Hi guys!
Is it real to make any stock based miui rom?
I only can found this
I try to PM to the developer, but no answer.
I really like miui, but my xt926 have locked bootloader and it's really problem to me.
Posted 12 December 2013 - 10:23 AM
Hi guys!
Posted 12 December 2013 - 10:53 AM
Tquetski is a Dev here as well. See his MIUI thread in the ROM forum for xt926 and ask there, you may have better luck.
Posted 13 December 2013 - 03:15 PM
Hi, I haven't abandoned PatchRom stock but I don't work on it religiously, It's very possible to make a Stock MIUI that works on a locked-bootloader phone, BalcanGSM has done it however it takes many months of work.
My methodology and skillset are not where Balcans are, and though unfortunate It's highly unlikely I'd be able to finish it for a locked-bootloader without help; I wasn't even aware it was possible until speaking w/ him.
The biggest problem is that AOSP is better than stock at the 'later release cycles' and MiCode likes AOSP. It does not like Stock and tries to apply MIUI components to files that pretty much don't exist; when creating a workspace with our stock rom you notice right away for example that because we don't have a framework2.jar there is an immediate issue and this really sets the pace for a lot of the stuff that happens trying to use Xiaomi's official stuff.
A lot of people don't even finish a release with PatchRom but use it to build a booting FullOTA and manually fix the errors later.
I'm at that point. I do have a FullOTA (Stock MIUI PatchROM) that will boot with errors and it does need to be fixed manually, fixing it manually isn't so much the issue although I would love help for time reasons. The issue is the fact that it only boots because I made proper edits to BOOTCLASSPATH and added Shelld service, I'm not sure how to do these two essential operations without changing the roms framework structure and ramdisk so..
Posted 13 December 2013 - 09:30 PM
thank you for your answer.
Unfortunately, I don't even have basical skills at rom porting. I can only test it on my locked razr hd.
