446 replies to this topic
#161 jimgfitzgerald
jimgfitzgerald
  • 277 posts
Posted 05 July 2012 - 06:31 PM
Probably a dumb question, but what is 6.14.85?
#162 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 05 July 2012 - 06:37 PM
Older ICS leak that most of us got stuck on where you could not fastboot back to GB
#163 jimgfitzgerald
jimgfitzgerald
  • 277 posts
Posted 05 July 2012 - 07:25 PM
Thanks. So that utility is what's called the "unstuck" utility?
#164 bamakore
bamakore
  • 11 posts
  • Twitter:bamakore
  • Google+:bamakore
  • LocationHartselle,Alabama
Posted 05 July 2012 - 07:26 PM
Thanks Matt for all you do.....
#165 portscan
portscan
  • 277 posts
  • Twitter:@JasonCollins23
  • LocationClarksville, TN
  • Current Device(s):Samsung Galaxy S4- Stock Rooted on 4.3/Samsung Galaxy Note 10.1- Redemption Rom v6.1
He built separate utilities pre 1.7 for getting unstuck, but he included unstuck in 1.7.
#166 portscan
portscan
  • 277 posts
Posted 05 July 2012 - 07:46 PM
Thanks Matt! Easy as the rest of your leaks! I first flashed with little utility for the kernel. I then temp unrooted with Voodoo, then flashed .214 in recovery. After boot used backup with Voodoo to root. All worked like a charm.
#167 nromero
nromero
  • 17 posts
Posted 05 July 2012 - 07:48 PM
OK......need some help here.
I installed the .214 via the cmd prompt but I can't go into recovery after AP Fastboot. When I try it just to an open heart android with a red triangle...... Any help please.
#168 rackumrack
rackumrack
  • 54 posts
  • LocationUpstate, SC
  • Current Device(s):Nexus 7, Maxx HD
Posted 05 July 2012 - 07:50 PM
Try pushing both volume buttons at the same time....
Sent from my ICS rooted Razr Maxx
  • mattlgroff likes this
RAZR MAXX HD
#169 sgtguthrie
sgtguthrie
  • 135 posts
  • Twitter:@sgtguthrie1
  • LocationMichigan
Posted 05 July 2012 - 07:57 PM
+1... This is normal to prevent just anyone from using recovery. They hide it ;-)
Tricky tricky...
Sent from my DROID Razr Maxx via Tapatalk 2
#170 bipmip
bipmip
  • 58 posts
  • LocationSouth Dakota
Posted 05 July 2012 - 08:01 PM
What are the steps and requirements to go back to .211?
#171 nromero
nromero
  • 17 posts
Posted 05 July 2012 - 08:03 PM
Tricky tricky...
My fat fingers wasn't pushing one of the volume buttons......Thanks guys.
And great job Matt.....keep up the awesome work!
#172 topdog031382
topdog031382
  • 131 posts
Posted 05 July 2012 - 08:04 PM
you can either use the downgrade to .211 zip located in the downgrade thread here
in which you have to be stock .214 OR use the 1.7 utility option 2 to restore back to stock .211 just make sure you have the zip files on your sd card.
#173 bipmip
bipmip
  • 58 posts
Posted 05 July 2012 - 08:16 PM
Ok. Thank you, where would I get the zip files?
#174 zrpmgo
zrpmgo
  • 42 posts
Posted 05 July 2012 - 08:29 PM
So, I used Matt's utility to flash the new .214 kernel without a hitch on my rooted razr.... I'm running a custom ROM with safestrap installed and in safe mode...... My question is...After the update to .214 kernel,...could I still toggle back to unsafe side of safestrap and be ok with the untouched stock .211 ics on my first system?...And any nandroid I made on ics before the kernel change in safe mode?...............................I'm thinking I should be ok...just thought I'd be safe and ask...thanks
#175 c_live_lee
c_live_lee
  • 159 posts
  • Twitter:c_live_lee
  • Google+:116609432208837778358
  • LocationGeorgia
Posted 05 July 2012 - 09:20 PM
Thanks yet again, Matt! You've really made this HTC-->Moto transition much easier for me. To anyone who hasn't tried this yet, I used the utility (second download in OP) while running Eclipse and it went off without a hitch. It quite literally took only seconds to get the updated kernel!
#176 TweakedSystems
TweakedSystems
  • 122 posts
Posted 05 July 2012 - 09:21 PM
Thank you for this Update :)
This was a very easy update to do...and I'm rooted!
I don't know why I am not getting a full snapshot..
#177 jesse542
jesse542
Posted 05 July 2012 - 09:29 PM
Just updated. Works great. Only problem is that when I try to re install Safestrap through the Safestrap 2.00 ICS apk it always closes.
#178 Easymfe
Easymfe
  • 24 posts
Posted 05 July 2012 - 09:48 PM
It's that time again folks... leaked updates! (Yay~!)
This time I got a special treat. I did not want to leave my comfortable place with safestrap installed and booted on Arctic Rom on 211 to fastboot the 6.12.181 files, re-upgrade to 211 stock, upgrade to 214 just to see a small difference in the kernel.
I thought you could not fastboot to 6.12.181 from .211??
#179 utekking
utekking
  • 65 posts
Posted 05 July 2012 - 10:29 PM
You can't, it fakes the system to think that its on .181 and allows the flashing of .211
Droid Razr upgraded to Maxx!!!
#180 Easymfe
Easymfe
  • 24 posts
Posted 05 July 2012 - 10:59 PM
Thank you. So the .181 fastboot in Matt's 1.6 utility will trick it into thinking it's 181, or will that flat out brick it? Or is it in the 1.7 utility? I apoligize if these are stupid questions. I seem to overlook the obvious sometimes. Just want to know what my "start from scratch" option is now.
  • ecam444 likes this
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
