[ROM] [4.4] Aviator Gummy 2.1 [01/21/14] Come and get some KitKat!
4.4 KitKat ROM Gummy XT912 RAZR
533 replies to this topic
#1 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 09 December 2013 - 10:24 AM
(Aviator Gummy 2.1 Current Version: 20140121)
Hi all,
Fly higher with Aviator! Please do not post this anywhere else without prior permission.
Gummy ROM is made for speed, stability and to stay as closely in line with AOSP as possible. It gives you all of the features you love and it isn’t slowed down by features you’ll never use. Aviator Gummy mixes the Aviator tweaks you love with this Android 4.4 base.
Github-
Other Aviator Versions:
Click on icon to got to that Aviator Version OP.
I am not responsible for anything that may happen to your device. (... nothing should happen)
Click to
  • Deodexed.
  • Zipaligned.
  • 4.4 System.
  • Init.d tweaks - Battery and Performance based.
  • ADBD.
  • 1% battery.
  • Reboot in power menu.
  • Titanium Backup (Can be uninstalled, not a system app).
  • Battery Calibration (Can be uninstalled, not a system app).
  • Performance Control (Baked into settings. I.E. go into settings).
  • CPU Sleeper (Baked into settings. I.E. go into settings).
  • OTA Updater (Baked into settings. I.E. go into settings).
  • Beats Audio (Baked into settings. I.E. go into settings).
  • Superuser.
  • Apollo Music Player.
  • GPS tweaks.
  • Build.prop tweaks.
  • Ad blocker - via modified /system/etc/hosts file.
  • Inverted Calender.
  • Custom theme, Wallpaper, boot animation, 3G/4G icons, and semi-transparency.
STS-Dev-Team , dhacker29 and Gummy - Source.
Dhacker29 - He made this build possible and brought gummy to our devices.
Previously thanked people in Aviator Blur OP.
If I have forgotten anyone, PLEASE PM me.
  1. Transfer ROM and gapps zip files to SD card.
  2. Reboot into SafeStrap (3.07, 3.11, or 3.6x).
  3. Delete ROM slot.
  4. Recommended: Boot into stock system and attain a GPS fix in Maps. Then reboot back into Safestrap.
  5. Create ROM slot.
  6. Install Aviator ROM file.
  7. Flash gapps on top of ROM.
  8. Reboot after installation.
  9. Setup phone.
  10. Finish phone setup.
  11. Let phone settle for 5-10 minutes.
  12. Go into Settings>CPU Sleeper. Check "Enable auto-start on reboot" (First Line), then "Start Service" (Second Line) (Press twice).
  13. Charge to 100% for battery calibration or use battery calibration app.
  14. If you want the 1% Aviator battery icon which is in the screenshots, go to settings>system>statusbar>Battery status style and select "Icon."
  15. Enjoy!
Don't forget to read the "Bugs" list for bug fixes.
AVIATOR GUMMY 2.1:
Download the latest build here:
(If you don't like the smaller resolution, see post 2)
4.4 GAPPS DOWNLOADS:
Stock GAPPS 20131208:
Stock GAPPS 20131206:
WALLPAPER:
4.4:
SEE POST 3 FOR EXTRAS!
Updates:
Aviator has it's own OTA updates via OTA Updater:
When an Aviator CM update is available, you will get a notification. You will then download the update using the app. Once downloaded, you will have to manually reboot into safe strap. The download location is sdcard/OTA-updater/Download/[filename].zip
Bugs:
This is still a nightly build. There will be bugs out there. Please report them as they arise.
Possible External SD Card issues.
Want to show your Aviator Support with a custom Aviator signature image?
Instructions:
Edit your droidrzr.com profile and go to the signature option.
Copy and paste this text:
Save and enjoy!
Kanging Policy:
Please feel free to use anything here for your personal, or public use. If you do use something from this thread, all I ask to to be given credit where it is due. You do not need to ask for written permission unless it is otherwise stated as part of a forum's kanging policy.
Don't forget to "Like" -->
Or if you want to Donate, click on signature image. Thanks!
  • Baby Duck, MrFrankRazr, mugsy77 and 13 others like this
Donate? Click on signature :)
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 December 2013 - 10:25 AM
Changing Screen Resolution (DPI):
Want to change the screen resolution back to the regular resolution?
  1. Use a file explorer to edit system/build.prop.
  2. Search for ro.sf.lcd_density.
  3. Change the value to 240.
  4. Save file and reboot.
#3 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Aviator Boot Logo: BLUR, AOKP, CM10.1 and CM11.
Anyone want an Aviator splash screen?
this:
and follow the instructions here:
Splash image example:
Safestrap Splash Screen: BLUR, AOKP and CM10.1.
Instructions:
  • Save the above images as "background-safe.png" and "background-nonsafe.png". Make sure they are 540x960.
