Possible XT907 Brick
32 replies to this topic
#21 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 05:40 PM
FAILED (remote failure)
finished. total time: 0.307s
sending 'system' (30720 KB)...
OKAY [  2.350s]
writing 'system'...
Battery Low!!
finished. total time: 2.646s
sending 'boot' (10240 KB)...
OKAY [  0.789s]
writing 'boot'...
Invalid partition name boot
finished. total time: 0.921s
erasing 'userdata'...
Invalid partition name userdata
finished. total time: 0.127s
sending 'modem' (30720 KB)...
OKAY [  2.351s]
writing 'modem'...
Unkown partition name modem
finished. total time: 2.484s
erasing 'modemst1'...
Invalid partition name modemst1
finished. total time: 0.128s
erasing 'modemst2'...
Invalid partition name modemst2
sending 'fsg' (2794 KB)...
OKAY [  0.221s]
writing 'fsg'...
Invalid partition name fsg
finished. total time: 0.353s
[*] Flash complete, Rebooting..
rebooting...
finished. total time: 0.006s
#22 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 01 February 2014 - 05:47 PM
^^^Battery is low...
#23 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 05:49 PM
yes. but it is a glitch. i restarted the phone. battery is ok now. running it again. appears to be doing something this time.
#24 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 05:51 PM
tyvm livinginkaos!!!!!
  • johnthehillbilly likes this
#25 johnthehillbilly
Posted 01 February 2014 - 05:55 PM
Usually (typically) ..... If it gives the battery low error..... Then nothing will flash because it "thinks" that the battery is to low to successfully flash..... Its a built in protection ......
However..... You said it booted, so it must just have a bad additude.....hehehehe
"No more training do you require...... already know you, that which you need...."
#26 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 06:04 PM
yeah. i am just happy it is back. battery is 77%, so not sure what it was besides a glitch. now i think its time to take a break away from the phone and computer. thanks a bunch to everyone here at droidrzr!!! I am not sure what i would do without this website!!
  • johnthehillbilly and livinginkaos like this
#27 johnthehillbilly
Posted 01 February 2014 - 06:16 PM
Glad you are back up and running..... That's always great news!!!!
#28 Aizarxplosiv
Aizarxplosiv
  • 7 posts
  • Current Device(s):Motorola Droid Razr M
Posted 14 July 2014 - 09:33 AM
I'm suffering from the same pain. I flashed JB then updated to next update but since my bootloader was unlocked it crashed and it set me to the fastboot loop. Now i can't get out of that. Help me. The link of Cap n slow and livinginkaos are down. Please provide an alternative link or method so that I can use my Droid again.
#29 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 14 July 2014 - 09:59 AM
You can try searching in this very same forum for a how-to thread on how to update to the latest KK update.  Also, what kind of error are you getting in fastboot?
#30 Aizarxplosiv
Aizarxplosiv
  • 7 posts
Posted 14 July 2014 - 10:15 AM
I get the following text on my Fastboot -
AP Fastboot Flash Mode (S)
Device is LOCKED, Status Code: 0
Battery OK.
downgraded security version
update gpt_main version failed
Failed to hab check for gpt_backup: 0x35
failed to load GPT
CID read failed
Invalid CID status 0x69.
And whenever i try to flash using RSD or HousofMoto i get the following errors :
Invalid partion name
FAILED( remote failure).
#31 Aizarxplosiv
Aizarxplosiv
  • 7 posts
Posted 14 July 2014 - 09:09 PM
Thanks to all for the help. My Droid has life again. Just had to flash Kitkat (newer ROM).
#32 huyminhco123
huyminhco123
  • Current Device(s):Motorola droid razr m
Posted 22 July 2014 - 04:30 AM
Battery OK.
failed to load GPT
CID read failed
mee to !
#33 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 22 July 2014 - 09:03 AM
mee to !
That's because you're trying to downgrade.  Re-read the post above yours, there's the solution...;)
