xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#361 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 09:29 AM
Oh and most noticeable change was DPI settings. Looks to be higher resolution now.
#362 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 09:31 AM
  46.5KB   15 downloads
#363 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 09:36 AM
I forgot when it was added and I already had it but this ROM comes with AdAway now (which is awesome) and I noticed viper4android has been updated
#364 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
OK. I meant flashing the recovery from a zip... Switching from CWM to TWRP... There are zip files in the recovery directory on Graber... Never flashed a recovery as a zip. Can't find any info on it, at least for the XT926...
#365 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 10:16 AM
The direct downloads are zip files too. It should be like 238 mb in size. Yes, that is what you flash in recovery along with your gapps. I let the ROM grabber flash for me.
#366 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 10:17 AM
CWM and TWRP essentially do the same thing just different interfaces and a few different features. I like TWRP a lot more.
#367 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 10:22 AM
Anyone have any idea why my screen recorder doesn't work ? I go from the power menu and get either of these messages...
  55.14KB   13 downloads
  75.28KB   13 downloads
  77.43KB   13 downloads
#368 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 04 April 2014 - 10:24 AM
You've missed the whole point of what I asked. I know what recoveries are, what they do. I know what zips are and what they do. I know how to flash them etcetera... Try again: I have CWM on my phone... I want to switch to TWRP... There are zip files of the RECOVERY on Graber's directory... Is there a way to FLASH THE RECOVERY, not the ROM, instead of using the fastboot method... What is the purpose of having the RECOVERY in zip format other than to use it to be flashed in a bootloader or other method. I'm trying to change the RECOVERY without using a computer via fastboot method. Make more sense? I'm already well versed in the ROM side of things. I just haven't found any info on loading a recovery other than in fastboot...
#369 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 10:43 AM
Lol sorry my bad. You should be able to just download an app called "Flashify" and go from there. If I remember correctly you can download and flash TWRP right from the app.
#370 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 04 April 2014 - 10:48 AM
Perfect, thanks. Was wondering what the hell was up with the recoveries as a zip. I'll check it out. Is there any particular reason we are running a JDM on a dyno with an open cooling system?
#371 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 10:53 AM
That was my last year setup. GT3076R @ 10psi on e85 making 330 whp B18C1 stock internals. This year I'm doing 93 pump gas water/meth injection, fully built B18c1 bottom built pr3 head. Going for 525 whp Sent from my DROID RAZR HD using Tapatalk
#372 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 04 April 2014 - 10:55 AM
I have a G8 GT that's getting built for HPDE next year. About 500 RWHP N/A. I just saw the coolant funnel and wondered why it was an open cooling system on the dyno...
#373 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 10:57 AM
I forget why. That's something my tuner did. I really don't know. Lol I think he did that at the beginning to make sure there was no air in the system or something like that
#374 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 04 April 2014 - 12:13 PM
Sweet. Flashify=awesome. Don't know why I never heard of it. Still had to use the IMG file instead of ZIP but worked perfect. No more fastboot BS. Flashed TWRP no issues. Gonna start the ROM updating after work. Thanks the help.
  • Slickademo likes this
#375 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 12:33 PM
Glad I could help!
#376 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 04 April 2014 - 12:34 PM
Yeah... I've used ROM manager and all that before and they never seem to want to work right... Stuff doesn't show up, or it doesn't flash properly. Flashify was on point right after install. Can't ask for much more.
Sent from my TF300T using Tapatalk
#377 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 02:27 PM
You ever check out ROM toolbox? That's my all time favorite app. The pro version is well worth buying. Some awesome features.
#378 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 04 April 2014 - 04:19 PM
I tried ROM toolbox and it kept acting fishy. Dunno if it was the ROM I had before but I just never tried it again since that. Anyone else having flash issues? I just downloaded 0404 to flash and TWRP get FAILED Could not open ZIP... Bad download?
#379 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 04 April 2014 - 05:11 PM
Is it 239 mb ?
#380 kamaromike
kamaromike
  • 164 posts
  • LocationFlorida
Posted 04 April 2014 - 07:05 PM
Is it 239 mb ?
244... 0403 & 0404 are both 244MB...
