[Recovery] Clockworkmod Recovery Touch 5.8.4.5
5 replies to this topic
#1 Guest_hacker812c_*
Guest_hacker812c_*
Posted 07 July 2012 - 05:07 AM
The base used in this Recovery is the Samsung Galaxy S3 CWM Touch
This recovery is compatible and fully tested with Razr ICS OTA
This recovery is compatible and fully tested with Razr XT910 and XT912
This recovery is compatible and fully tested on Droid Razr Maxx XT912
This recovery is compatible and fully tested with ICS Roms 4.0.3 and 4.0.4
The buttons and volume vol - and vol + this buttons are working perfectly
The buttons search and back on touch screen are working perfectly
The file system of this recovery is edited and tested [recovery.fstab]
For Razr XT912 i confirmed this release is running perfect, perfect install and working Posted Image
For Razr XT912 now use CWM Touch or use Safestrap 2.0
For Razr XT912 uninstall Safestrap app and remove current recovery before installing CWM Touch Recovery
For confirmation see the post of HexBug... Thanks for participate HexBug
[Razr XT912 using Safestrap]
***If currently using safestrap, must be in primary rom aka safe system prior to completing the following steps. After confirmation of being in primary location you must uninstall current safestrap recovery from safestrap app before installing CWM Touch Recovery***
[Credits] XCellPhoneSalesRep My Big Friend
[Others Credits]
Hansheck - By working hard to correct the Boot
nitroglycerine33 - At work with Bootstrap Original
JYDaddy - For the original work on Recoverys
Hacker812c - Modification of scripts / exploits internal
Hacker812c - Amendment of recovery Internal / application testing
Hexbug - Thanks for testing on Razr Verizon XT912
XCellPhoneSalesRep - Thanks for help me and tests the Recovery on XT912
ClockworkMod is considered by many the best recovery system in place for android.
ClockworkMod Touch is an advanced recovery feature that incorporates the touch screen.
This tutorial including Root, ClockworkMod Touch and CWM were tested without error on my Razr
This tutorial is fully tested by other users Razr on Brazil
With CWM you can quickly recover your rom, reinstall updates, etc ...
[Setup]
1. Make the root of the device
2. Install RazrTouch5845.apk
3. Open the application that you installed and click to install the recovery
4. Now you have the best recovery system CWM ClockworkMod
5. Click "Reboot Touch CWM" and restart the device to go into recovery
6. Click on "Backup and restore" and "backup" to create your backup android
7. Install ROM MANAGER the download is free on Google Play
7. After completely restart the phone install ROM MANAGER and install
8. Now you see the your backups on /sdcard-ext/clockworkmod/backup
9. Now you can install the new Custom roms
10. After install your new rom install again Clockworkmod Touch 5.8.4.5
Now we have CWM 5.8.4.5 Touch
This recovery is based on the latest system rom manager Posted Image clockworkmod.com
[ROOT]
[Download CWM Touch 5.8.4.5] APK
ROM MANAGER 5.0.0.7 free download on Google Play or Appbrain
[BUSYBOX PRO]
[THANKS]
If you have a little time press the THANKS, thanks.
[RESULTS]
This release does not cause brick ...
This release is based on Samsung Galaxy S3 Recovery [Clockworkmod.com]
This recovery was fully edited and tested for some users...
Compiled the apk and modified the recovery procedure...
The product is stable and tested in our Razr for some users...
The base used is the Recovery of the Samsung Galaxy S3
After testing the razr did not occur any error or failure.
Jesus is the secret of my success!
  • larrygeary likes this
#2 larrygeary
larrygeary
  • 160 posts
  • LocationNJ, USA
Posted 07 July 2012 - 05:59 AM
"Jesus is the secret of my success!"
Then you should add him to the [Credits] section. :)
Now it seems (I've been out of the loop for a while.) people are using SafeStrap for their ROMs. Is there a chance you could work on a SafeStrap Touch recovery? Having both recoveries on the same base seems like an advantage to me for work going forward.
#3 Guest_hacker812c_*
Guest_hacker812c_*
Posted 07 July 2012 - 06:15 AM
Thanks my friend, Jesus work in this realy.
i work in this satestrap touch... wait i pot...
#4 jcdelta
jcdelta
Posted 10 July 2012 - 04:55 AM
I followed the steps and I have CWM touch installed on my Droid Razr xt912 but when I go to do a backup of my current ROM I get an error message:
Error while making a backup image of /system!
I have tried doing a factory reset and starting from scratch but I get the same error. I do not want to flash a ROM until I have a good backup of my current ROM. Please help.
I have included the text recovery.log created by CWM below:
Starting recovery on Tue Jul 10 01:26:26 2012
can't open /dev/tty0: No such file or directory
framebuffer: fd 4 (540 x 960)
ClockworkMod Recovery v5.8.4.5
recovery filesystem table
0 /tmp ramdisk (null) (null) 0
1 /sdcard vfat /dev/block/mmcblk0p1 /dev/block/mmcblk0 0
2 /webtop ext3 /dev/block/mmcblk1p23 (null) 0
3 /emmc vfat /dev/block/mmcblk1p25 (null) 0
4 /pds ext3 /dev/block/mmcblk1p7 (null) 0
5 /system auto /dev/block/mmcblk1p20 (null) 0
6 /cache ext3 /dev/block/mmcblk1p21 (null) 0
7 /data ext3 /dev/block/mmcblk1p24 (null) 0
W:Unable to get recovery.fstab info for /datadata during fstab generation!
