Help! Bionic in perpetual reboot... boot loop
droid bionic verizon boot loop restart
4 replies to this topic
#1 wub
wub
Posted 29 November 2013 - 05:51 PM
I hope my foggy memory doesn't make it impossible to help me.  About 7 months ago my Droid Bionic went into perpetual boot loop.  I can not remember doing anything to initiate the problem.  In fact, my wife and I were on our way to the zoo when I noticed the Droid boot theme for the third time in 15 minutes (the phone was randomly rebooting for several months, but only once or twice a week).
I called Verizon and after some tech support they said my phone needed to be replaced.  I didn't really buy that diagnosis since I could put the phone into that boot option screen indefinitely.  Anyway, I had an available phone upgrade at the time so I got a SIII.  I could really use this Bionic now, though, so I hope someone could help.
I know very little about the Android OS, but I will try to describe the state of the phone when the problem started.  When I first purchased the phone it had Gingerbread---5.9.902-- or something like that.  I rooted it, then eventually installed 6.7.246 ICS.  I can't really remember if I ever rooted it or not.  Anyway, since then I have tried to flash both ICS and JB via RSD (I doubt I'm using the right terminology).  No matter what I do, the phone automatically reboots itself after about 3 minutes.  If I go into the AP Fastboot or Boot Option menu it will not restart.  Any advice will be greatly appreciated.
#2 livinginkaos
Posted 29 November 2013 - 05:53 PM
It's a known hardware problem
Sent From My DEV X
#3 livinginkaos
Posted 29 November 2013 - 05:57 PM
Sorry meant to expand. They're is a known hardware problem that results in the random reboots. A less than likely problem is a battery issue. With the hardware issue the reason you don't get it in Fastboot is that the hardware in question has not been activated at that point.
Sent From My DEV X
#4 wub
wub
Posted 29 November 2013 - 06:55 PM
Well....not the answer I was hoping for, but thank you for replying.
#5 SamuriHL
  • 44,512 posts
Posted 29 November 2013 - 07:32 PM
Drop the cpu speed to 1ghz.
Also tagged with one or more of these keywords: droid, bionic, verizon, boot loop, restart
