So a while back I brick my m and long story short I can't charge it and the factory cable dose not work either so I'm assuming the charging port it screwed so what I want to do is open it up and directly charge the battery. I've see a few threads on this but non specifically for the m. Anyone done this?
Directly force charging the battery
Posted 16 December 2013 - 03:56 AM
Posted 16 December 2013 - 04:08 AM
Posted 16 December 2013 - 06:57 AM
If irreversible damage happens, post pics. Haha, in all honesty, I'm interested to see how this goes. Post results when you get them.
- johnthehillbilly likes this
Posted 16 December 2013 - 08:03 AM
Never done with this before on any phone so proper terminal is exact what I'm concerned about. And irreversible Is irrelevant since it has been a paper weight for a few months already. I just got a tool kit for another project so i I will be doing the tear down tonight, I'll be sure to take a sh!t ton of pics
Posted 16 December 2013 - 08:23 AM
OK so I may be sunk before I sail on the one. I just watched a guide video of this on the of razr and as john said it is a clearly marked terminal. Then a watched a tear down on the m. It didnt give the same close up view but it looked a lot more like ribbon cable coming straight from the batter to a special plug on the main board. so nowhere to wrap a wire around. I'll do the teardown myself when I get home and report back.
update:
oh so i got the screen off, so far it looks like i was right about the ribbon cable syle battery hook up, but i havent gotten it out yet. i found what looks like corrosion around the usb port. see pics, some weird blue crap. this phone did get wet but that was long before the brick. what do you guys think should i try to clean it and reassemble or keep pulling the battery
- RikRong likes this
Posted 16 December 2013 - 04:24 PM
ok so this is what ive got on the battery.... im gonna peel back the black covering to see what i can find
Posted 16 December 2013 - 04:32 PM
Posted 16 December 2013 - 06:08 PM
I decided to go the hard way. I have a feeling cleaning wouldnt be enough
Posted 16 December 2013 - 06:19 PM
So what you see above is the batter with the black covering peeled back and a small strip circuit board exposed. The two sliver spots you see on the left and right of the black chip seem to be the positive and negative terminals as you can see in the second pic. Then I sandwiched the wires against the terminals and the plastic backing piece and taped it closed. Theoretically, its charging right now.
- johnthehillbilly, RikRong and shane1 like this
Posted 20 November 2014 - 08:49 PM
did it actually work?
Posted 22 November 2014 - 07:42 AM
Turbo Driven Comment
