#121
Posted 05 July 2012 - 11:18 AM
#122
Posted 05 July 2012 - 11:22 AM
It's that time again folks... leaked updates! (Yay~!)
(This is a screenshot from ArcticRom214)
Alright so i flashed the kernel. But when i try to root, i go to flash the 85 boot img it shows me this.
[*] Simple Razr Restore
[*] Windows Version
[*] Created by mattlgroff
[*] Before continuing, ensure your Razr is in the
[*] "AP Fastboot" mode and connected via USB.
[*] mattlgroff@gmail.com
'moto-fastboot' is not recognized as an internal or external command,
operable program or batch file.
You may now reboot.
Please make a selection or hit ENTER to return:
What should i do?
EDIT: Never mind i extracted the zip into the folder with the files on the 1.7 utility.
Edited by spc_hicks09, 05 July 2012 - 12:43 PM.
#123
Posted 05 July 2012 - 11:32 AM
So ok been running. 214 leak since last night all is smoother and faster but battery life is horrendous so far this is discharging from100%... so sad and i have a MAXX:( <br /><br />DROID RAZR MAXX..is it just me???
I have the regular razr and battery was almost totally drained after 7 hrs of very light use. As stated previously I did a reboot and put it on the charger. Time will tell.
#124
Posted 05 July 2012 - 11:33 AM
Just use the 1.7 utility, wait did you flash the entire zip file or just the .214 img?Alright so i flashed the kernel. But when i try to root, i go to flash the 85 boot img it shows me this.
[*] Windows Version
You may now reboot.
What should i do?
#125
Posted 05 July 2012 - 11:56 AM
DROID RAZR MAXX..
#126
Posted 05 July 2012 - 12:20 PM
Well sadly i reverted back to. 211 for now..just used the other leak...215 and all is back to stock .211...well it was exciting for a half day im sure more is to come! ...Still thanks anyways Matt you still rock!!
DROID RAZR MAXX..
The screenshot you posted shows that most of your discharge is due to 'screen time'. If it was the OS it would show in the next bar down, titled "Android OS". Were you spending a lot of time watching a video maybe...?
I'm curious because my .214 seems to be doing very nicely on the battery.
#127
#128
Posted 05 July 2012 - 12:32 PM
LOL.. I lose 1% every 3 minutes on my Maxx. No, I don't leave the screen on all that time. It's a calculated average. I was on Arctic 214; pretty sure it's not the ROM. However, since I could go 42+ hours on DualCore and Liquid previously, I'm going to experiment with those for a few days before going back to 211. I did notice my phone runs a lot warmer with 214.
Update: Now I'm confused... Was running Arctic 214, battery showed 84%... I then restored the DualCore nandroid, now it shows 97%.
#129
Posted 05 July 2012 - 12:51 PM
Like 8 hours discharging!!...IDK maybe i should of did a full data reset and wipe then checked it out but i was too hasty...as usual!!...might do it all over again tomorrow its my day off and it will give me something to do!!
DROID RAZR MAXX..
#130
Posted 05 July 2012 - 12:55 PM
@Kmss1..no video just normal browsing and text's and a short phone call and on. 211 i would have like 3 1/2 hours of screen time and still have like 70% after
DROID RAZR MAXX..
My guess is that we ALL need to be doing MORE full data wipes more often... Seriously!
#131
Posted 05 July 2012 - 12:57 PM
- Installed an update that seems to have made my phone much faster. (The update caused me to reboot the phone, which usually makes it faster for a while)
- Battery is not as good after update. (I've been messing with my phone all day trying to see what the update did for me, and i've had the screen on way more than I usually would)
- dawg72 likes this
#132
Posted 05 July 2012 - 12:58 PM
I installed .214 this morning on my stock Maxx, and my battery was at 80%. I played with the phone for a couple of hours now, and my battery only went down to 70%. I know it's only a small example, but my battery life appears to be much better than .211.
#133
Posted 05 July 2012 - 12:59 PM
Mine appears to be the exact opposite. My phone is "cool" running .214, whereas it was borderline hot running .211.
#134
Posted 05 July 2012 - 01:09 PM
#135
Posted 05 July 2012 - 01:10 PM
lol my battery lasted a whole 7 hrs in my pocket. Did a reboot and charging now. Will see how it goes.
I flashed the kernal last night and let it charge all night, then unplugged it to go to work. After 2 hours, maybe 10 texts and an address lookup on Google I was already down 20%. I'm gonna wipe everything and start anew and see if that changes
Seems we all have an apparent issue, or something is just being misread within the system. I have setcpu set to 300/300 hotplug when screen is off. No matter what happens on my phone when the screen is off, it never pops up above 300mhz. The screen is off a majority of the time, but my battery too was dropping 1% every couple minutes. Matt didn't want to hear it So, if someone restores a previous backup, and has the battery reading differently, then maybe it's something to do with the build in 1% mod maybe? Just thinking out loud. What would make a battery read different on the same phone with a different system running?
Did this happen prior to 214 while it was on 211?
Did this happen prior to the built in 1%?
Are we on 3G or 4G?
Where do babies come from?
X
#136
Posted 05 July 2012 - 01:20 PM
Thanks Matt for all you do.
#137
Posted 05 July 2012 - 01:45 PM
My theory is that it was doing this on.211 kernel too though. Its why i think our phones were overheating and draining the battery.
#138
Posted 05 July 2012 - 01:46 PM
- digdug1 likes this
#139
Posted 05 July 2012 - 01:47 PM
#140
Posted 05 July 2012 - 01:49 PM
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
