xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#481 johnnysyeah
johnnysyeah
  • 59 posts
Posted 04 June 2014 - 05:38 PM
I use my phone with Bluetooth speakers and don't have any issues. Did this happen with previous ROMs? If not maybe it's your car?.... Sent from my moto_msm8960 using Tapatalk
Didn't happen with other roms.
It's happening with my Jawbone speakers also. I'll just try a reflash and see if that fixes it.
Thanks!
#482 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 06 June 2014 - 04:25 AM
What is the easiest way to change the boot animation? Is there an option in the settings menu? I'm new to this ROM, but I've used others in the past that allowed the boot animation to be selected from a list in the settings. I just can't seem to find anything.
I use ROM Toolbox Pro. It comes with a ton of boot animations...
  • hoosteen likes this
#483 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 06 June 2014 - 04:27 AM
I just spent an hour setting up my phone on a fresh install 6-5 build and all of a sudden I'm getting this :(
  45.62KB   34 downloads I tried clearing cache and app data but it didn't work. Any ideas?
#484 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 06 June 2014 - 04:44 AM
My phone also just freaked out. Wallpaper was flashing black and then back to a random picture until I rebooted. Not sure what the newest build has done to it but something isn't right here.
#485 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 06 June 2014 - 04:55 AM
Apparently it was my theme that was messing with my phone. Switched it back to stock and I'm good to go.... Wierd
#486 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 06 June 2014 - 02:45 PM
I just spent an hour setting up my phone on a fresh install 6-5 build and all of a sudden I'm getting this :(attachicon.gif
For some reason this ROM doesn't like Play Store v4.8.19 or v4.8.20...Downgrade to v4.6.17 and everything will be fine. Glad to hear you got your other problem fixed.
BTW, come over to our Razr M thread, for more support :)
  • Slickademo likes this
Need Help? Send me a message
#487 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 08 June 2014 - 04:13 AM
Go sure sounds good!
#488 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 09 June 2014 - 05:19 AM
I'm glad I checked out the RAZR M thread. I saw you have the arrrghhh kernel. Finally tried it and I'm very happy with the results. Better performance with the increase of processor speed and now I'm using Smartassv2 as a governor and it has helped keep everything smooth with good battery life! Thanks again!
  • nprevette420 likes this
#489 CobaltDroid
CobaltDroid
Posted 13 June 2014 - 11:31 AM
I'm not on the very latest update yet but I have some issues I'd like to report.
-OTA Update doesn't update, could be a recovery issue because the installation fails when recovery begins the process
-Active Display only works as a visual. When I go to click the middle icon to choose the three options it just unlocks the device and opens the app with the notification. Doesn't let me choose to clear the notification or unlock device.
-Keyboard doesn't always display. Sometimes when I change apps and the cursor is already in the text field, the keyboard is not showing but my Back button is already changed to the Close keyboard button. When I click that nap button the keyboard flashes and then is dismissed. Once I click the text box again it appears properly.
Other than that haven't noticed anything other than a lot of Force Closes if the phones been running non stop for a few days, seems someone already brought up the Google Play Services issue.
Love this Roms customization options!
#490 Guest_RCOO_*
Guest_RCOO_*
Posted 16 June 2014 - 11:26 AM
Will this rom work on the latest official software?
#491 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 17 June 2014 - 03:48 AM
So I just noticed that Cyangoenmod released a 4.4.3 for msm8960 I unified.... (Cough cough) hint hint :-p
#492 jtommyj
jtommyj
  • 181 posts
Posted 17 June 2014 - 04:38 PM
Do you have a link cause the 6-17 if that is what you're referring to is 404 right now. Thanks !
#493 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 June 2014 - 03:51 AM
Link for the cyanogenmod 4.4.3 ?
#494 Jaysp656
Jaysp656
  • 9 posts
Posted 18 June 2014 - 06:57 AM
yeah, I think that is what he means. Where did you see this?
was it here?
#495 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 June 2014 - 09:43 AM
was it here?
Yes, that is it. Running it right now until kitstalk 4.4.3 is released.
#496 Jaysp656
Jaysp656
  • 9 posts
Posted 18 June 2014 - 10:03 AM
ah, guessing it is still on the JB bootloader as the 6-17 just puts me in bootloop.
O_O *waits patiently*
#497 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 June 2014 - 10:20 AM
I flashed with TWRP 2.7.0 and even used arrrghhh's kernel. Been running smooth all day. Ain't no Kitstalk but it's pretty sweet.
#498 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Looks like 6-18 is on there already as well.
#499 Jaysp656
Jaysp656
  • 9 posts
Posted 18 June 2014 - 03:21 PM
well I'm going to download the 6-18 and see if I can install it or not. don't think I can successfully though.
I have TWRP 2.7.1 and the kernel I have is whatever came with SamuriHL's Data Keep script method for updating to KK.
#500 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 June 2014 - 06:42 PM
well I'm going to download the 6-18 and see if I can install it or not. don't think I can successfully though. I have TWRP 2.7.1 and the kernel I have is whatever came with SamuriHL's Data Keep script method for updating to KK.
Where can I find TWRP 2.7.1 for msm8960 ? Sent from my DROID RAZR HD using Tapatalk
