Rooting
23 replies to this topic
#1 rnh
rnh
  • 294 posts
  • LocationA Ct Yankee living in the land of Mass-oles
  • Current Device(s):Razr,
Posted 20 November 2013 - 12:40 PM
What is the best way to root the LG G2? I've seen several methods and they all look complicated. Also can I restore my apps and data with tibu coming from another phone? Thank you.
#2 livinginkaos
Posted 20 November 2013 - 12:44 PM
Can't get much simpler than this - http://forum.xda-dev...d.php?t=2448887
  • RuMad likes this
#3 rnh
rnh
  • 294 posts
Posted 20 November 2013 - 12:49 PM
Thanks. How about my tibu question. Also, I've heard of people wiping their phone os and not being able to restore it. The razr was easy in this regard. Any thoughts?
#4 livinginkaos
Posted 20 November 2013 - 12:54 PM
You should consider doing Loki and flashing a recovery as well -
I like TWRP - http://forum.xda-dev...d.php?t=2449670
That way you can do a full backup and store it on your computer as well just for those cases.
Apps and data should be ok.
Edited by livinginkaos, 20 November 2013 - 01:05 PM.
Fixed link
#5 rnh
rnh
  • 294 posts
Posted 20 November 2013 - 12:59 PM
Thanks. That link says it's only for the international version and at+t
#6 livinginkaos
Posted 20 November 2013 - 01:05 PM
You are right, my bad
CWM VZW - http://forum.xda-dev...d.php?t=2468858
TWRP VZW - http://forum.xda-dev...d.php?t=2449670
#7 rnh
rnh
  • 294 posts
Posted 20 November 2013 - 01:16 PM
Again thanks. Which do you like better. Cwm or twrp. And I'm really only looking to improve battery life. Is there an init.d script to install or do I need to install a rom to do that. The razr was touted for that and it was good until jelly bean came along and then it became terrible and we needed roms to restore good battery life with in init.d scripts.
#8 livinginkaos
Posted 20 November 2013 - 01:26 PM
I personally like TWRP only because that is what SafeStrap was/is built from.  As for battery life, the G2 has amazing life just on stock without messing around for me.
#9 rnh
rnh
  • 294 posts
Posted 20 November 2013 - 01:31 PM
The phone is coming soon. I will try it out without rooting. Thank you for your response is you have been so kind.
#10 livinginkaos
Posted 20 November 2013 - 01:33 PM
No prob.  No sense in having all these devices if I can't provide a little info :)
  • marleyinoc, tomv5314 and TALLYWACKER like this
#11 rnh
rnh
  • 294 posts
Posted 21 November 2013 - 11:57 AM
I read the twrp thread should the loki zip be unzipped before installing.?
Sent from my VS980 4G using Tapatalk
#12 livinginkaos
Posted 21 November 2013 - 12:11 PM
" and go into the bin folder of the zip. push loki flash and the img like so:"  basically, yes.
#13 rnh
rnh
  • 294 posts
Posted 21 November 2013 - 12:14 PM
So unzip and push using what?
#14 livinginkaos
Posted 21 November 2013 - 12:16 PM
In a command prompt navigated to your ADB folder.  Use the ADB instructions .
#15 rnh
rnh
  • 294 posts
Posted 21 November 2013 - 12:31 PM
Since you've been so helpful I thought I would say that I've used SetCPU to get even better battery life without appreciably slowing down the phone using the settings. The phone has now gone from blast speed to fast speed
#16 livinginkaos
Posted 21 November 2013 - 12:33 PM
That's cool!  I am one of those that charges every night, so as long as my battery makes it all day without any issues regardless of they type of usage, I am content :)  I am sure there are others that would benefit by adjusting their speeds down a notch.
#17 rnh
rnh
  • 294 posts
Here it is
  • livinginkaos likes this
#18 rnh
rnh
  • 294 posts
Posted 21 November 2013 - 12:41 PM
Cpu settings at least straight hr of use maybe more
#19 rnh
rnh
  • 294 posts
Posted 21 November 2013 - 12:45 PM
It's fast with no hesitation at all. Of course every phone can be different
#20 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 09 January 2014 - 04:43 PM
I just rooted 4.2.2 using ioroot 17. Easiest and fastest root I've ever done :)
