Miscellaneous stuff
20 replies to this topic
#1 jayrod
jayrod
  • 6,525 posts
  • LocationWilmington NC
  • Current Device(s):Taimen
Posted 21 November 2013 - 08:42 AM
I recently decided to try and do some boot animations for Carbon.These are somewhat basic compared to professional ones like CM, but I'm still learning. Below you will see the .gif of the animation...and they are close to what the actual animation is. Install is pretty straight forward. Simply move the bootanimation.zip into system/media using a file explorer. Remember to change mount to R/W set permissions rw-r--r--. I am going to try and do some for other ROMs eventually.
All of these WILL WORK on smaller resolutions (Bionic/RAZR,etc) but were made for my S4 resolution so if you are running a smaller screen they will look slightly different.
Lightning_BA
Fire_BA
Fire_2_BA
Blue_fire
Leather_full
Leather_Cutout
Chromefire_RED
Chromefire_BLUE
Flames
#2 jayrod
jayrod
  • 6,525 posts
Posted 23 November 2013 - 07:46 AM
Attached File  BSC_Vol1.png   1.65MB   50 downloads
I've finally gotten around to finishing enough icons to share them.I'm not a pro like Tha Phlash, so be gentle with the critique. The .zip contains 100 icons for use on launchers such as Nova ( The only one I tested). Only around 60 are apps I use so I just picked some others that many might use.
The majority of icons were built off of 2 different templates created by Dave Pfaff (Pfaffinator) over on XDA. There are many that I either grabbed from Google or made myself. I have been working on these for a while,trying to get a specific look.
Jayrod_BSC_VOL1
  • B.E.McAllister likes this
#3 jayrod
jayrod
  • 6,525 posts
Mine
#4 jayrod
jayrod
  • 6,525 posts
Just in case
#5 jayrod
jayrod
  • 6,525 posts
Posted 26 November 2013 - 01:31 PM
Added my very first set of icons.
Sent from my Platyraptor extreme ultra maxxxx 4gLTE/GSM/ABC/123 Nick Knack Pattywack Ermegherd GED, MD,RNA,DNA,YMCA Edition S4! Via the 4th dimension....NOW RUNNING CARBON
#6 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 26 November 2013 - 05:57 PM
Nice work man! Really liking those icons.
  • jayrod and livinginkaos like this
#7 jayrod
jayrod
  • 6,525 posts
Posted 29 November 2013 - 11:36 AM
Attached File  Blue_Red_BSC.png   840.15KB   33 downloads
Red set: http://teamlitespeed...CS_VOL1_RED.zip
Blue set: http://teamlitespeed...S_VOL1_Blue.zip
  • kdivine981 likes this
#8 mjs27541
mjs27541
    I have no idea what's going on...
  • News Writer
  • 1,276 posts
  • LocationSouthern MD
  • Current Device(s):LG G2
Posted 29 November 2013 - 09:36 PM
BSC icons look great! Not running the theme at the moment, but they look awesome with the gunmetal cobalt theme.
#9 mjs27541
mjs27541
  • News Writer
  • 1,276 posts
Posted 29 November 2013 - 09:38 PM
Here's a screeny Attached File  uploadfromtaptalk1385792194760.jpg   56.8KB   31 downloads
  • jayrod likes this
#10 jayrod
jayrod
  • 6,525 posts
Posted 30 November 2013 - 07:25 AM
I can see a few that I need to make. I originally made ones that I use..and a few others that are "popular". If there are some that anyone wants,just leave a list here and I'll see what I can do.
#11 mjs27541
mjs27541
  • News Writer
  • 1,276 posts
Posted 30 November 2013 - 09:45 AM
Nah you've been keeping plenty busy lately.
#12 jayrod
jayrod
  • 6,525 posts
Posted 14 December 2013 - 07:45 AM
Attached File  JR_Chrome.png   1.15MB   38 downloads
Here is my first actual Zooper widget. I wanted to make sure it worked for others before I released it. It's not perfect! This is also my first attempt at making a Zooper skin apk..and it worked for all who I asked to test. This is a clock,battery widget with custom icons as well as a music widget.  There are 2 files to choose from.
