(Rom) (Unofficial-For Now)SlimKat xt907
#81
Posted 28 April 2014 - 03:24 PM
#82
Posted 28 April 2014 - 04:09 PM
Any news?
From what I can tell, the XT925/XT926 builds over at slimroms are still broken.
#83
Posted 29 April 2014 - 06:37 AM
Any news?
Correct. Apparently the maintainer is having personal problems. It's too bad that he refactored the gps HAL and then went MIA.
My RAZR M is relegated to alarm click duties, otherwise I would be more proactive about fixing it myself. I do check the slimrom repos regularly, so as soon as I see a fix, I'll rebuild for you guys.
#84
Posted 29 May 2014 - 02:01 PM
Hi guys,
First of all thanks so much to everyone for their hard work making these roms!
I'm trying to download the rom at the link given above, but im getting "ERROR: File path does not exist"
Is there another link available, or is the file down at the moment?
Thanks in advance for your reply.
EDIT: Nevermind, saw another link in the thread that worked XD.
Heres to hoping all goes well!
EDIT AGAIN:
Ive installed build 3.10 (the most recent one available to download on this thread) and it works fine with minimal gapps, but ive tried with the normal gapps, and after flash it stick on boot screen and never loads up. Wondering if anyone has had this problem and if they have had any headway?
Thanks again!
Last Edit I promise x.x:
Tried Wiping it a few times, and randomly started to work XD
I realised a good tell tale sign if it works is: while in the boot, have your charger/usb plugged in, if the orange charge indicator light comes on, its working
Motorola Droid RAZR M XT-907 running Kitstalk 4.4.4 ROM
#85
Posted 28 June 2014 - 06:29 AM
md5: e0dba0da0da3d01b4880f0be4ecbb5ca
Happy Saturday
Build notes:
1. GPS should be fixed (can't confirm, see #3)
2. Since slimkat has gone to a unified build for the msm8960 devices, building these for xt907 is kind of a PITA, don't expect these regularly if at all
3. I don't have an xt907 to test this on, so flash at your own risk
Make sure to download the latest gapps from slimroms.net.
You should clean flash if you are moving up from <4.4.4.
- s.dubs, T3T3droid and eclipse00 like this
#86
Posted 13 July 2014 - 09:42 PM
Just wondering... Is there any way you guys could replace the DSP Audio Interface with AC!D Audio Technology on the Razr M? I love the ROM but the sound isn't nearly as good as when I had AC!D on there. Please let me know ASAP!! Thanks!
#87
Posted 14 July 2014 - 08:53 AM
There's an official, unified build now on the Slim website. Your best bet is to ask questions in the official thread on XDA or the forum on the Slim website.
#88
Posted 14 July 2014 - 11:01 AM
Yes, I'm probably done building these as of today. There were still quite a few problems with the 3.4 kernel that warranted building the 3.0.101 based roms independently from the unified device tree, but as of slim 6.4, most of those bugs have been resolved. I'd recommend everyone update to the official 4.4.2 package (whatever method you like best) and using the msm8960 unified builds directly from slim from now on. Anyone that wants to stay on the old bootloader can use my build 6 posted above.There's an official, unified build now on the Slim website. Your best bet is to ask questions in the official thread on XDA or the forum on the Slim website.
Cheers
- RikRong likes this
#89
Posted 15 July 2014 - 05:46 AM
so will the official unified build work on the 3.4 kernal? Im currently running one of the july cm nightlies but id prefer something stable. Do i just wipe cache and flash?...or would i have to wipe data as well. Thanks!
#90
Posted 15 July 2014 - 06:24 AM
Yes the latest slimkat weeklies are 3.4. I would definitely do a clean flash if you are coming from cm.so will the official unified build work on the 3.4 kernal? Im currently running one of the july cm nightlies but id prefer something stable. Do i just wipe cache and flash?...or would i have to wipe data as well. Thanks!
#91
Posted 15 July 2014 - 09:37 AM
There's a stable release on their website, but I think it's still the older kernel.