  • Save to ext SD card.
  • Reboot into Stock ROM.
  • Use a root explorer (ES File Explorer, etc) and navigate to the pictures. MAKE SURE YOU HAVE R/W PERMISSIONS (Menu>root explorer>mount R/W).
  • Press and hold on the pictures, and copy the pictures.
  • Navigate to /system/etc/safestrap/res.
  • Paste and overwrite the existing files (Make a copy of the originals if you wish).
  • Reboot and profit!
Custom Aviator Widgets: BLUR, AOKP and CM10.1.
These were made in UCCW. Please download UCCW from the play store in order to use these files:
Instructions:
  • Download:
  • Unzip to get 2 .uzip files (weather and stat widgets)
  • Move .uzip files to /sdcard/UltimateCustonClockWidget/
  • Create widget by long pressing on screen, select Widgets, then UCCW. Choose 2x2 size.
  • Press menu, "Open uzip"
  • Navigate to /sdcard/UltimateCustonClockWidget/ and select the appropriate .uzip
  • Enjoy!
  • trekkin1707 likes this
#4 rnh
rnh
  • 294 posts
  • LocationA Ct Yankee living in the land of Mass-oles
  • Current Device(s):Razr,
Posted 09 December 2013 - 10:56 AM
Hi ZKK. I have stuck with your blur rom since I consider it the best overall. I don't like the degradation in signal that nonblur roms have. Is that fixed in kit kat?
  • tyscheff likes this
#5 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 December 2013 - 11:05 AM
It's getting better, but it's not quite the same as blur yet. These 4.4 builds have better 4G signal, so I would recommend trying this Gummy or CM11 if you are predominately in a 4G area.
#6 rnh
rnh
  • 294 posts
Posted 09 December 2013 - 11:07 AM
Does it have 3g? We have a big 4G 3g mix
#7 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 December 2013 - 11:15 AM
Yes:
#8 rnh
rnh
  • 294 posts
Posted 09 December 2013 - 11:42 AM
Thanks for your responses. Haven't flashed anything since 309 came out. It's in my stock slot and it's all I use. Lost the crackflasher addiction after it. I rooted and set up my friend's LG G2 for him a few weeks ago. Man that thing is fast with great battery but I still prefer the razr.
#9 jrr10
jrr10
  • Validating
  • 7 posts
Posted 09 December 2013 - 02:57 PM
This looks really great! Nice to see 3g working. Have been running Aviator Blur for forever. Might have to try this though. Is MMS working?
#10 rnh
rnh
  • 294 posts
Posted 09 December 2013 - 03:03 PM
Just installed an hr ago. It has int storage recognition problems and immediately wiped out my ext storage pics and music torrents. Beware before using. Fortunately I backup my SD card
#11 rnh
rnh
  • 294 posts
Posted 09 December 2013 - 03:12 PM
Battery life is comparable if not better than blur and 4G signal is really good
#12 ddmclw
ddmclw
  • 10 posts
Posted 09 December 2013 - 03:25 PM
MMS works for me! Loving this more then any 4.4 ROM that's out. Thanks for this great ROM.
#13 rnh
rnh
  • 294 posts
Posted 09 December 2013 - 03:28 PM
Are you finding problems with ext card recognition? I also noticed camera is only set to download to int storage.
#14 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 December 2013 - 04:14 PM
I had SD issues once, but I haven't had it since. All that happened to me was that the SD Ext wasn't visible when I plugged my phone into my computer. No wiping of data or anything. But just beware and make a backup of the important stuff! :)
#15 bradg24
bradg24
  • 36 posts
Posted 09 December 2013 - 04:16 PM
What about the wireless tether? Does it work since it don't in the other kk builds?
#16 rnh
rnh
  • 294 posts
SD problems seem to persist. I think I'll reinstall. Do you have a razr ZK?
#17 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 December 2013 - 04:19 PM
Yep, standard RAZR. Its my only phone :p
#18 bfederspill
bfederspill
  • 284 posts
  • LocationRoy, Utah
  • Current Device(s):Razr Maxx
Posted 09 December 2013 - 04:32 PM
Don't suppose you have a nice A-10 Warthog wallpaper on hand do you? That's what I work on and it would look great on my phone with this ROM. :-)
#19 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 December 2013 - 04:43 PM
Nope, but I could do one if you give me a few days (maybe on Wednesday I'll have time).
#20 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 09 December 2013 - 05:24 PM
Dude you're killing it!! Aviator seems to be the go to rom for the OG guys and you're always pushing forward with a newer version. I just hope those jet engines don't melt all those kit-kat bars!!
  • rickw, ZKK007 and possnfiffer like this
Also tagged with one or more of these keywords: 4.4, KitKat, ROM, Gummy, XT912, RAZR
