xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#121 pjgraber03
pjgraber03
  • 482 posts
  • Google+:pjgraber03
  • Current Device(s):LG G2 (vs980),Razr M (xt907), Galaxy S2(d710),Galaxy Tab 3 8.0 (sm-t310), Galaxy tab 2 (p3113)
Posted 31 January 2014 - 12:10 AM
Not sure if it's just me but the proximity sensor doesn't turn off the screen when in call and holding the phone to my ear. Kinda seems like all sensors are messed up. Full wipe, 1-27 rom with 1-23 pa minimal gapps, and aaarggghhh's kernel.
I have seen this problem also and a redownload seems to fix it but I'm going to be putting out an update shortly so u might as well wait for that
Sent from my SM-T310 using Xparent BlueTapatalk 2
  • ryankliber likes this
Donate To Show Your Support for Graber Roms
Currently supporting 17+ devices if you would like your device added PLEASE let me know.....pjgraber@gmail.com
#122 pjgraber03
pjgraber03
  • 482 posts
Posted 31 January 2014 - 12:14 AM
I have not tested any other kernel with this ROM I suggest just using the kernel that comes with the ROM it has been optimized for this rom
#123 viper8u2
viper8u2
  • 12 posts
Posted 31 January 2014 - 07:14 AM
Just got back from a conference.  Has anyone tried recording video?  It looks like it records, but when I went back to play the video later it shows video and has sound. there is a high loud pitch on top of it.  Very annoying and can hardly hear what I was trying to record.
#124 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 31 January 2014 - 07:27 AM
That has been a problem across all aosp ROMs for a while now. Drives me crazy too and it doesn't seem like anyone has found a fix
#125 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 31 January 2014 - 09:29 AM
Haven't had any noise issue with recording video...
#126 DroidAddict101
DroidAddict101
  • 259 posts
Posted 31 January 2014 - 01:51 PM
You sure? Try recording something real quick then play it back with the volume all the way up.
When I do that it makes my brain want to explode. Worse than nails on a chalkboard
#127 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 31 January 2014 - 03:38 PM
You're right... It did it this time. I use Focal... But I recorded a video literally three days ago and it was fine, even used it for a website. Now it seems to have that weird beep. Maybe a glitch in an update? Isn't PA on AOSP also? Never had an issue in that either...
#128 pjgraber03
pjgraber03
  • 482 posts
Posted 01 February 2014 - 12:29 AM
Update posted
#129 Robdog
Robdog
  • 6 posts
Posted 01 February 2014 - 04:57 AM
Hi Pj
Are you no longer updating xt925 version?
#130 alexgtshp1
alexgtshp1
  • 31 posts
Posted 01 February 2014 - 06:49 AM
What's in the update? Will it be available ota?
#131 jld
jld
  • 149 posts
  • Current Device(s):Motorola Razr HD MAXX
Posted 01 February 2014 - 07:53 AM
In case anyone is as neurotic about aesthetics as me, I recreated the original lockscreen lock icon and made a png out of it. You can change it under the lockscreen options in settings, looks pretty legit.
#132 pjgraber03
pjgraber03
  • 482 posts
Posted 01 February 2014 - 10:28 AM
Hi Pj
I posted an update for the 925 this morning
#133 pjgraber03
pjgraber03
  • 482 posts
Posted 01 February 2014 - 10:42 AM
The update has under the hood upgrades to make things faster and smoother....... I haven't gotten the ota hooked to my builds as of yet I'm working on it though
#134 alexgtshp1
alexgtshp1
  • 31 posts
Posted 01 February 2014 - 01:28 PM
Think I can get away with dirty flash?
#135 mindcritic
mindcritic
  • 6 posts
Posted 01 February 2014 - 02:18 PM
Seems to have worked just fine for me. Just wipe your dalvik cache and reinstall your gapps :-)
Sent from my XT926
#136 Sleehrat00
Sleehrat00
    Moot Consumer
  • 90 posts
  • LocationNorth Carolina
Posted 02 February 2014 - 05:55 AM
Can someone post where you can download all the available 4.4 kernels for the xt926? Maybe there is already a repository bit I have just missed it if so.
Current consumer, but hopefully one-day purveyor, of high quality moot products.
#137 DroidAddict101
DroidAddict101
  • 259 posts
Posted 02 February 2014 - 07:13 AM
That's the only one I know of. Cm11 kernel in the 5th post down. I'm pretty sure it has caused issues with this ROM tho as the kernel that is already built in is optimized for it.
#138 timmy10shoes
timmy10shoes
  • 198 posts
Posted 02 February 2014 - 06:46 PM
The developers use the kernel that is best for their Rom. Stick with what they have, overclocking, underclocking, different governors and schedulers are minimal gain at best.
Sent from Above
#139 ryankliber
ryankliber
  • 103 posts
Posted 02 February 2014 - 07:40 PM
The arrrghhh kernel was updated 1-31-14 and no longer causes auto rotate/auto brightness issues.
  • DroidAddict101 likes this
#140 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 03 February 2014 - 04:16 PM
After last update earpiece volume is almost nothing...? Will try the app on first page but, why the change? Was awesome before...
