#141
Posted 03 February 2014 - 04:28 PM
#142
Posted 03 February 2014 - 07:49 PM
Sent from my SM-T310 using Xparent BlueTapatalk 2
#143
Posted 04 February 2014 - 09:53 AM
#144
Posted 04 February 2014 - 12:48 PM
lol now that u got it figured out LOL
UPDATE POSTED!!!
#145
Posted 04 February 2014 - 01:00 PM
#146
Posted 04 February 2014 - 05:50 PM
Got it: Found this was the only thing that fixed after searching all day today, all the apps to Download an such didn't do squat. I guess all the data from google gets turned to putty or something when switching between ROMs etc... and allowing it to update all your google account stuff. First time I encountered it was after the last two updates GPS went sketchy... and I use Device Only setting, no WiFi BS. So if you're having issues with your GPS after updating from ZIP:
From Alex Smith on AskStudent
Lock fix in 4 sec inside house with 8+2 Sat.
Thanks for the update too, this thing is still kicking almost non stop with no FCs or random reboots. Switched to HoloLauncher will see how that goes with the other two issues I was having. Thanks again!
GO DEVs!!
#147
Posted 05 February 2014 - 08:35 AM
#148
Posted 05 February 2014 - 09:18 AM
#149
Posted 05 February 2014 - 02:49 PM
#150
Posted 05 February 2014 - 08:20 PM
Is this something you could change/fix? Another thought I had was going into root explorer and giving both of them full permissions but I'm afraid that might do more harm than good, and would it stick on reboot, or each time I plug in a flash drive?
#151
Posted 06 February 2014 - 12:40 PM
Quick question, Were you able to find a fix for bt and apply it in this update??
UPDATE POSTED!!!
#152
Posted 07 February 2014 - 12:24 AM
Sent from my VS980 4G using Xparent BlueTapatalk 2
#153
Posted 07 February 2014 - 08:57 AM
Have u tried the older version of Netflix? I posted a link a few posts ago
#154
Posted 08 February 2014 - 01:10 AM
The older version of Netflix does work but is not chromecast compatible.
Hmm I plan on putting out an update very soon so we shall see what it brings
- noobiest likes this
#155
Posted 08 February 2014 - 03:53 PM
can you please try and see if you can include Bluetooth fix?
#156
Posted 09 February 2014 - 10:25 PM
- neckchop and sfg like this
#157
Posted 11 February 2014 - 04:40 PM
#158
Posted 11 February 2014 - 05:25 PM
#159
Posted 11 February 2014 - 07:45 PM
Flashed latest wiped dalvic only, incoming caller ID pic only displayed once out of 5 calls today, anyone else?
I would try wiping system, cache, dalvik then flash update and reflash gapps..... let me know
#160
Posted 13 February 2014 - 08:01 AM
is anyone having wakelock issues. my phone refuses to go into deep sleep on stock and arrgggh's kernel. i can't figure it out. so much seems to have changed with running services from 4.3 like apps requiring a notification or they are turned off and whatnot.
