Xt910 bricked/recovery partition damaged
3 replies to this topic
#1 LKS
LKS
Posted 31 December 2013 - 11:31 AM
Hello guys!
Im using my xt910 maxx with cm11 and ST 3.65, well i got the stupid idea to uninstall the ST because i guess with the cm11 installed I dont need ST any more.
The result is the mobile bricked...
Well, if I try to flash original firmware with RSD lite i got:
And, if i try to enter recovery mode i see the android dead screen with red "!".
Any ideas do fix it?
#2 LDubs
LDubs
    Pawn In Game of Life
  • 9,724 posts
  • Twitter:lew_bklyn
  • LocationBrooklyn, NY
Posted 31 December 2013 - 01:02 PM
What version of the OS were you on?  Looks like you tried to flash an older version and the security portion failed.
Do a search for House of Moto, it will fix you right up...
And for future reference, yeah you need safestrap to enable you to boot into one of your ROM slots...
  • LKS likes this
#3 LKS
LKS
Posted 31 December 2013 - 01:22 PM
Before the brick Im using Cm11 (4.4.2). Now, bricked im trying to flash the original motorola firmwares, like as: 6.7.2-180_SLC-31_LATAM_SPYDERICSRETBRLA_ServiceCFC_fastboot.xml
But i got the error flashing you see above. Any idea friend? Can i use the RDS to re-flash the CM 11??
Thanks.
#4 LDubs
LDubs
  • 9,724 posts
  • Twitter:lew_bklyn
Posted 31 December 2013 - 02:10 PM
Like I said, head over to the house of moto thread. Will fix you right up.
sent from my hammerhead
