xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#81 pjgraber03
pjgraber03
  • 482 posts
  • Google+:pjgraber03
  • Current Device(s):LG G2 (vs980),Razr M (xt907), Galaxy S2(d710),Galaxy Tab 3 8.0 (sm-t310), Galaxy tab 2 (p3113)
Posted 23 January 2014 - 12:05 AM
Also....I will get some gapps packages uploaded to my server tonight.....I tested out my link for the gapps and Ya it is SLOW so I will get that fixed asap
Sent from my VS980 4G using Xparent BlueTapatalk 2
  • 4shlr likes this
Donate To Show Your Support for Graber Roms
Currently supporting 17+ devices if you would like your device added PLEASE let me know.....pjgraber@gmail.com
#82 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 23 January 2014 - 05:08 AM
Awesome. So is ota good to go? Or do I need to flash this in recovery from your downloads? BTW can I use the donate button in Beanstalk? Or should I use your link? Just wondering. Sometimes that stuff is there but doesn't work right (other ROMs I've had) but I will assume work as well as everything else in this one.
#83 pjgraber03
pjgraber03
  • 482 posts
Posted 23 January 2014 - 05:42 AM
Well I'm working on ota to link it to my server so as far now just flash my updates....as far as donations go. ...just use my link....thanks again
#84 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 23 January 2014 - 06:40 AM
So zip install and wipe cache... Would be like ota... No need for wiping system? Would rather not start from scratch. I got so excited I spent four hours setting everything up...
#85 pjgraber03
pjgraber03
  • 482 posts
Posted 23 January 2014 - 10:10 AM
Wipe cache dalvik Before and make sure system is mounted then flash zip them wipe cache and dalvik after them reboot
#86 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 23 January 2014 - 10:59 AM
Any thoughts / hope on the netflix fc issue?  That is sort of a deal breaker for me, trivial as it may sound.
  • 4shlr likes this
Proud father of a US Marine
#87 4shlr
4shlr
  • 58 posts
  • Current Device(s):Motorola Droid Razr HD Maxx, rooted JB
Posted 23 January 2014 - 11:21 AM
This is what is keeping me from taking the plunge right now. My 2 year old watches Netflix all the time so this is a need for me. Can't wait for the fix tho! Break me off a piece of Kit Kat! :)
#88 viper8u2
viper8u2
  • 12 posts
Posted 23 January 2014 - 03:40 PM
I am running CM10.2 right now and getting the itch
Looks like this is the rom to try for 4.4.  What recovery are folks using to flash?  I was on TWRP 2.6.0 but saw something that I needed a new one.
I am using a CWM based one here (Philz Touch 6):
someone posted this in another forum and I am trying Philz Touch 6 recovery
I miss being able to name my backups with the keyboard of TWRP though
Anyone try the first one here:
#89 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 23 January 2014 - 04:08 PM
Update fixed all my issues. The few there were. Don't have Netflix, Adult Swim app streams no issues. This is definitely the ROM to have. Fast, light, customizable and the dev's on top of sh!t. I switched to this from PA for XT926... Thought it couldn't get better than Paranoid but I'm sold. Was set on Pie control but the option to shrink down the nav with custom density is working way better. If I was all thumbs, they'd all be up. Can't go wrong here. BTW my install was A+ with CWM but make sure you have 6.0.4.4 for XT926 Can I get a donation link? I couldn't find it for some reason... Sent from my XT926 using Tapatalk
  • 4shlr likes this
#90 4shlr
4shlr
  • 58 posts
Posted 23 January 2014 - 04:21 PM
Update fixed all my issues. The few there were. Don't have Netflix, Adult Swim app streams no issues. This is definitely the ROM to have. Fast, light, customizable and the dev's on top of sh!t. I switched to this from PA for XT926... Thought it couldn't get better than Paranoid but I'm sold. Was set on Pie control but the option to shrink down the nav with custom density is working way better. If I was all thumbs, they'd all be up. Can't go wrong here. BTW my install was A+ with CWM but make sure you have 6.0.4.4 for XT926Can I get a donation link? I couldn't find it for some reason...Sent from my XT926 using Tapatalk
Awesome, can anyone else confirm Netflix works?... Please & thank you.
I still use TWRP, which version will I need? Think I'm still on a 2.5 variation.
#91 pjgraber03
pjgraber03
  • 482 posts
Posted 23 January 2014 - 04:37 PM
I use twrp 2.6
I will put up a link to Gapps and. .ing. zip recovery tonight
  • 4shlr likes this
#92 4shlr
4shlr
  • 58 posts
Posted 23 January 2014 - 04:44 PM
I use twrp 2.6 I will put up a link to Gapps and. .ing. zip recovery tonightSent from my VS980 4G using Xparent BlueTapatalk 2
Awesome! Thanks man, looking forward to trying this out
#93 Warrior732MN
Warrior732MN
  • 48 posts
  • Current Device(s):Droid RAZR MAXX HD
Posted 23 January 2014 - 05:47 PM
Netflix does not work for me 4shlr. it has not worked on this ROM at all for me. not a huge deal when everything else is rock effing solid!
  • 4shlr likes this
#94 4shlr
4shlr
  • 58 posts
Posted 23 January 2014 - 06:03 PM
Ok thanks for the heads up Warrior.... I will probably give this a test drive tomorrow without Netflix anyway. Anxious to see it
#95 ryankliber
ryankliber
  • 103 posts
Posted 23 January 2014 - 06:10 PM
Auto Brightness seems to be stuck on default values after a dirty flash. Not really a big deal, I'll just wipe next time.
Have you thought about including the pie control in this rom?
#96 retromad
retromad
  • 6 posts
Posted 23 January 2014 - 06:27 PM
Sweet ROM! Thanks op
#97 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 23 January 2014 - 06:31 PM
Damn, I put Grabber instead of Graber... sorry. *smacks head*
#98 pjgraber03
pjgraber03
  • 482 posts
Posted 23 January 2014 - 11:05 PM
OP UPDATED!!! I have added a link for twrp recovery both .zip and .img working on getting up a new link for gapps
#99 pjgraber03
pjgraber03
  • 482 posts
Posted 23 January 2014 - 11:22 PM
OP UPDATED!!!! add link to gapps  on my server
#100 pjgraber03
pjgraber03
  • 482 posts
Posted 24 January 2014 - 12:13 PM
UPDATE POSTED !!!!!!
  • neckchop and NAKAMONIEL like this
