(ROM) GZR Presents Validus13 (4.4)(CM Based)
6 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 30 November 2013 - 12:11 PM
Validus 13 Features 2.0
Alternate default app picker;
Network stats in status bar;
Network stats custom colors;
CPU info overlay;
Screenshot quick trash;
Navigation bar customization;
Improved scrolling cache;
New power mwnu from SlimRoms;
RAM bar;
Halo;
ChangeLog
Build 2 - 29.11.13
- Ported TRDS from Beergang
- New kitkat dialer icon;
Build 1.6 - 26.11.13
- Merged android KRT16S;
- Clear recents button;
- RAM bar;
- Quick unlock control;
- Halo;
Build 1.5 - 17.11.13
- Improved scrolling cache;
Thank U's:
CM                                         DRDevs
Slim                                        DroidRzr.com
ChameleonOS                        Cristiano Matos
AOKP
Dirty
                         And Many More.......
Aeries Productions
JaeKar99
Google
Our Dedicated Community
  • NAKAMONIEL, satman80, Joseberga and 2 others like this
#2 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 02 December 2013 - 12:54 PM
Love it :) Nice work!
  • Rinkle McBally and somber73 like this
Site Rules and Guidelines
#3 TecknoFreak
TecknoFreak
  • 14 posts
Posted 03 December 2013 - 03:50 AM
Data is not working for me and it will not stick to any network speed as 4g, 3g, lte etc..
The signal bars are always on E
#4 NAKAMONIEL
NAKAMONIEL
  • 59 posts
Posted 16 December 2013 - 03:48 AM
Reporting a bug buddy, Bluetooth crashes as soon as I connect to my car. Had done clean install. See if you can get it working on next built. ROM was awesome otherwise.:rolleyes:
#5 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 16 December 2013 - 07:47 PM
3.0 is out BT seems to be working fine by word of mouth
#6 elcabo1989
elcabo1989
  • 6 posts
  • Locationguerrero
  • Current Device(s):Motorola razr hd
Posted 19 December 2013 - 12:22 AM
Help!! Fastboot device locked status:0 :(
Enviado desde mi Nexus 7 mediante Tapatalk
#7 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 18 January 2014 - 04:56 PM
4.1 is up get on it ;)
  • elcabo1989 likes this
