(Rom) (Unofficial-For Now)SlimKat xt907
#21
Posted 31 December 2013 - 10:24 AM
#22
Posted 31 December 2013 - 12:58 PM
Trying this rom again now beta 2 is out. Having two problems though: 1. Icons way to small for my aging eyes and 2. 3D Weather widget is all bunched together. I have used this widget for couple years now and this is first rom I have had a problem with.
#23
Posted 31 December 2013 - 04:33 PM
Beta 2 cleared up the lagging problems I was having with swype. Glad the dark mode has been ported. Still having adaptive brightness problems on resume from sleep occasionally. It will get stuck on the darkest setting and not get any brighter until I turn the screen on and off.
I haven't flashed the 4.4 version yet, but if it's like the others just change the lcd density in settings. It's a 5 or 6 step process that is explained by the device along the way. Because it's a port some things will be a bit off.
#24
Posted 31 December 2013 - 04:34 PM
beta 2 released
Thanks for your work on this!
#25
Posted 31 December 2013 - 08:15 PM
After flashing this I soon realized I was wrong about changing LCD density through settings as was available on previous versions. Still in Beta so probably just not added in yet. I tried several different things, including 3 apps I trust and all caused brick or bootloop to find a solution. Here are 3 options to those looking for a solution:
1. Change the source code and recompile. This probably only applies to Somber, Tim and Me......Not it.....
2. If you have no computer skills and no interest in learning any you can download another launcher (like Apex) and that will give you functionality to increase Icon sie, set layout,etc. The downside is the LCD density will stiil be off in the apps, nav bar, etc.
3. This is the best option - update the build prop and reflash.
Here is a quick, easy guide:
Assuming you are on windows-
1. Make sure you have a program to handle zips - I use WInrar, but a lot of devs us 7zip which is free
2. Download Notepad ++ - trust me if you are on windows this will save you a ton of headaches
3. Double click the zip
4. Double click system
5. Double click build.prop and open with notepad ++
6. Go to line 123 and change the density to 240 (default for the device). It should look like this - "ro.sf.lcd_density=240"
7. Save file
8. Click "yes I want to update zip"
9. Reflash - theoritically there is no need to wipe data if you are just reflashing from slim, but I would recommend a complete wipe. TiBu is a lifesaver......
#26
Posted 01 January 2014 - 08:28 AM
#27
Posted 05 January 2014 - 06:58 AM
Need a little help, i get an error "set metadata_recursive: some changes failed. error (status 7) installed aborted"
I got this error for the last 2 roms I tried to install.
I wipe/factory wipe,
wipe cache
mount system
FIXED Needed to update CWM to the latest version.
Edited by techjunkie, 05 January 2014 - 08:26 AM.
#28
Posted 07 January 2014 - 11:46 AM
does anyone know how to get root back? I did a clean install and I'm running the newest cwm touch. Thanks in advance!
#29
Posted 08 January 2014 - 04:44 PM
Flash the supersu update zip after flashing slimkat and remounting /system.
#32
Posted 10 January 2014 - 08:29 PM
They have an "on the fly" dpi app coming soon. I've tested it much easier process. I'm not gonna add it though. due to respect of the slim devs
Donations Not Necessary but tia
#34
Posted 22 January 2014 - 01:08 PM
Should we be expecting any more updates on this? I really loved this ROM.
#35
Posted 22 January 2014 - 06:14 PM
#37
Posted 24 January 2014 - 11:26 AM
You the best!
#38
Posted 05 February 2014 - 03:16 PM
somber did me a big favor by making an xt907 platform specific manifest available on github. SlimKat 2.6 RC2 is working great on my razr m and the devs have apparently ironed out the bugs that were affecting the moto family the last few releases. I don't want to hijack his thread with my personal build, but I thought I would share my experience on the newest weekly.
Edit: Alright he gave me the go ahead to share.
And don't forget to update your gapps:
- somber73 likes this
#40
Posted 06 February 2014 - 11:59 PM
