FXZ Script Generator
43 replies to this topic
#41 strasber
strasber
  • 14 posts
Posted 13 May 2014 - 04:37 AM
Java's being a *******.  When I compiled it I told it to set the version to Java 7.  If it's telling you that it's an unsupported version then it did not honor my request and is requiring java 8.  I can fix it but it'll take a while as I'm working right now.  Either wait or install Java 8.
bingo. thats exactly what i found with the error code. compiled with jdk 8. ill install 8 and see what happens for QA's sake
#42 SamuriHL
  • 44,535 posts
Posted 13 May 2014 - 04:40 AM
I uploaded a new version that in theory may run under 1.7.  Just grab it from the link in the OP and see what happens.  I don't have 1.7 installed so I can't test if it works now.
#43 strasber
strasber
  • 14 posts
Posted 13 May 2014 - 04:45 AM
yea, this one's good. thanks.
if anyone is reading this in the future, if the jar downloads as 'FXZ-ScriptGenerator.jar.zip' just rename and remove the '.zip' all is ok
  • SamuriHL likes this
#44 SamuriHL
  • 44,535 posts
Posted 13 May 2014 - 05:06 AM
I don't know why java was being idiotic on that one, but, I forced the issue.  Any new version will be 1.7 or higher.
  • johnlgalt likes this
