446 replies to this topic
#381 networkdood
networkdood
  • 52 posts
  • Twitter:networkdood
  • LocationOver there
Posted 09 July 2012 - 07:08 PM
ok, so, I was on .211 and trying to go to .214 - I kept getting an E:Error in /tmps/sideload/package.zip and some error involving the boot.img image upon verifying the update package. I switched my boot image back to the original logo and now I am getting:
assert failed: mount("ext3", "MTD", "system", "/system") along with the E:Error in /tmps/sideload/package.zip (Status 7) Installation aborted.
Now, since I had been getting similar errors I decided to re-image .211. So, I have the .211 file on my external SD card and I used Matt DroidUtility to 'prepare' my phone to flash the .211 file.
I still have the same errors...anyone have any suggestions?
Thank you.
  • orateam likes this
I love it when a plan comes together...
#382 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 09 July 2012 - 08:25 PM
Hows everyone battery life on new rom?
#383 spid1
spid1
  • 5 posts
Posted 09 July 2012 - 08:51 PM
I'm going 1 and 3/4 days and that includes a full day of texting, email, and surfing the internet. Wifi is fast. GPS grabs quickly. Took 2 days to burn in the.214. The key for me was to do a full wipe from moto recovery.
#384 apquijano
apquijano
  • 8 posts
  • LocationBuffalo, NY
Posted 09 July 2012 - 09:00 PM
Huge fan of Matt's work. I successfully installed this via .zip/Recovery method earlier this afternoon and this is how it's been. About to sleep so here's my findings.
- Brightness set to auto
- About half an hour used on calls
- Around forty-five text messages sent
- Sync on all day
- Cellular data set to LTE/CDMA/Evdo
- Wi-Fi on for about six hours
- Watched two episodes of Doctor Who via Netflix
- Watched a couple videos on YouTube
- Moderate use of Facebook and Instagram (checked each for about two minutes at a time, about ten times)
- Moderate amount of Web surfing
- Constantly looking through forums
This is about normal for me, if just a little better. I'm interested to see if a data wipe from recovery would help me.
#385 Mr. Orange 645
Mr. Orange 645
  • 128 posts
  • LocationSW, Missouri
Posted 09 July 2012 - 09:15 PM
Thank you.
After using option 2, when you reboot to the stock recovery, do a factory reset and wipe cache.
#386 networkdood
networkdood
  • 52 posts
Posted 09 July 2012 - 09:26 PM
Hey, saw you on the chat and yeah I did try that :-(
#387 networkdood
networkdood
  • 52 posts
Posted 09 July 2012 - 09:27 PM
Anyway I can transfer a file using fastboot, from my PC to the external memory of my phone? It could be that that the file is bad since the assert always fails.
NM, lol, I can just pull the card out and transfer the file directly...lol
Edited by networkdood, 09 July 2012 - 09:39 PM.
#388 networkdood
networkdood
  • 52 posts
Posted 09 July 2012 - 09:52 PM
Anyone have a link to a "GOOD" .211 update file - one that you have personally used - I have 2 and one of them has a sig ver failed while another one gives me the original error I had in the first place. Thanks
#389 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
  • Twitter:xlightwaverx
  • LocationEast Coast
  • Current Device(s):XT912, Kindle Fire HD
Posted 10 July 2012 - 12:24 AM
  • networkdood likes this
#390 diesel84
diesel84
  • 5 posts
  • LocationNew Hampshire
Posted 10 July 2012 - 04:14 AM
My battery usage has been greatly improved after updating to .214. I did do a factory reset, System Settings > Privacy > Factory Reset and now my screen is showing 95% battery usage. And yes I have launched applications since powering on my phone.
#391 networkdood
networkdood
  • 52 posts
Posted 10 July 2012 - 04:17 AM
Thanks, it seems like every .211 update file I find is bigger than the next.....in terms of KBs.
