Cm 11 test by Dhacker
34 replies to this topic
#1 braum
braum
  • 21 posts
  • Current Device(s):Bionic, rzr max, infinity pad
Posted 21 November 2013 - 01:15 PM
Everthing seems to be working ...install rom.. boot.. setup... reboot flash gapps
Sent from my XT875 using Tapatalk 4
#2 marleyinoc
marleyinoc
  • 557 posts
  • Twitter:marleyinoc
  • Google+:+RicCrockett
  • Current Device(s):LG G2 and Bionic on WiFi
Posted 21 November 2013 - 03:37 PM
+1. They released a gummy ROM for LG G2 too. Dhacker and Hashcode are devs on there too. And BK. Some issues but wow these guys are tireless.
Sent from my VS980 4G using Tapatalk
  • braum likes this
__________________sent from my bionic with dub_________________
#3 d73t
d73t
  • 32 posts
Posted 22 November 2013 - 06:49 AM
what gapps are you using? NM....I just can't read lol
#4 d73t
d73t
  • 32 posts
Posted 22 November 2013 - 08:52 AM
you gotta be kidding me! this runs almost flawlessly. way better than the far more developed 4.3 roms i ran. I am beyond impressed. and to top it off, jbx will have a 4.4 kernel soon.
  • braum likes this
#5 braum
braum
  • 21 posts
Posted 22 November 2013 - 10:51 AM
Dhacker did a great job.... today's build will not take screenshots. Still has same gfx glitches as yesterdays
Sent from my ASUS Transformer Pad TF700T using Tapatalk 4
#6 d73t
d73t
  • 32 posts
Posted 25 November 2013 - 02:50 PM
11/25 build fails on flash for me. anyone else get it to work?
#7 bpambrose
bpambrose
  • 35 posts
  • Current Device(s):Bionic, TFT700
Posted 26 November 2013 - 08:24 AM
#8 kc69
kc69
    Droid Elite
  • 1,057 posts
  • Google+:kcmj6969@gmail.com
  • LocationEast Bernard TEXAS
  • Current Device(s):RAZR HD
Posted 26 November 2013 - 09:03 AM
Can we move this to ROMs?. Its almost a DD for me.
TEXAS state of mind
#9 bpambrose
bpambrose
  • 35 posts
Posted 26 November 2013 - 09:43 AM
Up an running!! CM11 OH YEAH. Keeping my Bionic relevant> Many Thanks
#10 d73t
d73t
  • 32 posts
Posted 26 November 2013 - 11:54 PM
I'm assuming ART has to be setup for the OMAPs, that's why its not there?
Also has anyone found a launcher that incorporates the Google now functions, but that doesn't suck at every other aspect of a launcher like GEL? I love nova but I also love that Google now page...undecided lol
#11 csantarcangelo
csantarcangelo
  • 159 posts
Posted 27 November 2013 - 04:18 AM
Art is there. It's in Settings ––> Developer Options.
If you don't see Developer Options then you need to go to Settings ––> About Phone and tap Build Number 7 times to unlock them.
Just having fun with Android!
#12 bpambrose
bpambrose
  • 35 posts
Posted 27 November 2013 - 07:03 AM
CM 11 running great a few incompatible apps( to be expected) otherwise running great. Very happy and impressed will probably rides this out until I retire my bionic which might be a while now.
  • B.E.McAllister and d73t like this
#13 d73t
d73t
  • 32 posts
Posted 27 November 2013 - 01:53 PM
Art is there. It's in Settings ––> Developer Options. If you don't see Developer Options then you need to go to Settings ––> About Phone and tap Build Number 7 times to unlock them. Sent from my XT875 using Tapatalk
DO'H!! I forgot about that lol. Also I agree, this is very daily driveable. I plan on running this for a while, not going back to 4.3.
#14 bpambrose
bpambrose
  • 35 posts
Posted 28 November 2013 - 01:23 PM
Speechless like having a new phone!!!!
  • braum likes this
#15 bpambrose
bpambrose
  • 35 posts
Posted 29 November 2013 - 06:54 AM
Just discovered I have no GPS, has anybody else have seen or have this problem? Hoping I can fix it I use my GPS often.
Disregard appears to be working, navigation is working now.
#16 funtyes0970
funtyes0970
  • 11 posts
  • LocationNew York
  • Current Device(s):Razor maxx
Posted 30 November 2013 - 04:14 PM
Seem like data connection 4G not stable sometimes I have 3 bars cell phone service but no data connection
#17 funtyes0970
funtyes0970
  • 11 posts
  • LocationNew York
Posted 01 December 2013 - 07:28 AM
Is anyone else getting 3g with this rom I'm only getting 4GLTE if I don't have 4GLTE no data connection
  • Oblivious1 likes this
#18 bpambrose
bpambrose
  • 35 posts
Posted 05 December 2013 - 02:43 AM
Love CM11 was running it my daily everything worked fine except GPS. Downloaded and flashed Rom again same issue, checked stock side of phone  GPS ok. Flashed Gummy version GPS great but no Bluetooth. Will go back to CM11 version again and hope GPS works because  I like to have my Bluetooth( that's right I want it all). Any suggestion everything I read says GPS works on CM11 just not for me go figure.
#19 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
  • Current Device(s):droid razr
Posted 05 December 2013 - 04:28 AM
If you would like to try this gps.conf here is a link.. Do you know how to install this? And set permissions? Also a great app you can use with this is gps fix from Play Store.
XT912 RaZR SpYdEr CDMA
hit ThAnKs if I was helpful!!!
  • bpambrose likes this
#20 bpambrose
bpambrose
  • 35 posts
Posted 05 December 2013 - 04:58 AM
Thanks! I'll give a try
