CM11 for DNA
19 replies to this topic
#1 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 05 December 2013 - 12:56 PM
Yes, I know I am going backwards here, but I have been playing with porting MIUI for the last few days and I can't get past the boot animation. My next course of action was to try a 4.2.2 CM to see if it is just an incompatibility between my base and port roms, but every link I find is dead.  Does anyone by chance have a copy of CM10.1 they would like to share with me? I would really appreciate it, thanks!
And yes, I spent the last couple of hours googling for 1 and either my eyesight is going bad or I just need to step away for a bit, but I just couldn't find a working link :D
I should add that I would be happy with any base aosp 4.2.2 rom also...it doesn't have to my cm. thanks again!
Nice job on the signature, jl90...thanks!
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 05 December 2013 - 01:23 PM
Looks like these are 4.2.2
. Linked from
rom thread
#3 Memnoch73
  • 5,016 posts
Posted 05 December 2013 - 01:26 PM
Also
is 10.1 CM with working link
  • mrlolli likes this
#4 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 05 December 2013 - 01:28 PM
ok, that confirmed it...i am blind as a bat :lol: . thanks Memnoch73, i will go back in my corner now lol
  • Memnoch73 and livinginkaos like this
#5 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 06 December 2013 - 06:50 AM
well, that didnt work anyways :lol: . i ended up trying 10.1, 10.2, and even 11 with no luck. i did happen to stumble upon a way to get cm11 to install using twrp v2.5, though...just testing other things to make sure i didnt kill something else in the process
#6 Memnoch73
  • 5,016 posts
Posted 06 December 2013 - 10:01 AM
Looks like the sense 5 4.2.2 update is pushing now. Man I would like a slim down stock rom... Hint hint.  :)
  • mrlolli and Sabres032 like this
#7 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 06 December 2013 - 10:06 AM
haha, ok as soon as i get it i will start playing with it :lol:
  • Memnoch73 likes this
#8 Sabres032
Sabres032
    Large and in charge EMS minion
  • 9,515 posts
  • LocationWayward USA
  • Current Device(s):Google Pixel 2 XL
Posted 07 December 2013 - 04:16 PM
How did you get CM11 to load on TWRP 2.5? I thought a version that old would not support SELinux security codes?
Sent from my Marine World N6 or my Nexus 7 2013 WiFi I'll let you figure out which.
#9 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 07 December 2013 - 04:35 PM
I changed some stuff in the updater script for both cm11 and kk gapps. If you want to try it, i can either send you the updater scripts to stick in to cm11 and gapps or if you are uncomfortable with that or just dont want to, i can up cm11 and gapps with them already in so all you need to do is flash them.
Sent from my HTC6435LVW using Xparent BlueTapatalk 2
#10 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 08 December 2013 - 09:34 AM
I figured I would rename this thread so we stop derailing the screenshots thread. Is there any way to get our little derailing taken off of that thread and put here?
#11 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 09 December 2013 - 05:38 AM
it seems that cm11 has the same problem with the black screen during a phone call that aokp did. run this, move both sliders to 100%, check set on boot, and that problem is fixed:
#12 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 09 December 2013 - 09:32 AM
allrighty...got the 4.2.2 ota. time to start stripping down and speeding up ;) . oh yeah, i might try to make it look pretty, too. to be continued...
  • Memnoch73 and Sabres032 like this
#13 Memnoch73
  • 5,016 posts
Posted 09 December 2013 - 01:52 PM
May I suggest adding the white KK status bar icons? I hate the ugly different colored HTC stock ones.
Just punch me if I'm making too many "suggestions".  :blink:
#14 livinginkaos
Posted 09 December 2013 - 02:03 PM
He is wearing boxing gloves in his avi....
  • Memnoch73 and mrlolli like this
#15 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 09 December 2013 - 02:13 PM
Hddhhdsjsiisagafstsbsbs
#16 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 09 December 2013 - 02:16 PM
I just tried typing with my gloves on, as you see it didnt work :D.
Yeah, i can either use those icons or i will make my own, i planned on that anyways :). The more suggestions, the better, so dont be afraid...i wanna build this for you guys!
  • Sabres032 likes this
#17 Memnoch73
  • 5,016 posts
Posted 09 December 2013 - 03:20 PM
Hahahahahaha!! Funny thing is I didn't even pay attention to your avatar when I wrote that. Guess it was fitting.
I'm actually really looking forward to this. I have to run sense because my phone is basically my car stereo so I need beats working.
Trying to think of custom stuff I like or stuff I need.
-Beats
-menu key on recents button
-Exchange working (normally does on sense, iffy on AOSP)
I usually use exposed to make my status bar semi-trans as well as app drawer background and notification background. Plus center my clock
I use a custom launcher so I don't care to much about blinkfeed although others might.
Maybe black-out all the white in the settings. Not sure what that entails.
Just throwing stuff off the top of my head...
#18 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 09 December 2013 - 03:35 PM
I am gonna print out your post and use it as a checklist :D
Seriously, i am glad you took the time to do that. Being the 1st non-Moto smartphone i have ever had, i really dong know too much about what is and isn't used in sense. I had stock on my phone for an hour at the most before i was flashing aokp on it :D
#19 Memnoch73
  • 5,016 posts
Posted 09 December 2013 - 03:50 PM
Oh and add to the list to remove the persistent GPS icon in the status bar. I always forget about that since all the roms have had it killed for so long now.  :)
#20 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 09 December 2013 - 03:55 PM
......and check....... :)