#392 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 10 July 2012 - 04:23 AM
Battery life for me seems pretty good, better than 211 and this was just taking the boot image file. I'm going to go back to factory 211 and apply the update via the stock recovery just to be sure, but I'm liking 214.
I did run into one problem that I haven't seen. My 4g network was refusing to work today. The 4g signal indicator was up in my status bar but was grey and would never turn blue. I had to turn the phone off and on to get it to work again. I've never had this problem before with my RAZR before 214. Not sure if that's the reason or ICS Eclipse 1.2RC1. In any case, I do see an improvement in both responsiveness in my phone as well as better battery life.
#393 cw0725
cw0725
Posted 10 July 2012 - 04:33 AM
i must be losing my mind.. i'm on a leaked version of 211 and keep trying both links. did the utility and still not on the 214. any input would be greatly appreciated.
#394 phaim
phaim
  • 19 posts
  • Twitter:phaim11
Posted 10 July 2012 - 05:02 AM
I actually experienced a similar problem in NYC/Northern NJ. My 4G connection with .214 has been very unreliable the last few days and all the radio trouble I've been having with an inconsistent signal actual seemed to hurt my battery life compared to .211 (Cell Standby has drained a relatively large portion of my battery, around 10% on .214). Maybe if I was in Chicago it would be better (where I found the 4G coverage is excellent) but in the NYC area I'm sticking with .211 which seems to get a better more stable lock on 4G.
#395 jonwgee
jonwgee
  • 301 posts
  • Twitter:JonWGee
  • Google+:jonwgee
  • LocationDekalb IL
Posted 10 July 2012 - 05:07 AM
If you used option 2 , the pc utility, your system version will still say .211. Your kernel version should show June 29 . It's it does, you're all good.
Maxx
maxx
#396 orateam
orateam
  • 120 posts
Posted 10 July 2012 - 05:11 AM
Thank you.
I got this same issue. I couldn't get past it. Spent 10 hours with the phone and finally gave up. Called Verizon and told them that thier ics upgrade did it. my new Razr comes tomorrow. I will not be doing this upgrade again. I will just root it, install safestrap and use custom roms. Something about this kernal upgrade seems to have locked my phone from getting any standard recovery. It senses that the kernal is not right. I assume only a fastboot of .214 or higher will work.
#397 cw0725
cw0725
Posted 10 July 2012 - 06:01 AM
Edit <> got it to work all is good.
<P>Jon actually my kernel version says thurs jun 14. if i run the first option and try flash it i get a bunch of errors but then if i try the utility it looks like it runs but doesn't change? and im pretty sure i did it correctly.<BR><BR>
<BR>If you used option 2 , the pc utility, your system version will still say .211. Your kernel version should show June 29 . It's it does, you're all good.<BR><BR>Maxx<BR>
</P>
#398 fdisker
fdisker
  • 5 posts
Posted 10 July 2012 - 06:20 AM
Real men call that fraud.
#399 Arak-Nafein
Arak-Nafein
  • 10 posts
Posted 10 July 2012 - 08:09 AM
Shame on you. That's fraud, and it's also why we can't have nice things. When I break my stuff, and it's my own fault. I man up and pay for them myself.
I understand that a new phone is a lot of money.....but you shouldn't be playing with expensive toys if you can't afford to buy a new one. I'm only saying all of this because Droidrzr.com doesn't not condone fraud.
#400 orateam
orateam
  • 120 posts
Posted 10 July 2012 - 08:42 AM
THIS is fraud? So using WiFi tether without paying as most hackers do, is not.? Sideloading paid apps which many do, is not? I can go on and on. I have given the telcos tens of thousands of dollars and many times have barely touched their network. Using my phone for a handful of minutes with wifi data. And they've never given me no discount.
As a side mention. I told the Verizon guy later on after we talked for an hour exactly what I did for proactive reasons and he didn't care. He said all raze moto are under a 1 year warranty and Verizon want to keep me as a customer. He went on to say that once a customer is eligible for an upgrade, they have more leniency. So full disclosure, nothing dishonest on my part. If they are with moto, its on them.
