Firmware Droid Razr Xt912 Verizon Ics 4.0.4
112 replies to this topic
#21 TopSnake
TopSnake
  • 45 posts
Posted 11 July 2012 - 11:02 PM
I take it they are uploading them right now? Figured at least one would be done since the OP was almost 3 hours ago
#22 nailbomb3
nailbomb3
  • 195 posts
Posted 12 July 2012 - 02:51 AM
It's up here:
#23 Guest_R3Ds_*
Guest_R3Ds_*
Posted 12 July 2012 - 03:06 AM
It's up here:
thank you
#24 nailbomb3
nailbomb3
  • 195 posts
Posted 12 July 2012 - 03:13 AM
Win!
Just fastbooted it over my .211 sideloaded OTA leak. Looks good so far. Flashed pretty fast as well which is cool!
Used RSDlite 5.7 to flash it.
Thank you thank you thank you to whoever got ahold of this.
Honestly, I think someone at Moto is helping us out on the sly dudes.....
#25 nailbomb3
nailbomb3
  • 195 posts
Posted 12 July 2012 - 03:24 AM
Interesting. It seems to leave the SD-Internal alone.
#26 Narffran
Narffran
  • 147 posts
  • Twitter:Fran_Granfield
  • LocationNorth of Boston MA
Posted 12 July 2012 - 03:34 AM
I'll be giving this a try on my spare Razr as soon as it downloads. WIll update when completed.
Edit:
Worked like a charm. Nice to have a fastboot file again. We can now get to 'stock'. :)
Thanks for the great upload!
#27 en7gm4
en7gm4
  • 137 posts
  • Twitter:https://twitter.com/#!/en7gm4
  • LocationtEXas
Posted 12 July 2012 - 03:35 AM
so this means the ones that were stuck on 211 will be able to fast boot back to at least stock.
#28 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 12 July 2012 - 03:44 AM
Thus means you can flash back to stock 211 easier than the method that we had
#29 en7gm4
en7gm4
  • 137 posts
  • LocationtEXas
Posted 12 July 2012 - 03:49 AM
well i guess if we do the ota rootkeeper and rsd back to stock we should keep root also.
#30 nailbomb3
nailbomb3
  • 195 posts
Posted 12 July 2012 - 03:57 AM
An interesting side note. I was on the leaks, so maybe this was because of bitrot but it seems RSD'ing back has made the phone a hell of lot 'snappier'.
I did a FDR after the flash was done.
Hrmmmm :)
#31 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 12 July 2012 - 03:58 AM
Or use the available exploit after rsd
#32 nailbomb3
nailbomb3
  • 195 posts
Posted 12 July 2012 - 03:59 AM
I just rerooted with Matt's 1.7 tool. Worked fine.
#33 Narffran
Narffran
  • 147 posts
Posted 12 July 2012 - 04:01 AM
Hrmmmm :)
Agreed! I'll be doing my other phone as soon as I get a chance! There was no 1st run lag at all. It just worked! hopefully it stays that way.
  • nailbomb3 likes this
#34 nailbomb3
nailbomb3
  • 195 posts
Posted 12 July 2012 - 04:05 AM
Seems as fast as CM7 was on my D2 yeah.
#35 Torin_93
Torin_93
  • 137 posts
Posted 12 July 2012 - 04:08 AM
Ive read everything so far and im still a bit confused? How is this faster? And what is RSDLite? If anyone cares to explain that would be great. Im on a work computer and most resources are blocked.
#36 Gerland the Oracle
Gerland the Oracle
    Co-Owner and Support Specialist for Team Rage
  • 212 posts
  • Twitter:gerlandh
  • Google+:gerland.hardin@gmail.com
  • LocationJerome, Idaho
Posted 12 July 2012 - 04:19 AM
I assume this is the file you guys are placing in RSDLITE 5.7? I ask because have never used RSD B4! VRZ_XT912_6.7.2-180_DHD-16_M4-31_1FF.xml.zip
#37 HouseMD
HouseMD
    Vicodin Addict
  • 294 posts
  • Twitter:DSLRVideoGuy
  • LocationCharlotte, NC
Posted 12 July 2012 - 04:21 AM
  • Narffran likes this
If you feel the need to buy me a beer, or help pay my bills, here's the link:http://bit.ly/O4ZnLW
#38 Narffran
Narffran
  • 147 posts
Posted 12 July 2012 - 04:24 AM
A quick compare with Quadrant
Phone I've been using 2917
Fresh RSD Phone 3023
To much work to do so play time comes to an end for awhile.
#39 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 12 July 2012 - 04:30 AM
If it makes it "faster" is because it cleans up the phone wiping whatever was installed or if you softbricked it should restore your phone back to official stock ICS 4.0.4.
RSDlite is software you run on your PC to flash the firmware to your phone.
  • Torin_93 likes this
#40 jb_alphamale
jb_alphamale
  • 251 posts
Posted 12 July 2012 - 04:34 AM
Wow wow!! What do you say here? That you're able to fastboot only on the safe side? I thought fastbooting would destroy the SS partition. Maybe I didn't get correct what you said.
Win! Just fastbooted it over my .211 sideloaded OTA leak. Looks good so far. Flashed pretty fast as well which is cool! Used RSDlite 5.7 to flash it. Thank you thank you thank you to whoever got ahold of this. Honestly, I think someone at Moto is helping us out on the sly dudes.....
