Possible XT907 Brick
32 replies to this topic
#1 AK47sForAll
AK47sForAll
  • 50 posts
Posted 02 January 2014 - 01:54 AM
So...got tired of dealing with roms and went back to all stock on my phone and accepted the update. Now the Device is locked and only goes into fastboot and won't display anything other than that. It says things like
downgraded security version
update gpt_main version failed
failed to hab check for gpt_backup: 0x35
failed to load GPT
CID Read Cailure
Invalid COD status 0x69
Any ideas?
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 02 January 2014 - 03:02 AM
I tried to find the solution in here, I thought there was a thread on DroidRzr, but here's a thread on XDA.  Should be as simple as flashing in RSD or using House of Moto to fix your problem.  Don't worry, the BL being locked is just a glitch.  Once the flash goes through, you should still be unlocked.
  • romma1 likes this
#3 AK47sForAll
AK47sForAll
  • 50 posts
Posted 02 January 2014 - 03:08 AM
The mediafire link he posted in that seems to be down.
Ok I found that, but RSD doesn't seem to recognize my phone...
#4 AK47sForAll
AK47sForAll
  • 50 posts
Posted 02 January 2014 - 03:29 AM
Nvm <3 Got it. I really thought I had fried it that time. Many thanks.
  • RikRong likes this
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 02 January 2014 - 06:40 AM
Nice to see you got it working.  Post what you did to fix it, to help out others in the future.
  • romma1 likes this
#6 AK47sForAll
AK47sForAll
  • 50 posts
Posted 03 January 2014 - 06:03 PM
Just followed the instructions that were posted on here.
  • neckchop likes this
#7 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 02:46 PM
I have this same issue now. Tried everything in this post. I keep getting "Failed flashing process. 1/20 flash partition "gpt_main0.bin" -> Phone returned Fail". Any help will be appreciated. Thanks.
stuck on the fastboot screen
failed to load GPT
CID Read Failure
Invalid CID status 0x69
No SP partition found
Fastboot Reason: Invalid GPT
usb connected
#8 livinginkaos
Posted 01 February 2014 - 03:47 PM
Give this a go.
Btw, you are sure you've been trying the appropriate fxz?
Sent From My DEV X
#9 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 03:56 PM
yes. it is the FXZ_xt907. i am using version 1.2 utility. maybe this 1.3 will do the trick. thanks for replying.
your ftp site is a 6 hour download for me. Yikes!
#10 livinginkaos
Posted 01 February 2014 - 03:57 PM
This utility is specifically to address the gpt issue. BUT most often the gpt fail is because people are trying to flash an fxz older than what they are currently on. Sent From My DEV X
#11 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 04:09 PM
well i was running several different rom's. the last one i was running was beanstalk on 4.4. I was running into several different issues, so i decided to go back to stock. I know this was my fault because i didn't flash the recovery before i accepted the ota update to the current version. I am sure this caused my issue. i just hope i can bring this back to life.
#12 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 04:14 PM
hopefully this helps.
02/01/14 19:31:57  --------------------------------------------------------------------------------
02/01/14 19:31:57  New Log Started For Software Download.
02/01/14 19:31:57  The FlashLog key is turned off.
02/01/14 19:32:00  000004c0 Phone.cpp 531 0 ERROR Generic failure when sending command.
02/01/14 19:32:00  000004c0 Phone.cpp 1778 0 ERROR GetTechnology failed: ERROR.
02/01/14 19:32:00  000004c0 Phone.cpp 1847 0 ERROR GetSoftwareVersion failed: SendTC failed: ERROR.
02/01/14 19:32:00  000004c0 Phone.cpp 2005 0 ERROR GetSoftwareFlexVersion failed: ReadSeemElement failed: ERROR.
02/01/14 19:32:00  000004c0 Phone.cpp 1975 0 ERROR GetBootVerFlashMode failed: SendTC failed: ERROR.
02/01/14 19:32:00  000004c0 Phone.cpp 1894 0 ERROR GetDRMVersion failed: SendTC failed: ERROR.
02/01/14 19:32:00  Multi upgrade started for 1 phones
02/01/14 19:32:00  [Device ID: 0] 1/20 flash partition "gpt_main0.bin"
02/01/14 19:32:00  ERROR: 1/20 flash partition "gpt_main0.bin" -> Phone returned FAIL. - on device ID 0.
