is msm8960 the RAZR M? If so, here
#501
Posted 18 June 2014 - 07:08 PM
#502
Posted 18 June 2014 - 07:29 PM
RAZR m, xt926, etc. Motos with the same msm8960 cpu from what I understand it's not specific to one device. "unified"is msm8960 the RAZR M? If so, here
#503
Posted 18 June 2014 - 07:30 PM
#504
Posted 18 June 2014 - 08:16 PM
Seems like I got it off xda in one of the threads explaining how to get it on the phone the first time. Though I'd think you could just go to TWRP's website and get it there... not sure
I still have the program and the recovery image if you want I guess but probably best get it from a more trusted source. The program is in a folder named "unlocked_root_1.7" if that helps...
#505
Posted 18 June 2014 - 08:26 PM
maybe this will help. Different method I think but probably same result
#506
Posted 19 June 2014 - 06:16 AM
#507
Posted 19 June 2014 - 06:21 AM
Sent from my S-Offed One M8
#508
Posted 20 June 2014 - 12:48 PM
Now from what I understand the 2.7.1 is compatible with the KitKat bootloader, which I do not have and will not update to considering it has been problematic for many. Any idea if it works with the JB bootloader as well? Not sure if I need to update, I just like having the newest version outYou can also get it from dhacker directly -
#509
Posted 21 June 2014 - 03:30 AM
*THANKS FOR THIS ROM*
I've been running a homemade InfliktedHD/BlurryHD 4.1.x hybrid ROM for a looooong time now with no issues, but I'm itching to try a Stable KitKat ROM.
I need FULL functionality out of my XT926, and from what I've read, this ROM sounds like the winner
Any recommended/preferred 'most stable' build for XT926?
Or just go with the latest 'n greatest...
What's the good word on the 6-21-14 Build?
Changes?
PlayStore Issues resolved? (Downgrade to v4.6.17 still needed?)
*THANKS AGAIN FOR ALL YOUR WORK*
#510
Posted 21 June 2014 - 08:38 AM
Sent from my moto_msm8960 using Tapatalk
#511
Posted 23 June 2014 - 05:15 PM
So far, so good. We'll see how well this ROM goes after a day of use.
#512
Posted 24 June 2014 - 02:25 AM
You running the newest build with the KitKat boot loader_?Decided to give this ROM a shot after sticking with a 4.4.2 ROM for months. I wanted to try 4.4.4.
#513
Posted 24 June 2014 - 05:49 PM
Yup, the newest build. And it hasn't been bad for the first day.
#514
#515
Posted 24 June 2014 - 06:37 PM
#516
Posted 24 June 2014 - 06:41 PM
The speakerphone is still super quiet
#517
Posted 25 June 2014 - 02:52 AM
#518
Posted 25 June 2014 - 04:15 AM
This ROM is BEAST!
LOVE the stability, battery life, and the ridiculous amount of features!
This ROM should be named **BEASTSTALK**
XT926 TWRP2630 came from 4.1.x based ROM, complete Wipes, Clean install (never dirty flash)
Running the 6-21 build, using Kernel that came with it, pa_gapps-4.4.2-BlackedOut, APEX launcher
ISSUES:
-Sometimes the Buttons on the Dialer will not work when on a call. (#'s Mute Speakerphone ect.)
So far it's random, will work most of the time
-GMAIL that came with pa_gapps-4.4.2-BlackedOut did NOT work for me.
I just manually replaced it with another Gmail.apk of my choice...
-Sound is Quiet, but jacked everything up back to par with ViPER4Android_FX eXtra-loud setting.
-I initially had no Mobile Data, but started working after 2nd boot.
-GPS Issues at first.
Would initially start Navigation, but GPS Signal lost pretty quickly.
Disabling location/enabling location would prompt me to Agree to Location consent again, then GPS would work fine without even closing the app.
I had to repeat this process every time to use Navigation.
I applied 1st GPS Fix mentioned earlier in here, and it seemed to work:
*GPS FIX #1:*
1. Turn off “Access my location” in Location Access Setting
2. go into google services framework in applications, settings, and clear data
3. Clear data for maps as well
4. reboot the phone
5. Turn on “Access my location” in Location Access Settings
*GPS FIX #2: (if #1 doesn't work)
Put GPS in device only and then back into high accuracy while in maps.....
NOTE: After doing the GPS fix #1, I had no mobile data, but worked fine after another reboot.
When on a Call using a Wired headset with Microphone, the Micropohone Button on the Wired Headset will Hang up the Call when pressed. (using old white iProduct headphones with Mic)
That button would previously MUTE on the old 4.1.x based ROMs.
Is there any way to change that?
*UPDATE* 7-14 build now MUTEs
#519
Posted 28 June 2014 - 08:34 PM
sorry wrong forum.
#520
Posted 01 July 2014 - 05:31 PM
nevermind
Edited by nal, 01 July 2014 - 05:32 PM.
