xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#101 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 24 January 2014 - 02:28 PM
What's in the new update? I noticed the nav will still disappear if you wake from active display without the phone being locked. And my far right dock item likes to disappear on reboot also... No biggie. Just a heads up.
#102 NAKAMONIEL
NAKAMONIEL
  • 59 posts
Posted 24 January 2014 - 04:19 PM
Reporting a bluetooth bug, it works, however connecting with my Nissan car it crashes while car asks for phonebook and call history, can you please fix it? thanks
#103 pjgraber03
pjgraber03
  • 482 posts
  • Google+:pjgraber03
  • Current Device(s):LG G2 (vs980),Razr M (xt907), Galaxy S2(d710),Galaxy Tab 3 8.0 (sm-t310), Galaxy tab 2 (p3113)
Posted 24 January 2014 - 07:11 PM
I will look into it...I'm not sure what would cause that....and Ur not the first one to bring this issue up I thought I had gotten it fixed since I hadn't had any complaints but I'll see what I can do
Sent from my VS980 4G using Xparent BlueTapatalk 2
Donate To Show Your Support for Graber Roms
Currently supporting 17+ devices if you would like your device added PLEASE let me know.....pjgraber@gmail.com
#104 pjgraber03
pjgraber03
  • 482 posts
Posted 26 January 2014 - 10:40 PM
UPDATE POSTED!!!!
  • DroidAddict101 likes this
#105 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 27 January 2014 - 12:58 AM
Cool. Any chance Netflix works?
  • 4shlr likes this
Proud father of a US Marine
#106 pjgraber03
pjgraber03
  • 482 posts
Posted 27 January 2014 - 12:44 PM
Not sure give it a try and let me know if not I'll look into it more...did u try as older version of Netflix Sent from my VS980 4G using Xparent BlueTapatalk 2
  • 4shlr likes this
#107 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 27 January 2014 - 01:11 PM
AS crashes on stream start now... :- will try a reinstall. Nav still vanishes when wake from active display when not locked. Will let you know about the dock item vanishing. Everything else is OK. Don't have Bluetooth in my car so cannot test or verify but works no issues with headsets or other audio as far as I can tell. Rock solid, though. Still no random reboots or FCs. Happy camper. Had Hangouts crash opening from active display but only once. Maybe something else in the background interfering.
#108 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 27 January 2014 - 05:59 PM
netflix does NOT work, bummer.  I restarted a couple of times too, just to see if that was it.  No go.  I don't know where to find older versions.  Willing to try, if you have a link you can send.
#109 pjgraber03
pjgraber03
  • 482 posts
Posted 27 January 2014 - 11:18 PM
#110 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 28 January 2014 - 05:16 AM
This version of Netflix...................  WORKS!!!!  Cool.  Now I can play with the beanstalk!!   :p
#111 retromad
retromad
  • 6 posts
Posted 28 January 2014 - 05:30 AM
Awesome now with Netflix!
#112 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 28 January 2014 - 05:44 PM
OK... So as far as the dock item disappearing it happened today without a reboot. Coming out of Chrome the launcher did a redraw and it disappeared. I'm guessing that means it's a glitch in the launcher... Of which I'm using the default. Don't know if that helps.
#113 ryankliber
ryankliber
  • 103 posts
Posted 28 January 2014 - 07:04 PM
Auto Brightness appears to be broken in the last few builds, full wipe. I don't think it's detecting the amount of light as it doesn't display a current sensor value in the auto brightness customization settings.
#114 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 29 January 2014 - 07:50 AM
Confirmed that. Didn't even notice. Just kinda sets it to 50%...
It is reading lux in the custom settings, though. Just not adjusting brightness.
#115 ryankliber
ryankliber
  • 103 posts
Posted 29 January 2014 - 10:35 AM
Auto rotate enabled, but not working.
#116 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 29 January 2014 - 12:06 PM
After reboot auto brightness is working again. Odd, didn't change anything in settings. Don't know if that's the only fix or if it works for anyone else. Good luck with the rest. Looking forward to more good things.
#117 retromad
retromad
  • 6 posts
Posted 29 January 2014 - 02:05 PM
With fast torch enabled phone reboots on long press/release of power button. Torch does light, but having the phone reboot after releasing the button seems to be a bug. I have tried disabling all hard button settings, such as volume control track skipping, to no avail. ROM has been my dd for the last few days and is great so far. Keep up the great work sir! Sent from my XT926 using Tapatalk
#118 jld
jld
  • 149 posts
  • Current Device(s):Motorola Razr HD MAXX
Posted 30 January 2014 - 06:52 AM
Great rom, lots of features! Only question: does anyone have the default lockscreen icon so I can replace the ugly beanstalk? Lol, thanks.
#119 ryankliber
ryankliber
  • 103 posts
Posted 30 January 2014 - 01:50 PM
Not sure if it's just me but the proximity sensor doesn't turn off the screen when in call and holding the phone to my ear. Kinda seems like all sensors are messed up. Full wipe, 1-27 rom with 1-23 pa minimal gapps, and aaarggghhh's kernel.
#120 retromad
retromad
  • 6 posts
Posted 30 January 2014 - 01:53 PM
Ryankliber, try swapping out that kernel, I had the same problem with dynamic notifications and aaarggghh's
