{ROM} GZR Presents Validus13 4.4 {CM Based}
16 replies to this topic
#1 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 01 December 2013 - 09:12 AM
Validus 13 Features 2.0
Alternate default app picker;
Network stats in status bar;
Network stats custom colors;
CPU info overlay;
Screenshot quick trash;
Navigation bar customization;
Improved scrolling cache;
New power mwnu from SlimRoms;
RAM bar;
Halo;
ChangeLog
Build 2 - 29.11.13
- Ported TRDS from Beergang
- New kitkat dialer icon;
Build 1.6 - 26.11.13
- Merged android KRT16S;
- Clear recents button;
- RAM bar;
- Quick unlock control;
- Halo;
Build 1.5 - 17.11.13
- Improved scrolling cache;
Thank U's:
CM                                         DRDevs
Slim                                        DroidRzr.com
ChameleonOS                        Cristiano Matos
AOKP
Dirty
                         And Many More.......
Aeries Productions
JaeKar99
Google
Our Dedicated Community
IF YOU LIKE OUR WORK AND OR THINK SATMAN80 IS THE MOST SEXIEST MAN ALIVE FEEL FREE TO SEND ME A PM FOR THE DONATION LINK
I HOPE EVERYONE ENJOYS THE FRUITS OF OUR LABORS PLEASE GIVE FEEDBACK WE LOOK FORWARD TO IT.... :) :) :) :) :) :) :)
HAPPY FLASHING MY LITTLE ROM JUNKIES
  • Johnsgone likes this
#2 Zack
Zack
    Developer
  • 94 posts
  • LocationArkansas
  • Current Device(s):OG Razr
Posted 01 December 2013 - 10:48 AM
Sweet. Thank you
  • Rinkle McBally likes this
Why do I love jacking with my phone so much??
#3 Daino92
Daino92
  • 258 posts
  • Google+:chrisdaino@gmail.com
  • LocationFort Collins
  • Current Device(s):SCH-1535
Posted 02 December 2013 - 05:21 PM
Going to flash this later... thanks bro.
#4 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 02 December 2013 - 05:34 PM
Somber73 is the mastermind I'm just his distribution/art monkey
  • Zack likes this
#5 jamminjon82
jamminjon82
  • 610 posts
  • Twitter:@jamminjon82
  • LocationGloucester, VA
  • Current Device(s):LG G2, Moto X, Kindle Fire 2,Razr M, Nexus 7, Acer A100
Posted 03 December 2013 - 06:08 PM
Okay completely out of the loop on kit kat for gs3,any issues that are still being worked on or is this already at dd status? Thanks for all your work!
Sent from my SCH-I535 using Tapatalk
#6 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 03 December 2013 - 07:38 PM
Some have reported issues with proximity sensor( battery drain) we are working on a fix ATM and should be handled in next release
  • jamminjon82 likes this
#7 Daino92
Daino92
  • 258 posts
Posted 04 December 2013 - 10:05 AM
I've been running this all day so far and have had 0 battery drain issues. I'm about to flash a kernel though.
  • trey likes this
#8 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 04 December 2013 - 06:57 PM
That's good to hear... Is your phone out all day or in your pocket?
#9 Daino92
Daino92
  • 258 posts
Posted 05 December 2013 - 02:08 PM
For the most part it's out of my pocket. When I'm in class is when its in my pocket. But I use it moderately once I've settled on a ROM for a few weeks. Today I've used it for about a total of 3 hours. (screen time) If you want me to be more specific let me know bro or shoot me a hangouts message, I would love to help the development of this ROM
#10 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 05 December 2013 - 06:09 PM
I can invite you to the ground zero q/a it's about rom but usually turns into a free for all
#11 jcass5467
jcass5467
Posted 06 December 2013 - 06:04 AM
SD card won't mount after installing this rom. What gives is there a fix for this?
#12 Daino92
Daino92
  • 258 posts
Posted 06 December 2013 - 12:29 PM
That'd be coo
#13 jamminjon82
jamminjon82
  • 610 posts
Posted 10 December 2013 - 12:48 PM
Is there a version of twrp that can go back and forth between the versions of Android?
#14 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 11 December 2013 - 04:21 AM
Just install the newest twrp
#15 jamminjon82
jamminjon82
  • 610 posts
Posted 11 December 2013 - 04:22 AM
It only seems to allow installation of 4.4 roms, not anything else
#16 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 11 December 2013 - 04:48 PM
I had no issues installing 4.3 dirty unicorns on the newest twrp
#17 jamminjon82
jamminjon82
  • 610 posts
Posted 11 December 2013 - 05:30 PM
Thanks, I just switched to cwm touch and all is well. Good to know about twrp for when I switch back
