{ROM} GZR Presents Validus13 4.4 {CM Based}
No replies to this topic
#1 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 01 December 2013 - 11:04 AM
Validus 13 Features 2.0
Alternate default app picker;
Network stats in status bar;
Network stats custom colors;
CPU info overlay;
Screenshot quick trash;
Navigation bar customization;
Improved scrolling cache;
New power mwnu from SlimRoms;
RAM bar;
Halo;
ChangeLog
Build 2 - 29.11.13
- Ported TRDS from Beergang
- New kitkat dialer icon;
Build 1.6 - 26.11.13
- Merged android KRT16S;
- Clear recents button;
- RAM bar;
- Quick unlock control;
- Halo;
Build 1.5 - 17.11.13
- Improved scrolling cache;
https://plus.google.com/communities/109330559573276360638
http://www.drdevs.co...0-RC1-d2att.zip
http://www.drdevs.co...1126-signed.zip
Thank U's:
CM                                         DRDevs
Slim                                        DroidRzr.com
ChameleonOS                        Cristiano Matos
AOKP
Dirty Unicorns                         And Many More.......
Aeries Productions
JaeKar99
Google
Our Dedicated Community
IF YOU LIKE OUR WORK AND OR THINK SATMAN80 IS THE MOST SEXIEST MAN ALIVE FEEL FREE TO SEND ME A PM FOR THE DONATION LINK
I HOPE EVERYONE ENJOYS THE FRUITS OF OUR LABORS PLEASE GIVE FEEDBACK WE LOOK FORWARD TO IT....  :)  :)  :)  :)  :)  :)  :)
HAPPY FLASHING MY LITTLE ROM JUNKIES
