xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#521 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
  • Current Device(s):motorola droid razr maxx hd
Posted 11 July 2014 - 04:08 PM
Latest nightly is solid. GPS works without issue for me. Battery is solid. Haven't had random reboots.
The only problem I've seen is that if you switch speakerphone on and off, the mic doesn't work. I don't use speakerphone, so that isn't a problem for me.
#522 hddeuce60
hddeuce60
  • 41 posts
Posted 12 July 2014 - 04:46 AM
Same here and I've noticed the speaker phone isn't very loud
#523 hddeuce60
hddeuce60
  • 41 posts
#524 MajorPay
MajorPay
    Code Monkey
  • 17 posts
  • LocationColorado
  • Current Device(s):XT926
Posted 12 July 2014 - 08:33 AM
Can't install... Have one from June installed, but getting errors about executing the binary on the 7/10 release
Sent from my moto_msm8960 using Tapatalk
#525 grunt344
grunt344
  • 5 posts
Posted 12 July 2014 - 08:47 AM
You may have to grab the kit kat bootloader first
#526 lgoptimusv5
lgoptimusv5
  • 55 posts
  • Current Device(s):XT926 JBBLKitStalk444065 TWRP2800V2
Posted 14 July 2014 - 09:32 AM
GPS issues...
Recently updated to stock 442 and new bootloader.
Then tried Beanstalk Builds from 7-4, 7-12, and 7-14.
No GPS for me on any of those i tried.
Google Location Settings are blank when i look.
It asks me to agree, and tries to re-enable location services each time, but never does.
**UPDATE**
GPS working fine on 7-14 build after using GMSCore and GoogleServicesFramework APKs from STOCK442.
I'm using pa_gapps-4.4.2-BlackedOut, and remembered I had to replace Gmail.apk, decided to try to replace GMSCore + Framework (relating to previous GPS Fix...)
I restored my TWRP backup of stock 442, opened Maps, and accepted everything regarding Location services.
Next, I stole the GMSCore and GoogleServicesFramework APKs from Stock442.
I then put them in my pa_gapps-4.4.2-BlackedOut (renamed GMSCore -> PrebuiltGMSCore.apk -> PrivApp)
Voila! GPS working perfectly :)
I also had the Speakerphone/Mic issue with 7-14 build.
I replaced the Dialer.apk with the one from the 6-05 v442 build.
Speakerphone working Fine now :)
Only 1 random reboot so far when i tried opening QuickPic the 1st time.
Really digging the "Hover" in this build... It's like Growl, but for Droids...
#527 hddeuce60
hddeuce60
  • 41 posts
Posted 14 July 2014 - 03:25 PM
Where can I grab the Dialer.apk from the 6-05 v442 build
#528 lgoptimusv5
lgoptimusv5
  • 55 posts
Posted 14 July 2014 - 06:46 PM
I got it from "KitStalk-4.4.285-20140605-moto_msm8960.zip"
But it looks like it's already been removed from the site...
#529 lgoptimusv5
lgoptimusv5
  • 55 posts
Posted 15 July 2014 - 03:14 PM
Blue flickering screen issue with 7-14 build.
I 'think' it's Hover related...
Seems to happen after screen has been sleeping for a while, then use 'Lock Icon Torch' to get hover to appear.
Blue flickering while hover is present and Torch is on.
Within the same minute:
I can turn off hover and use Lock Icon Torch without blue flicker.
Turn hover back on quickly, use Lock Icon Torch, and get blue flicker again
Seems to clear up after a minute or so, and no issues again until screen sleeping for a while.
#530 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
Posted 17 July 2014 - 08:12 AM
Haven't had any problems with this for a while, and battery has gotten better with the 7/13 build.
Downloading 7/16 now, maybe I'll flash it some time today.
#531 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
Posted 17 July 2014 - 08:13 AM
#532 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
#533 themiladoman
themiladoman
  • 41 posts
Posted 18 July 2014 - 02:25 PM
just a heads up cyanogemod had a build that was released it was 7/16 it is experimental and both BT and GPS ARE WORKING!!!!! FINALLY LOL...so we should hopefully see whatever changes were made in the build implemented into all other custom roms for the moto_msm8960 family :)
#534 nal
nal
  • 164 posts
  • LocationIllinois
  • Current Device(s):Droid Razr HD xt907/26, LG G2, Nexus 7 2012
Posted 18 July 2014 - 03:47 PM
I went on the nightly today and it fixed the https ssl issue too! :)
#535 lgoptimusv5
lgoptimusv5
  • 55 posts
Posted 20 July 2014 - 05:20 AM
Builds from 7-16 and 7-18 won't boot :(
7-14 last build that worked for me (on KK Bootloader)
*apparently builds from 7-16 and up will be for JB Bootloader...
#536 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 20 July 2014 - 05:42 AM
Been out of the loop for a bit dealing with building some other stuff. Is drdevs down? Can't get in to download new updates... Is the new boot loader required and will it be available in the Graber directory?
#537 lgoptimusv5
lgoptimusv5
  • 55 posts
Posted 20 July 2014 - 07:21 AM
New KK bootloader IS required for latest 4.4.4 builds (I think 6-21 was last 4.4.4 build for old bootloaders)
If you're still on the OLD bootloader, I'd recommend using the KitStalk-4.4.285-20140605-moto_msm8960.
If you're on the new KK bootloader, KitStalk-4.4.4007-20140714-moto_msm8960 is almost flawless.
Only Speakerphone and minor Hover issues for me on the 7-14 build.
And as mentioned earlier, cm-11-20140718-NIGHTLY-moto_msm8960 is pretty solid now (KK bootloader)
I also cannot get into the drdevs today
#538 thomasjamesbell
thomasjamesbell
  • 6 posts
Posted 22 July 2014 - 01:40 PM
Quick question: any time I install this
 or ANY other rom for that matter, the wifi gets all screwy. It will connect for a little bit then cut out, the wifi status switching between saved and authenticating. It happens with every rom except stock. Is it something I did wrong in the install process?
#539 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
Posted 23 July 2014 - 05:50 PM
WiFi has been iffy with every 4.4.4 ROM I've tried.
What's going on with drdevs? Any other site available to get kitstalk from?
#540 artnig
artnig
  • 5 posts
Posted 24 July 2014 - 11:12 AM
Wondering the same thing, have been trying DrDevs site for a week now and its still 404ing