W:Unable to get recovery.fstab info for /sd-ext during fstab generation!
I:Completed outputting fstab.
I:Processing arguments.
I:Checking arguments.
I:device_recovery_start()
Command: "/sbin/recovery"
ro.secure=1
ro.allow.mock.location=0
ro.debuggable=0
ro.factorytest=0
ro.usb_mode=normal
ro.bootmode=unknown
ro.baseband=unknown
ro.carrier=unknown
ro.bootloader=0x0A74
ro.hardware=mapphone_cdma
ro.revision=0
wifi.interface=wlan0
softap.interface=wlan1
vold.post_fs_data_done=1
ro.sys.atvc_allow_netmon_usb=0
ro.sys.atvc_allow_netmon_ih=0
ro.sys.atvc_allow_res_core=0
ro.sys.atvc_allow_res_panic=0
ro.sys.atvc_allow_all_adb=0
ro.sys.atvc_allow_all_core=0
ro.sys.atvc_allow_efem=0
ro.sys.atvc_allow_simswap=0
ro.sys.atvc_allow_bp_log=0
ro.sys.atvc_allow_ap_mot_log=0
ro.sys.atvc_allow_gki_log=0
persist.sys.usb.config=mtp,adb
persist.sys.mot.encrypt.mmc=0:0
persist.radio.world_mode=true
persist.qe=qe 1/1
persist.log.aplogd.enable=0
persist.sys.strictmode.visual=
persist.radio.interroaming=false
persist.sys.mot.encrypt.device=0:0:0:0:0:2:0
persist.sys.keyboard_layout=us_basic
persist.bandwidth.enable=1
persist.sys.timezone=America/New_York
persist.sys.texturesize.max=2048
persist.sys.profiler_ms=0
ro.FOREGROUND_APP_MEM=2464
ro.VISIBLE_APP_MEM=3712
ro.PERCEPTIBLE_APP_MEM=5632
ro.HEAVY_WEIGHT_APP_MEM=5632
ro.SECONDARY_SERVER_MEM=7392
ro.BACKUP_APP_MEM=7392
ro.HOME_APP_MEM=7392
ro.HIDDEN_APP_MEM=10752
ro.EMPTY_APP_MEM=14336
ro.blan.interface=usb0
net.tcp.buffersize.default=131072,262144,524288,4096,16384,131072
net.change=net.tcp.buffersize.4ghotspot
net.tcp.buffersize.wifi=131072,262144,524288,4096,16384,131072
net.tcp.buffersize.lte=524288,1048576,2097152,262144,524288,1048576
net.tcp.buffersize.umts=131072,262144,524288,4096,16384,131072
net.tcp.buffersize.hspa=4094,87380,262144,4096,16384,262144
net.tcp.buffersize.edge=16384,32768,65536,4096,16384,32768
net.tcp.buffersize.gprs=4096,8192,12288,4096,8192,12288
system_init.startsurfaceflinger=0
init.svc.qe=stopped
sys.SystemMode=RM_SM_MOBILE
sys.FbOwner=3
sys.DispOwnerLcd=3
sys.DispOwnerHdmi=7
sys.AiwFocus=3
sys.AMActiveTask=2
ro.net.dns_cache_size=400
ro.3lm.production=1
net.tcp.buffersize.cdma=4096,12288,24576,4096,12288,24576
net.tcp.buffersize.evdo=16384,32768,65536,4096,16384,51200
net.tcp.buffersize.2ghotspot=4096,12288,24576,4096,12288,24576
net.tcp.buffersize.3ghotspot=4096,16384,51200,16384,32768,65536
net.tcp.buffersize.4ghotspot=262144,524288,1048576,524288,1048576,2097152
init.svc.aplogd=stopped
init.svc.adbd=running
sys.usb.state=mtp,adb
I:Checking for extendedcommand...
I:Running extendedcommand...
Waiting for SD Card to mount (20s)
SD Card mounted...
Verifying SD Card marker...
673dab293a9862ce9f6a78122d006d21
I:Running script:
I:
ui_print("ROM Manager Version 5.0.0.8");
ui_print("July 9, 2012");
assert(backup_rom("/emmc/clockworkmod/backup/2012-07-09-21.25.49"));
parse returned 0; 0 errors encountered
July 9, 2012
SD Card space free: 7454MB
Backing up system...
deleted
deleted
omx_tests
tar: read error: I/O error
deleted
result was NULL, message is: assert failed: backup_rom("/emmc/clockworkmod/backup/2012-07-09-21.25.49")
#5 pitbull26
pitbull26
Posted 21 July 2012 - 12:33 PM
Is there a way to uninstall this?
#6 jav1
jav1
Posted 27 October 2012 - 08:27 PM
does the version of the rom changes to 5845 or it stays with what you initally d/l on rom manager
