(ROM) GZR Presents Validus13 (4.4)(CM Based)
102 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 30 November 2013 - 12:08 PM
Validus 13 Features 2.0
Alternate default app picker;
Network stats in status bar;
Network stats custom colors;
CPU info overlay;
Screenshot quick trash;
Navigation bar customization;
Improved scrolling cache;
New power mwnu from SlimRoms;
RAM bar;
Halo;
ChangeLog
Build 2 - 29.11.13
- Ported TRDS from Beergang
- New kitkat dialer icon;
Build 1.6 - 26.11.13
- Merged android KRT16S;
- Clear recents button;
- RAM bar;
- Quick unlock control;
- Halo;
Build 1.5 - 17.11.13
- Improved scrolling cache;
Thank U's:
CM                                         DRDevs
Slim                                        DroidRzr.com
ChameleonOS                        Cristiano Matos
AOKP
Dirty
                         And Many More.......
Aeries Productions
JaeKar99
Google
Our Dedicated Community
  • Noigel, jco23, moroshek and 2 others like this
#2 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
  • Current Device(s):DROID RAZR M
Posted 30 November 2013 - 12:30 PM
And it is running so well!
#3 motoroid7
motoroid7
  • 56 posts
  • Twitter:motoroid7
  • LocationBloomington, Indiana
  • Current Device(s):RAZR M
Posted 30 November 2013 - 12:35 PM
I'm almost certain I know the answer I'm going to get, but have you been able to test MMS on this? Is it something that is still broken? I'm just curious with every new release of the 4.4 ROMs if someone managed to fix it yet. Otherwise, I assume it won't be fixed until official 4.4 drops.
Also, is cross-system emoji fixed in gzr 4.4 now?
Twitter: @motoroid7
ADN: @seven07
#4 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 30 November 2013 - 01:01 PM
Should all be working
#5 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 30 November 2013 - 04:43 PM
Anyone else getting "Association rejected" when trying to connect to wifi?
Need Help? Send me a message
#6 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 30 November 2013 - 04:57 PM
I received mms. I never send them, personally.
#7 JWACK72
JWACK72
  • 103 posts
  • LocationSC
Posted 30 November 2013 - 05:14 PM
FREAKING AWSOME!!  Everything is working on mine. BTW Is there any way to change the soft key colors?
#8 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 30 November 2013 - 06:02 PM
Yes push style in navigation menu
#9 JWACK72
JWACK72
  • 103 posts
  • LocationSC
Posted 30 November 2013 - 06:30 PM
Sweet
#10 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 01 December 2013 - 05:06 AM
Somber73 can we get an md5 with this please? want to know if my downloads are bad cause of this "Association rejected" error.
#11 TheCheeze
TheCheeze
  • 25 posts
Posted 01 December 2013 - 05:36 AM
Does this have the same amazing battery life of your CM11 build? I went 50hrs on battery with normal usage before I ended up plugging in at 25%
#12 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 01 December 2013 - 07:37 AM
I'll generate one for you today
Prolly not as great YET since 4.4 is still fairly new. Trying my best to accomidate though :)
  • nprevette420 likes this
#13 thoriii
thoriii
  • 11 posts
  • Current Device(s):Motorola Razr M
Posted 01 December 2013 - 07:54 AM
Looks really good.  Thanks for all the hard work.
#14 moroshek
moroshek
  • 62 posts
Posted 01 December 2013 - 09:24 AM
Can you guys provide a GSM fix please?
#15 JonnyJacot
JonnyJacot
  • 12 posts
  • LocationNebraska
  • Current Device(s):Electrify M
Posted 01 December 2013 - 11:11 AM
I love this ROM! Running it on my electrify M and the only thing that I can notice that didn't work is the stock keyboard. I fixed it by just downloading another keyboard through the play store using the mic. Other than that I noticed when unlocking it through the pocket unlock kinda is buggy since it wants to go back to the actual unlock screen which kind of defeats the purpose. But once again amazing rom was just what I was waiting for!
#16 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 01 December 2013 - 11:12 AM
I get it too.. ((
UPD - I got the same problem on KitKat PA 4.0  (((
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#17 Noigel
Noigel
  • 197 posts
Posted 01 December 2013 - 11:13 AM
You can use
 - it 100% works!
  • moroshek likes this
#18 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 01 December 2013 - 01:17 PM
I get it too.. ((
Ah, so I'm not the only one. Must be a hit and miss thing.
#19 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 01 December 2013 - 02:49 PM
New link to Validus-2.0-RC1-flo.zip is giving me an error when trying to install. I Think you put the wrong link? Flo would be the Nexus 7.
#20 kingsoftszw
kingsoftszw
Posted 02 December 2013 - 12:04 AM
reserved。thanks
