xt926 kit kat kit-kat beanstalk razr razr hd razr maxx razr max razr max hd xt926 rom
567 replies to this topic
#1 pjgraber03
pjgraber03
  • 482 posts
  • Google+:pjgraber03
  • Current Device(s):LG G2 (vs980),Razr M (xt907), Galaxy S2(d710),Galaxy Tab 3 8.0 (sm-t310), Galaxy tab 2 (p3113)
Posted 06 January 2014 - 11:53 PM
  53.02KB   475 downloads
Requirements to flash:
An xt926 (you never can tell)
You must be rooted!
You must have an unlocked bootloader
and you must have a custom recovery (I personally like TWRP)
Known bugs!
None that is know....that said I am human and may have missed something.  If you find something isn't working please let me know.
Features:
The features are quite extensive.  There is:
init.d support
init.d script tweaks
custom nav bar
custom status bar
active display (like the Moto X)
Halo
Build.prop mods
To see a full list of features go
For Audio Mods Install
To Install:
Wipe data, system, dalvik, cache 3x
flash rom
flash gapps
reboot
Gapps packages:
 -- Goo.com
-- My link
For Anyone who need it:
Special Thanks:
Beanstalk
Timpohladthomas
Tucstwo
DrDevs
Download Beanstalk
Any questions or comments: pm me or contact me on hangouts pjgraber03@gmail.com
SEE MY OTHER POSTS FOR OTHER SUPPORTED DEVICES!!!!
  • neckchop, DroidAddict101, satman80 and 11 others like this
Donate To Show Your Support for Graber Roms
Currently supporting 17+ devices if you would like your device added PLEASE let me know.....pjgraber@gmail.com
#2 HDWILLIAMS
HDWILLIAMS
  • 41 posts
  • LocationCalifornia
  • Current Device(s):XT1254,Acer A200
Posted 06 January 2014 - 11:56 PM
Wi Fi Tether Work?
#3 pjgraber03
pjgraber03
  • 482 posts
Posted 07 January 2014 - 06:05 AM
It should yes. ....I have this on my 907 abs wifi tether works
Sent from my VS980 4G using Xparent BlueTapatalk 2
#4 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 07 January 2014 - 06:21 AM
Thanks for this. Will give it a try after work
  • pjgraber03 likes this
#5 themrgoats
themrgoats
  • 137 posts
Posted 07 January 2014 - 08:13 AM
Thanks man. Beanstalk is the only one I'll roll with. Been waiting for some 4.4. Can't wait for that camera fix.
#6 pjgraber03
pjgraber03
  • 482 posts
Posted 07 January 2014 - 10:32 AM
UPDATE POSTED!!!!!!
#7 pjgraber03
pjgraber03
  • 482 posts
Posted 07 January 2014 - 11:24 AM
OP UPDATED!!!!! Camera is fixed!!!!
#8 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 07 January 2014 - 11:40 AM
Cool does mms work?
Proud father of a US Marine
#9 DroidAddict101
DroidAddict101
  • 259 posts
Posted 07 January 2014 - 01:52 PM
Cool does mms work?
I'm going to flash in about an hour and I'll report back if you haven't tried it yet.
I'm also eager to see if tethering works for sure
#10 pjgraber03
pjgraber03
  • 482 posts
Posted 07 January 2014 - 02:52 PM
To be honest my 907 isn't connected to service....I have an lg g2 so Ya let me know if it does....it should though
  • tmord1 likes this
#11 DroidAddict101
DroidAddict101
  • 259 posts
Posted 07 January 2014 - 03:07 PM
Tethering works! MMS works!
Had some weird data lag at first but a reboot fixed it. So far so good.
Thanks for building this. Gonna be running it for a while I think.
#12 jtommyj
jtommyj
  • 181 posts
Posted 07 January 2014 - 03:23 PM
Yeah really runs great !! Thanks for putting this together for us 926 owners bud !!
#13 themrgoats
themrgoats
  • 137 posts
Posted 07 January 2014 - 07:53 PM
Front video camera has not worked for me
#14 jtommyj
jtommyj
  • 181 posts
Posted 07 January 2014 - 08:05 PM
Working fine here.
#15 DroidAddict101
DroidAddict101
  • 259 posts
Posted 07 January 2014 - 09:24 PM
Anybody else having sporadic data issues? I have 3-4 bars of 4g and it seems to lag for like 5 seconds and then load. Edit: Flashing argh's cm11 kernel fixed my strange data issues
#16 HDWILLIAMS
HDWILLIAMS
  • 41 posts
Posted 07 January 2014 - 10:41 PM
Why won't this install? I am on 4.4 ROM factory 1.1.1 uggh!!!! Always fails. And don't ask me if I did a full wipe. My rear end hurts from wiping so much.
Sent from my Droid Razr HD using Tapatalk
#17 TALLYWACKER
TALLYWACKER
    Android caused my divorce !
  • 139 posts
  • LocationSouth
  • Current Device(s):M8 ROOTED S-OFF UNLOCKED, XT926 UNLOCKED
Posted 08 January 2014 - 04:27 AM
Running this with arrrghhh's cm11 kernel = stupid fast great job bro !
#18 2mnydgs
2mnydgs
  • 8 posts
  • Locationcornfield
  • Current Device(s):xt926
Posted 08 January 2014 - 06:00 AM
Voice to text was crashing should I try a different keyboard or will all hell break loose
#19 pjgraber03
pjgraber03
  • 482 posts
Posted 08 January 2014 - 06:40 AM
I normally use Google keyboard
#20 2mnydgs
2mnydgs
  • 8 posts
  • Locationcornfield
Posted 08 January 2014 - 07:30 AM