An .apk
or
A zw template with the zwapk
1 hold down on home screen pick widgets/Zooper widget pro/Zooper widget 6x2
2 hold down on widget and resize ( I made it large just in case of screen ) then tap it
3 choose JR_Chrome
***In order to get the music widget to work you will also need to have Media Utilities installed and setup for Zooper.
I have only tried this widget on Nova and with Play music.**
**You may have to resize the actual widget and the contents to fit your screen**
**The battery icons seem to not update as fast as they should.Not sure if it is something I can fix or a limitation of Zooper. When charging the battery icon is supposed to indicate it by having a lightning bolt. Simply plug/unplug and it should adjust.****
HERE IS THE APK
https://copy.com/kTlnkP2byIez
HERE IS THE ZW TEMPLATE
https://copy.com/VgEGMN7mrFNC
#13 jayrod
jayrod
  • 6,525 posts
Posted 14 December 2013 - 12:52 PM
Attached File  JR_Scorched.png   1.52MB   28 downloads
Here is my second Zooper widget. This is a clock,battery widget with custom icons as well as a music widget.  There are 2 files to choose from.
An .apk
or
3 choose JR_Scorched
HERE IS THE APK
  • mjs27541 likes this
#14 jayrod
jayrod
  • 6,525 posts
Posted 18 January 2014 - 09:32 PM
Attached File  JR_ZW_Clock_Music_Dock1.png   748.49KB   20 downloads
Attached File  JR_ZW_Clock_Music_Dock2.png   907.93KB   19 downloads
Besides the dock icons seen in the picture,there are a few additional icons included in a .zip. Simply swap out and set them for whatever app...or use whatever icon set you want.
The clock widget has 20 images that change every 15 min. and the music one has 19 on the top frame that also change.
There are 2 image folders that have to be put in /sdcard for the background images to work. I tried to pick images that were neutral and appealing but everyone has their own taste.
Apps Needed:
Nova Launcher
Zooper Pro
Media Utilities
A file explorer or computer to unzip/move the image folders
Setup
Desktop Grid
10x8
Status Bar: off
Dock : Off
Height Margin : None
Width Margin : None
Download
https://copy.com/3AwGO8MaFqBt
#15 jayrod
jayrod
  • 6,525 posts
Posted 09 April 2014 - 02:50 PM
THIS IS JUST A ZIP FILE.. NOT AN APK
This is somewhat a test. I have not checked into an .apk setup yet but do plan on doing so. I realize this is not ideal for many but hey,it's free! Hahaha. I am open to suggestions as to apps to add,etc.
Please credit me in any screenshots as these have taken a while to get this far!
http://teamlitespeed...Chrome_VOL1.zip
  • johnlgalt, T3T3droid, mjs27541 and 1 other like this
#16 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 10 April 2014 - 07:50 AM
Very nice job, dude - well done!
#17 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 11 April 2014 - 04:56 AM
Man these are just getting better and better...... Awesome work dude..  :D
  • jayrod likes this
#18 jayrod
jayrod
  • 6,525 posts
Posted 11 April 2014 - 10:36 AM
Thanks!
Sent via Blacked out TapaTalk on my Eclipsed Dev X
#19 Sabres032
Sabres032
    Large and in charge EMS minion
  • 9,515 posts
  • LocationWayward USA
  • Current Device(s):Google Pixel 2 XL
Posted 17 April 2014 - 02:21 PM
Looking good Jay. Question on the not animation. Will it work on my DNA and if so how hard would it be to replace the Carbon with HTC? Just looking to switch things up because the CM boot animation is getting boring.
Sent from my Marine World N6 or my Nexus 7 2013 WiFi I'll let you figure out which.
#20 jayrod
jayrod
  • 6,525 posts
Posted 17 April 2014 - 05:55 PM
They *Should* work with the DNA as is. In order to replace "Carbon" with HTC..I need to know which one..and hope I still have the PSD..but I'm not sure when I would get to it.
