Posted 09 July 2012 - 10:25 AM
Posted 09 July 2012 - 10:27 AM
I just installed safestrap 2.0 for my razr that currently is on the 4.0.4 root and when I try to enter recovery, I get the symbol dimmed in the background but the menu does not open up at all. When I press the power button then it reboots. Right now I've reintalled safestrap 1.09 just because it works. Any advice to get 2.0 working?
You didn't install recovery is my guess. Reinstall the app instelf then open it and install recovery
Sent From My Semi-Stock Droid RAZR Using Tapatalk 2 Beta 69
- jirmiku likes this
Posted 09 July 2012 - 10:32 AM
I have safestrap open and it says it is installed and that safe system is active, still haven't gotten it working unfortunately.
Posted 09 July 2012 - 10:35 AM
No idea then. You have busybox installed?
Posted 09 July 2012 - 11:03 AM
I have busybox installed and I'm still getting the same thing.No idea then. You have busybox installed?
Posted 12 July 2012 - 12:56 AM
w/
iKaNDee.ICS.6.16.2.14.THEME.v2.0-R3Ds, removed the bootstrap it rebooted into stock. Then i Removed the safestrap folder on the internal sd. Then I reinstalled the App, and reinstalled the SafeStrap on boot. then it booted back into safestrap recovery. But i found my self back on .211/
Posted 16 July 2012 - 11:14 PM
Sent from my Amazon Kindle Fire using Xparent Blue Tapatalk 2
Posted 16 July 2012 - 11:16 PM
Posted 17 July 2012 - 12:25 AM
Also tagged with one or more of these keywords: razr ics, 2.0, 4.0.4
