X
I TRYED A FEW LIKE AVAITOR BUT I GET NOTHING TO WORK ANYONE KNOW OF A ROM THAT WILL WORK?
Posted 08 January 2014 - 05:08 AM
Sent From My DEV X
Posted 08 January 2014 - 01:20 PM
Ragerom
Sent From My DEV X
THX I FIGURED IT OUT I DIDNT MOUNT IT,THE OLDER ONE I NEVER HAD TO ON MY RAZR MAXX.
SO INCASE THERES OHHERS WITH MY PROBLUM HERE IS SOME HELP
- Transfer to SD card.
- Reboot into Recovery.
- Wipe
- Mount /system
- Flash boot.img if coming from a different kernel.
- Flash “AviatorHD v1.0.4”.
- Reboot after installation.
- Setup phone.
- Go into Settings>CPU Sleeper. Check "Enable auto-start on reboot", then "Start Service" (Press twice).
- Let phone settle for 5-10 minutes then reboot for best results.
- Charge to 100% for battery calibration or use battery calibration app from Play Store.
- Enjoy!
- cmh714 likes this
Also tagged with one or more of these keywords: ROM, SAFESTRAP
