Which build date are you looking at. Look at the kernel build date and not rom build date.
Thanks. I was looking in the right place :-/ Dunno what was wrong. Went the long way around and flashed through Moto recovery and I'm all good now.
Posted 05 July 2012 - 07:42 AM
Posted 05 July 2012 - 07:57 AM
Posted 05 July 2012 - 08:28 AM
I just did that... Stock 211 with SafeStrap 2.0Is there any reason mechanically why we can't just flash the boot .img if we're running stock .211? I understand system version won't change, that's fine.
Posted 05 July 2012 - 08:36 AM
Posted 05 July 2012 - 08:46 AM
Posted 05 July 2012 - 08:53 AM
Posted 05 July 2012 - 09:01 AM
Make sure you are looking at the kernel area not the other build for the date..I'm following the steps 100% and still end up with a build date of the 14th. Getting no errors and it looks like it's writing the boot.img fine. Super-confused here. Running .211 with Safestrap and Simplex.
Edit: Apparently I'm lower than a lobotomy patient ^ :-) but it's still a no-go for me after 6 attempts. Re-downloaded, rebooted, reinstalled drivers.
Posted 05 July 2012 - 09:06 AM
Posted 05 July 2012 - 09:13 AM
Like Matt said...Make sure you are looking at the kernel area not the other build for the date..
Posted 05 July 2012 - 09:20 AM
Problem installing. I am running stock 211 + root...
-I just temp unrooted via voodoo.
-Placed Blur_Version.6.16.211.XT912.Verizon.en.US on on sd card (downlaoded from 1st post)
-Booted into stock recovery and applied update
Resulting in ...
E:Error in tmp/sideload/package.zip
(Status 7)
Installation aborted.
Posted 05 July 2012 - 09:26 AM
Why did you unroot and try applying the zip file? I though this zip file was the same one that Matt released last week and for those of us on stock 211 + root would just need to flash the 214 boot img?
Posted 05 July 2012 - 09:30 AM
Posted 05 July 2012 - 09:36 AM
Posted 05 July 2012 - 09:37 AM
what stumps me is why folks only flash the boot.img. doing so it not updating anything else that may have been changed in the 214 file. So in essences you have a mix and match software running on the device.
Posted 05 July 2012 - 09:38 AM
Like Matt said...
58.63KB 65 downloads
System Build 6/14/2012
Kernel Build 6/29/2012
Posted 05 July 2012 - 09:43 AM
Followed the instructions, put the .zip on my SD card, booted into recovery, wiped cache, and then selected "Install from SD card", selected the file, and got this:
assert failed: mount("ext3 , "MTD" , "system" , "/system")
E:Error in /sdcard/Blur-Version.6.16.211.XT912.Verizon.en.US.zip
(Status 7)
Installation Aborted
Appreciate any help ...
Posted 05 July 2012 - 09:46 AM
So, im just wondering what governor you guys are using with this kernel.
Cpu info tells me that one processor stays off with interactive. Ive been using hot plug and there is a substantial performance increase but I'm wondering if its harder on my phone.
Posted 05 July 2012 - 09:50 AM
Good question - I have no idea why I should be doing one method over the other (other than the fact that flashing the 214 img is much easier, one click and I'm done). From what I can see, most people are just using this new utility and then choosing option 3 to flash the 214 img.
I suppose if you're only running stock, it would make sense to flash the entire upgrade. If you're running a custom Rom, you're relying on the software that comes with it and only want the radio and/or kernel update.
You realize this is what the 2nd file in the OP does...right?Is there any reason mechanically why we can't just flash the boot .img if we're running stock .211? I understand system version won't change, that's fine.
