xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#41 shockwaver
shockwaver
  • 8 posts
Posted 10 January 2014 - 04:20 AM
i used the same ones and i have tried others. are you guys using twrp or cwm to install and what versions?
#42 Warrior732MN
Warrior732MN
  • 48 posts
  • Current Device(s):Droid RAZR MAXX HD
Posted 10 January 2014 - 04:32 AM
I use Philz Touch Recovery. CWM based.
#43 augie757
augie757
  • 40 posts
  • Twitter:@augie757
  • Google+:chris augustine
  • LocationHoth
Posted 10 January 2014 - 04:39 AM
Using pa gapps newest. Hangouts SMS no go. Clean install.
#44 augie757
augie757
  • 40 posts
  • Twitter:@augie757
  • LocationHoth
Posted 10 January 2014 - 04:40 AM
Using twrp
#45 tmord1
tmord1
  • 36 posts
Posted 10 January 2014 - 05:33 AM
Hi, Installed as instructed and all seemed great. I started restoring my old apps with Titatinium Backup (latest version) and it indicated I needed to change to Supersu. After I downloaded supersu from the app store, I lost root (had it after initial install and before supersu). Any ideas, luckily I made a nandroid backup before I started and just rolled back to that. For what it's worth, sms hangouts were working for me before supersu install, I got several messages while using Titanium. Rom seems very smooth and I'd like to try it again, any suggestions on what to do if I lose root again? Thanks!
#46 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 10 January 2014 - 07:00 AM
Because of the way su is built into settings it always tells you to update but since its built into the ROM in a different way it screws something up. I never update because the same thing happened to me. Just don't try to update and you should be fine
  • tmord1 likes this
#47 tmord1
tmord1
  • 36 posts
Posted 10 January 2014 - 07:04 AM
Thanks droidaddict101, I'll try to reflash later!
#48 tmord1
tmord1
  • 36 posts
Posted 10 January 2014 - 01:14 PM
Quick question, been running the rom all day, very smooth and loaded with great features. The only thing is I only have one signal bar and I usually have atleast 3 at home. I checked signal strength and it show -108dbm in the status screen. Is there an alternative radio or a break in period, a setting that can be tweaked to increase reception? I am on Verizon's network.
Thanks!
#49 DroidAddict101
DroidAddict101
  • 259 posts
Posted 10 January 2014 - 03:43 PM
Thanks!
To be honest I've had some weird data issues. What I've done to solve them is toggle data modes in settings and then wiped cache in recovery
#50 2mnydgs
2mnydgs
  • 8 posts
  • Locationcornfield
  • Current Device(s):xt926
Posted 10 January 2014 - 04:55 PM
Ive had data weirdness and delayed data turn on since 4.3
#51 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 10 January 2014 - 06:16 PM
Just flash a SuperSU.zip in recovery and you shouldn't have an issue.
  • tmord1 likes this
#52 HDWILLIAMS
HDWILLIAMS
  • 41 posts
  • LocationCalifornia
  • Current Device(s):XT1254,Acer A200
Posted 10 January 2014 - 10:29 PM
Flash with Rsd lite Or Twrp? Never mind I figured it out. Ty.
#53 themrgoats
themrgoats
  • 137 posts
Posted 12 January 2014 - 01:14 PM
Front camera pictures work for me but still can't get front videos to work. Anyone else?
#54 themiladoman
themiladoman
  • 41 posts
Posted 12 January 2014 - 03:28 PM
I can't seem to get any voice recognition period texting Google now nothing just says Google cannot be reached...anyone else have this issue? I did a clean wipe and flashed like normal with latest twrp and used latest PA Gapps
#55 DroidAddict101
DroidAddict101
  • 259 posts
Posted 12 January 2014 - 04:44 PM
NEW BUILD IS UP!!:D
#56 DroidAddict101
DroidAddict101
  • 259 posts
Posted 12 January 2014 - 04:59 PM
And voice to text has been fixed. No issues with SMS/hangouts so far.
Thanks dev. This is my favorite ROM right now
  • pjgraber03 likes this
#57 pjgraber03
pjgraber03
  • 482 posts
  • Google+:pjgraber03
  • Current Device(s):LG G2 (vs980),Razr M (xt907), Galaxy S2(d710),Galaxy Tab 3 8.0 (sm-t310), Galaxy tab 2 (p3113)
Posted 12 January 2014 - 05:58 PM
I'm glad that you enjoy it....I hope everyone enjoys my work...If anyone has ANY issues plez let me know
  • DroidAddict101, wheels01, Warrior732MN and 1 other like this
Donate To Show Your Support for Graber Roms
Currently supporting 17+ devices if you would like your device added PLEASE let me know.....pjgraber@gmail.com
#58 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 14 January 2014 - 04:17 AM
I updated with the latest build - by using a restored version to update upon - and Netflix would not work, dolphin closing.  Cleared caches, etc, rebooted, etc.  No go.  Anyone else seeing some stuff not working?
I dropped back to Carbon KK and netflix works fine and no other closing issues.
Should I try a clean install?  Other thoughts?
EDIT:  Did a clean install - Netflix still does not work.  Reloaded Carbon KK, works fine.
Proud father of a US Marine
#59 DroidAddict101
DroidAddict101
  • 259 posts
Posted 14 January 2014 - 10:22 AM
Its always a good idea to do a clean install if you run into bugs.
Quite a few devs will actually get irritated when bugs are reported without a clean install because you don't know what caused the bug, the rom itself or the dirty install. Just another friendly heads up :p
  • neckchop likes this
#60 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 14 January 2014 - 12:11 PM
No worries - my first attempt to be clear, was "clean" in that I wiped all, then restored an earlier version - THEN updated with the new version.  I think that is an accepted method, since the orig was a CLEAN install.
Anyhow -  The new REALLY clean install didn't work either on Netflix (not sure if you read that part).
