[ROM][AOKP]Big Blue V1.0 (11.21.13)
35 replies to this topic
#1 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 20 November 2013 - 09:34 PM
Without further ado, I give you
Big Blue
for the DNA!
AOKP 4.3.1 based
with some speed and
customizations added.
Thanks go out to:
livinginkaos- for his generosity
TheDanimal- for the great AOKP port found here:
emwno- for his init.d scripts found here:
dustinb- for letting me use parts of his sweet cobalt theme from the play store.
jp1044- for the server space
Sabres32- for being my brave tester
Here are the screens:
  606.88KB   27 downloads
Here is with light AOKP:
  528.25KB   28 downloads
Here is with dark AOKP:
  537.58KB   28 downloads
  147.72KB   27 downloads
  140.38KB   23 downloads
Featuring:
modded build.prop for speed
extra init.d modules
customized boot animation
customized icons here and there
changed system font
choose your launcher: standard, xperia, or moto with the circles widget
it is aokp...customize anything else you want :)
Known bug:
I read that bluetooth audio is buggy, but i dont use it so i couldn't verify
Install notes:
GAPPS and SU are included
I have included an app called Rezound Proximity. After you are set up, run this app, put both sliders to 100%, then check the 'set on boot' box. Otherwise, your phone calls will crash!
To get my custom battery icons, go to settings ->rom control ->battery ->battery icon style ->circlemod
Finally, the goods:
Big Blue V1.0:
Alternate boot animations(instructions and screens on page 2):
Bubbles:
Abstract:
Earth:
As always for me, suggestions and questions are always welcome! Thanks for checking it out :)
  • mike_augie, Memnoch73, livinginkaos and 3 others like this
Nice job on the signature, jl90...thanks!
#2 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
  • Twitter:@BionicMan_69
  • LocationCookeville, TN
  • Current Device(s):Motorola Droid Razr Maxx HD, Motorola Droid Bionic, Motorola Xoom, HTC Flyer
Posted 20 November 2013 - 11:41 PM
Going make me want to get a DNA... lol... looks great... :D
  • mrlolli and livinginkaos like this
#3 Sabres032
Sabres032
    Large and in charge EMS minion
  • 9,515 posts
  • LocationWayward USA
  • Current Device(s):Google Pixel 2 XL
Posted 21 November 2013 - 07:00 AM
As with mrlolli I was unable to test bluetooth audio because I don't own an ear piece or speakers. The build team hit this one out of the park for sure.
  • Memnoch73, mrlolli and livinginkaos like this
Sent from my Marine World N6 or my Nexus 7 2013 WiFi I'll let you figure out which.
#4 livinginkaos
Posted 21 November 2013 - 07:22 AM
Saweeeeet   !!!!!!
  • mrlolli and Sabres032 like this
#5 livinginkaos
Posted 21 November 2013 - 07:23 AM
Side note - We need to get you on the DrDevs build box.....
#6 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 21 November 2013 - 07:50 AM
really? wow, you just dont stop giving, do you?  :)
  • Sabres032 likes this
#7 Sabres032
Sabres032
  • 9,515 posts
Posted 21 November 2013 - 08:44 AM
I wonder if Kaos will adopt me?????
  • mrlolli likes this
#8 Sabres032
Sabres032
  • 9,515 posts
Posted 21 November 2013 - 11:26 AM
I was streaming music while driving to Lowes and I can report that switch over from 3G to 4G is flawless, didn't loose signal when I drove into the 3G area.
#9 Sabres032
Sabres032
  • 9,515 posts
Posted 22 November 2013 - 05:41 AM
Where is the menu settings to change the behavior of the capacitive buttons?
#10 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 22 November 2013 - 06:39 AM
i dont believe there are any. i will look around and see if i can find something that will allow that
#11 livinginkaos
Posted 22 November 2013 - 07:44 AM
Yeah, you gotta watch these guys. They use something like Viper and they get spoiled
  • Memnoch73 and mrlolli like this
#12 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 22 November 2013 - 07:48 AM
Haha well that gives me something to look into for this, so i am fine with it :D
Sent from my HTC6435LVW using Xparent BlueTapatalk 2
#13 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 22 November 2013 - 07:50 AM
While there is truth to Kaos' statement at a minimum a rom needs to be able to change the task switch button to a menu button (task on long press). This is one of the few large flaws in the DNA design. IMO..
#14 Sabres032
Sabres032
  • 9,515 posts
Posted 22 November 2013 - 08:18 AM
Not spoiled was just wondering if it was buried somewhere else in settings.
No real rush it was more of a question then a mod request.
#15 Sabres032
Sabres032
  • 9,515 posts
Posted 22 November 2013 - 08:31 AM
The one feature on this ROM that is the absolute bomb is the ability to read and reply to a text from the status bar and have the screen automatically turn off after pressing send. Makes it so much easier then opening the messaging app, replying to a text and manually turning the screen off. I really wish this was standard on all JB ROMs.
  • livinginkaos likes this
#16 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 22 November 2013 - 08:35 AM
What i did to get a menu button was enable the navbar in rom control, then change the center button to menu. Then i enabled the hidden navbar option and put both sliders to 50%, that way when i need a menu button i just flick up from the bottom of the screen and voila :)
#17 livinginkaos
Posted 22 November 2013 - 08:39 AM
Dude, I want this !!!! Wait, I don't have a DNA any more :(
#18 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 22 November 2013 - 10:53 AM
You wanna borrow mine? :D
#19 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 24 November 2013 - 01:24 PM
To get the recents button switched back to the menu button, download the button remapper apk found here:
then open it up. Switch key 249 to menu and leave 'state' at none. As soon as you hit apply, it goes right to my boot animation. I let it sit for about 3 minutes, then hard booted it. After you get it restarted, it should fire right up and your recents button is now the menu button. Long pressing home will get you the recent apps. You probably knew that, but i thought i would throw that in anyways :)
You probably dont need to stare at the bootanimation for 3 minutes, though. Try rebooting it shortly after you hit apply and it goes to bootanimation and see if that works.
#20 Sabres032
Sabres032
  • 9,515 posts
Posted 26 November 2013 - 04:50 PM
But, but, but..... I like the boot animation.
I'll give it a go when my rotation is over and report back. For now I'm still rocking this ROM as a daily driver without issues.
