phone stuck in bootloop & RSD aborts on step 8 of 12 during flash
3 replies to this topic
#1 eoinoc
eoinoc
  • 6 posts
  • Locationireland
  • Current Device(s):moto razr I
Posted 26 November 2013 - 04:37 AM
Hi,
my phone (XT890 EU version running JB 4.1.2) is stuck at the Motorola logo when booting up. A couple of days ago,it started acting sluggish and would power itself down. It would take much longer than normal to boot up and then yesterday it got stuck on the M logo.
I have tried wiping the cache and doing a factory restore through Recover via the fastboot option,but still no success.
The bootloader is not unlocked.
I have tired flashing through RSD but with both ROMs (EU & GB) abort during the flashing process at step 8 of 12.
The error message reads:
                 Flashing process failed 8/12 flash system "sytem_signed" -> phone returned
The two JB roms i used were: CFC_9.8.2I-50_SMI-29_S7_USASMIJBRTGB.xml    and   CFC_9.8.2I-50_SMI-26_S7_USASMIJBRTEU.xml.
I also tried to flash a smaller ROM (57mb) through SD card when in Recovery mode (Blur_Version.81.5.31006.XT890.Retail.en.EU), but it craps out during install.
Will another ROM work or is it totally screwed?
#2 eoinoc
eoinoc
  • 6 posts
  • Locationireland
Posted 26 November 2013 - 05:37 AM
I did another cache wipe and factory restore and tried to flash again but RSD failed at same point again.
the phone said the following during flashing.......
fastboot reason: reboot to bootloader
fastboot: max download size: 100mb
USB connected
Downloading....
Flashing boot....
Downloading...
Flashing recovery.....
Downloading...
Flashing motobp...
Motobp image flashed
Downloading...
Fastboot command failed
#3 SamuriHL
  • 44,421 posts
Posted 26 November 2013 - 07:14 PM
Change your usb cable and/or port.
#4 eoinoc
eoinoc
  • 6 posts
  • Locationireland
Posted 28 November 2013 - 08:01 AM
i have tried different USB ports but still same error. I will try another cable but i dont think thats the problem.
The image wont transfer as the boot loader is locked :angry: . The file is bigger than 100mb i think.