02/01/14 19:32:00  [Device ID: 0] 1/20 flash partition "gpt_main0.bin" -> Phone returned FAIL.
02/01/14 19:32:00  ERROR: Failed flashing process. - on device ID 0.
02/01/14 19:32:00  Multi upgrade finished.
02/01/14 19:33:10  --------------------------------------------------------------------------------
02/01/14 19:33:10  New Log Started For Software Download.
02/01/14 19:33:25  The FlashLog key is turned off.
02/01/14 19:33:26  Multi upgrade started for 1 phones
02/01/14 19:33:26  [Device ID: 0] 1/20 flash partition "gpt_main0.bin"
02/01/14 19:33:26  ERROR: 1/20 flash partition "gpt_main0.bin" -> Phone returned FAIL. - on device ID 0.
02/01/14 19:33:26  [Device ID: 0] 1/20 flash partition "gpt_main0.bin" -> Phone returned FAIL.
02/01/14 19:33:26  ERROR: Failed flashing process. - on device ID 0.
02/01/14 19:33:27  Multi upgrade finished.
#13 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 04:41 PM
i started fresh with an older sbf.......got something different
02/01/14 20:16:40  --------------------------------------------------------------------------------
02/01/14 20:16:40  New Log Started For Software Download.
02/01/14 20:16:53  000036e8 Phone.cpp 531 0 ERROR Generic failure when sending command.
02/01/14 20:16:53  000036e8 Phone.cpp 1778 0 ERROR GetTechnology failed: ERROR.
02/01/14 20:16:53  000036e8 Phone.cpp 1847 0 ERROR GetSoftwareVersion failed: SendTC failed: ERROR.
02/01/14 20:16:53  000036e8 Phone.cpp 2005 0 ERROR GetSoftwareFlexVersion failed: ReadSeemElement failed: ERROR.
02/01/14 20:16:53  000036e8 Phone.cpp 1975 0 ERROR GetBootVerFlashMode failed: SendTC failed: ERROR.
02/01/14 20:16:53  000036e8 Phone.cpp 1894 0 ERROR GetDRMVersion failed: SendTC failed: ERROR.
02/01/14 20:17:30  000036e8 Phone.cpp 531 0 ERROR Generic failure when sending command.
02/01/14 20:17:30  000036e8 Phone.cpp 1778 0 ERROR GetTechnology failed: ERROR.
02/01/14 20:17:30  000036e8 Phone.cpp 1847 0 ERROR GetSoftwareVersion failed: SendTC failed: ERROR.
02/01/14 20:17:30  000036e8 Phone.cpp 2005 0 ERROR GetSoftwareFlexVersion failed: ReadSeemElement failed: ERROR.
02/01/14 20:17:30  000036e8 Phone.cpp 1975 0 ERROR GetBootVerFlashMode failed: SendTC failed: ERROR.
02/01/14 20:17:30  000036e8 Phone.cpp 1894 0 ERROR GetDRMVersion failed: SendTC failed: ERROR.
02/01/14 20:17:36  The FlashLog key is turned off.
02/01/14 20:19:30  Multi upgrade started for 1 phones
02/01/14 20:19:30  ERROR: Unknown fastboot command. (getvar) - on device ID 0.
02/01/14 20:19:30  [Device ID: 0] Unknown fastboot command. (getvar)
02/01/14 20:19:30  ERROR: Failed flashing process. - on device ID 0.
02/01/14 20:19:30  Multi upgrade finished.
do you think this is the same issue?
#14 livinginkaos
Posted 01 February 2014 - 04:50 PM
Well. That One still has the getvar lines the xml. It will never work that way. Did you use the script I linked to?
Sent From My DEV X
#15 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 04:52 PM
it is still downloading it says it has 6 hours left.
#16 livinginkaos
Posted 01 February 2014 - 05:00 PM
Seriously? Are you on a slow connection?
Sent From My DEV X
#17 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 05:02 PM
no. i have a 40mb download speed. i thought it was your ftp server.
#18 livinginkaos
Posted 01 February 2014 - 05:05 PM
Oh. I'll have to check on that it is normally pretty darn fast
Sent From My DEV X
#19 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 05:06 PM
i will pause my download for now.
#20 webtrix
webtrix
  • 77 posts
Posted 01 February 2014 - 05:10 PM
whatever you did, it worked. (as far as the download) trying the fix now.
scratch that. it was corrupted. i need to try again when the server comes back online.
