Validus 13 Features 2.0
Alternate default app picker;
Network stats in status bar;
Network stats custom colors;
CPU info overlay;
Screenshot quick trash;
Navigation bar customization;
Improved scrolling cache;
New power mwnu from SlimRoms;
RAM bar;
Halo;
ChangeLog
Build 2 - 29.11.13
- Ported TRDS from Beergang
- New kitkat dialer icon;
Build 1.6 - 26.11.13
- Merged android KRT16S;
- Clear recents button;
- RAM bar;
- Quick unlock control;
- Halo;
Build 1.5 - 17.11.13
- Improved scrolling cache;
https://plus.google.com/communities/109330559573276360638
http://www.drdevs.co...2.0-RC1-flo.zip
http://www.drdevs.co...1126-signed.zip
Thank U's:
CM DRDevs
Slim DroidRzr.com
ChameleonOS Cristiano Matos
AOKP
Dirty Unicorns And Many More.......
Aeries Productions
JaeKar99
Our Dedicated Community
IF YOU LIKE OUR WORK AND OR THINK SATMAN80 IS THE MOST SEXIEST MAN ALIVE FEEL FREE TO SEND ME A PM FOR THE DONATION LINK
I HOPE EVERYONE ENJOYS THE FRUITS OF OUR LABORS PLEASE GIVE FEEDBACK WE LOOK FORWARD TO IT....
HAPPY FLASHING MY LITTLE ROM JUNKIES
