Reroot?
17 replies to this topic
#1 joecracker
joecracker
  • 16 posts
Posted 04 December 2013 - 06:28 AM
Ok. so I rooted my phone for the first time a year ago. I flashed it with the stock rom 4.0.4 like I was told then installed safestrap then ICARUSHD. I loved it. Later I went with Icarus remix... Even better. as time went on I noticed some lagging so I decided to it was time to try out another rom. I like to experiment. I would like to find something solid with just a few bells and whistles( simple) that has great battery life. Should move to a JB rom? Do I have to reroot if I do? I guess what I'm asking is how do I get out of this mess and into a slick driver. I've looked all over this forum and I'm just more confused.
#2 LDubs
LDubs
    Pawn In Game of Life
  • 9,721 posts
  • Twitter:lew_bklyn
  • LocationBrooklyn, NY
Posted 04 December 2013 - 07:15 AM
You will have to get your Bionic up to stock JB (4.1.2).  You can use the House of Bionic or Voodoo OTA Rootkeeper to retain root through the upgrade.
  • joecracker likes this
#3 B.E.McAllister
B.E.McAllister
    Paint by Number Master
  • 355 posts
  • LocationUT, PA
  • Current Device(s):Bionic
Posted 04 December 2013 - 08:40 AM
If you've left your stock slot alone and not changed anything you can use voodoo root keeper on your stock slot like was mentioned, uninstall safestrap, take the over the air upgrade, use voodoo again to restore root, install safestrap again, then flash away. Sounds like your looking for a stock rom and you will have a nice selection to choose from. Sent from my DROID BIONIC using Tapatalk 2
#4 joecracker
joecracker
  • 16 posts
Posted 04 December 2013 - 09:39 AM
Thanks LDubs. And thank you B.E.M. for the walk thru. I just dont want to brick it. I had Safestrap 3.11 on it but tried to update it to 3.63 in preperation for a new rom. now its all buggered up. should I stick with 3.11?
#5 B.E.McAllister
B.E.McAllister
  • 355 posts
  • LocationUT, PA
Posted 04 December 2013 - 10:02 AM
Honestly, if it was me I'd wipe it clean with an Jelly Bean fxz, root it with Linux option, and go from there. There are a couple ways to root it and there are pages to walk through. If House of Bionic has the option to upgrade and keep root, I've never personally used it, but as long as you followed directions that might be the smartest way to go.
#6 joecracker
joecracker
  • 16 posts
Posted 04 December 2013 - 10:06 AM
Thats what I want. Wipe it clean. Start fresh. So the first step is house of bionic? Thanks. I'll start looking.
#7 LDubs
LDubs
  • 9,721 posts
  • Twitter:lew_bklyn
Posted 04 December 2013 - 04:53 PM
IIRC house of bionic had an option to protect and restore root. sent from my hammerhead
#8 SamuriHL
  • 44,416 posts
Posted 04 December 2013 - 05:03 PM
Won't help here and the House of Bionic is discontinued.  Any time you FXZ, you will lose root so protecting it won't help.  Use the House of Moto to FXZ to 4.1.2, then use easy root to root it.
  • B.E.McAllister, johnthehillbilly and joecracker like this
#9 LDubs
LDubs
  • 9,721 posts
  • Twitter:lew_bklyn
Posted 04 December 2013 - 05:41 PM
Right, what Sam said. :)
#10 joecracker
joecracker
  • 16 posts
Posted 04 December 2013 - 07:22 PM
Thank you sir. Nice to hear from the master. I've been reading up on your stuff. I sure it will go fine.
...Feeling kinda dumb but I can't find easy root.
  • SamuriHL likes this
#11 SamuriHL
  • 44,416 posts
Posted 04 December 2013 - 07:24 PM
Let me know if you run into any issues.  It should be straight forward.  Use the KEEP DATA script in the House of Moto unless you want a completely clean start, in which case you can use the FULL script.  Easy root is a linux VM that someone wrote that'll walk you through the exploit.
#12 joecracker
joecracker
  • 16 posts
Posted 05 December 2013 - 02:22 PM
I must be the worst noob ever. Looked for the easy root vm without much success. I found a video explaining how to use RSD lite to update to jelly bean. I thought I would use house of moto first then use the RSD lite? do I uninstall the safestrap first?
#13 SamuriHL
  • 44,416 posts
Posted 05 December 2013 - 02:41 PM
Uhhhhhhhhhh, wait, what?  Let's take this very slowly cause no, just no.
First:
Second:
NO.  The House of Moto has RSD built in.  You don't do anything with RSD.  That's the whole point...to make it easy to just install the House of Moto, the support file for the xt875, your FXZ, and run it.  Pick the flash mode you want (fastboot or RSD), then pick a script and flash it.
Third:
Safestrap is irrelevant when flashing an FXZ.  It'll be removed for you.  The app will still be there, but, the recovery will be removed just like root.
#14 joecracker
joecracker
  • 16 posts
Posted 05 December 2013 - 03:39 PM
First:
Second:
Third:
You rule. Sometimes I just need to be led a little. I should be all set. I'll let you know how all your hair pulling out worked for me. 8)
#15 joecracker
joecracker
  • 16 posts
Posted 05 December 2013 - 04:48 PM
I obviously did something wrong and I think I read something about this somewhere in here. It says " AdbWinApi.dll " is missing from my computer?
.... Tried other flash option seems to be working
#16 SamuriHL
  • 44,416 posts
Posted 05 December 2013 - 05:13 PM
Seems you didn't set it up right.  But as long as RSD is working, whatever.
#17 joecracker
joecracker
  • 16 posts
Posted 08 December 2013 - 05:37 AM
I chose Revelution-Unleashed. Other then it being a bit heavy on the battery I like it. Is there a better stock rom for Battery? You taught me well Obi Wan. Thanks Sam.
#18 LDubs
LDubs
  • 9,721 posts
  • Twitter:lew_bklyn
Posted 09 December 2013 - 06:58 AM
Flying Jelly, Blurry or Rage were my faves
