4.4.2 Network issue
4G LTE 3G DATA Network RazrHD xt926 Verizon CDMA
15 replies to this topic
#1 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 17 December 2013 - 08:19 PM
Thanks to all the developers for there ard work. I'm loving Kit Kat!
I have been using Kit Kat on my Verizon Razr HD XT926 daily. I have been flashing CM11 nighlies and recently ran in to problem. For some reason my phone automatcally connects to 3G instead of LTE. I can go into Settings/More/Mobile Networks and It has CDMA+LTE/EvDo selected. This should be my correct network setting by default. I can go in manually and select LTE and it does work. This is a extremely annoying considering if I want to use LTE I can't recieve calls or texts... Anyone else deal with this?
I am now running 4.4.2 Carbon ROM and it is butter smooth. Everything is work well besides this wierd glitch my phone is having with the data.
Thanks for any help :) this site rocks!
#2 livinginkaos
Posted 18 December 2013 - 04:29 AM
Have you tried flashing new radios at all?
Sent From My DEV X
#3 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 December 2013 - 04:53 AM
I have not. Do I flash with twrp? Where can I find such a file? Thank you so much for your response!!
#4 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 December 2013 - 06:50 AM
I did some research and learned I am supposed to use RSD lite. Am I supposed to flash back to stock ROM and temp unroot? Just need someone to verify I understand the process before I flash my radio. Thanks
#5 cmh714
Posted 18 December 2013 - 07:04 AM
See here:
OP has the radio file and Post 2 the commands to enter by hand if you want.
#6 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 December 2013 - 07:12 AM
That's what I'm talking about! You're my hero lol
#7 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 December 2013 - 07:23 AM
Seriously thank you! I will flash later tonight and post my results!
#8 cmh714
Posted 18 December 2013 - 07:25 AM
So switch back to Stock and then flash the Radio, although really it shouldnt matter I dont think. The funny thing is after you flash, you may not see the updated baseband numbers in Custom Roms only in the Stock rom. Its rather odd....
#9 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 December 2013 - 02:59 PM
I decided to take a chance and just flash it as is with custom ROM. RSD did it's thing and then rebooted my phone. This did not fix my problem. It is exactly the same. Should I try flashing back to factory system? Is the Fastboot method more effective?
#10 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
  • Twitter:@BionicMan_69
  • LocationCookeville, TN
  • Current Device(s):Motorola Droid Razr Maxx HD, Motorola Droid Bionic, Motorola Xoom, HTC Flyer
Posted 18 December 2013 - 04:34 PM
I have the same problem on any 4.3 or 4.4 ROMs and especially any CM ROMs. Weak signal, slow data speeds. I always end up having to go back to a stock based ROM. I've already flashed the newest radio and it didn't help on any ROMs that's not stock based. Another thing always been strange is the new base band never shows on anything but stock based ROMs. Anything else the old base band shows.
#11 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 December 2013 - 04:39 PM
That's actually not the problem I am having. My signal is fine and data works great. I have solid 3G AND FAST 4G LTE. The problem is that my phone automatically goes to 3G insead of LTE but I can manually select LTE and use it. That sucks you are having those problems :(  I am so spoiled with ROMs I couldn't imagine going back to factory and I would go crazy if I wasn't rooted!
#12 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 18 December 2013 - 08:49 PM
I flashed back to stock JB 4.1.2 and then I updated my radio. It seemed like it wanted to connect to 4G lte and it showed it was very briefly and then switched to 3G. I flashed back to Carbon 4.4.2 and now I am back where I started. ...  automatically connecting to 3G instead of LTE. Lame! :(
#13 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 19 December 2013 - 05:07 AM
May be worthwhile to grab a new Sim card from Vzw...
#14 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 19 December 2013 - 07:06 AM
I was thinking about that. Thanks!
#15 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 20 December 2013 - 02:51 PM
What's up?!? I just wanted to update and let everyone know I got a new sim card today and it did fix my problem! Thanks again for the help.
  • Memnoch73 and cmh714 like this
#16 Memnoch73
  • 5,016 posts
Posted 20 December 2013 - 02:52 PM
Glad to hear it man...
  • cmh714 and Slickademo like this
Also tagged with one or more of these keywords: 4G, LTE, 3G, DATA, Network, RazrHD, xt926, Verizon, CDMA
