Circles widget for DNA
9 replies to this topic
#1 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 13 November 2013 - 10:54 AM
Get the circles widget for your DNA! Here is how you do it:
1. Download the flashable zip from here:
2. Reboot into recovery.
3. Wipe Dalvik and Cache.
4. Flash the Zip.
5. Wipe Dalvik and Cache again.
6. Reboot.
7. Upon unlocking your screen, you will be asked to choose between your old launcher and homescreen. Select homescreen. Widget should appear out of thin air! :)
Just a little note here, this will not work on kitkat.
  672.99KB   32 downloads
  • Memnoch73, Sabres032 and BionicMan69 like this
Nice job on the signature, jl90...thanks!
#2 livinginkaos
Posted 13 November 2013 - 12:18 PM
And so it begins ..... !!!!
  • Memnoch73 and Sabres032 like this
#3 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 13 November 2013 - 01:43 PM
I have just begun... :D
Sent from my HTC6435LVW using Xparent BlueTapatalk 2
  • BionicMan69 likes this
#4 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
  • Twitter:@BionicMan_69
  • LocationCookeville, TN
  • Current Device(s):Motorola Droid Razr Maxx HD, Motorola Droid Bionic, Motorola Xoom, HTC Flyer
Posted 14 November 2013 - 05:55 AM
So I'm curious lol... I like how this design looks with the font. I've got the regular droid ultra circle widgets now. I know this is for the DNA but they possibly be made to work on the Maxx HD? Almost time to get a different phone. Slowly running out of things to do and try on this one but so many good phones to pick from heehee... :p
#5 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 14 November 2013 - 06:01 AM
So you just want the font? That's just the font he has installed on his phone. Look at the clock in the status bar. Same font. If he gives you the name you could just change your font since you already have the circles from the Ultra
#6 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 14 November 2013 - 06:25 AM
the name of the font is dream orphans, i dont think that the font is in the list in rom toolbox, so here it is
just in case you dont know how, download the font, then open rom toolbox up. swipe over to font installer, then tap on local. go to where your font is, probably downloads, tap on it, then click install. like Memnoch73 said, though, that will turn all of your phone over to this font, not just the circles widget.
#7 Sabres032
Sabres032
    Large and in charge EMS minion
  • 9,515 posts
  • LocationWayward USA
  • Current Device(s):Google Pixel 2 XL
Posted 14 November 2013 - 07:19 AM
Once I shake this headache and am able to think properly I'm going to give this a shot.
Sent from my Marine World N6 or my Nexus 7 2013 WiFi I'll let you figure out which.
#8 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
Posted 14 November 2013 - 08:20 AM
Thanks for both the replies back. Going to check and try that out... :D
#9 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
Posted 20 November 2013 - 06:19 AM
Just wanted pop back in to let anyone know that this also works on the Maxx HD on 4.1.2 don't know on 4.3 if does or not. Thought I'd try it out. Sent from my DROID RAZR HD using Xparent Skyblue Tapatalk 2
  • mrlolli likes this
#10 livinginkaos
Posted 20 November 2013 - 07:02 AM
I would hope that it worked on the HD..... it comes stock with the circles. :)
