How did you get sio? My only scheduler options are noop, deadline, and cfq. I flashed the the two zips from XDA to get the interactiveX governor, but my scheduler still doesn't show sio. Not that I know what the difference is in the schedulers, anyway, LOL.
#341
Posted 08 July 2012 - 11:27 AM
#343
Posted 08 July 2012 - 12:23 PM
2 questions 1. You have to use custom rom on safe side of safestrap or you can do it on stock rom too? 2. You need to use SetCPU to do it or Rom Toolbox Lite or No-frills CPU Control will do job fine?I used CPU Spy to view which states mine was in, and it was changing correctly. I also used SetCPU to set my phone to Hotplug and Noop as many users have indicated works well.
#344
Posted 08 July 2012 - 12:34 PM
You have to go into the /system/etc/init.d/ directory with a root enabled explorer and add a line to activate the sio scheduler (located in /system/lib/modules) manually. They included the module, but didn`t put the line into their boot init`d script for it.
That worked. I added the line, rebooted to recovery and reflashed the init.d installer, and now I have all governor/scheduler options.
Thank you for the assistance.
#345
Posted 08 July 2012 - 12:41 PM
#346
Posted 08 July 2012 - 07:29 PM
i installed the full update since i run stock rooted.
thanks again man!
#347
Posted 08 July 2012 - 07:42 PM
#348
Posted 08 July 2012 - 08:09 PM
Didn't bootloop or have to fastboot or anything
Thanks Matt; good to be on the latest and greatest (even if I may or may not notice a difference)
#349 Guest_BDH_*
Posted 08 July 2012 - 09:23 PM
Your kernel version should have a date of Jun 29th - that means it took
Just letting you know since you wanted updated. After running the interactiveX governor, using noop for the I/O Scheduler, and NOT USING MY PHONE FOR ANYTHING. I managed to squeeze 8 hours of life out of my phone.
#350
Posted 08 July 2012 - 09:42 PM
My battery life is bad, but not quite that bad. Wtf is happening here? Some people claim as good or better (or decent) battery life with ics. I saw a tear down on iFixit that showed some components have changed in the razr since the first tear down they did. Different mfgs for a few parts. I wonder if that could have an effect? No way to know for sure though.
Badass battery monitor shows a huge amount of power drained by the kernel, but I don't have anything to compare it to since we can't revert back to GB.
#351 Guest_BDH_*
Posted 08 July 2012 - 09:46 PM
Yeah and it's really weird that there is no middle section. It's either great battery life, or horrible battery life lol. Really really sucks.
#352
Posted 08 July 2012 - 09:54 PM
X
#353
Posted 08 July 2012 - 10:21 PM
That is weird. My wife has the OG RAZR on stock. 211 and she can get a full day out of hers with a few phone calls and text messages and taking pictures of our daughter. She doesn't surf the internet at all. She will occasionally stream music during the day.
She told me her battery isn't as good as it was on the 79 leak, but she's still getting much better battery life than you are.
What was your battery life like on 209? That was the best for me.
#354
Posted 09 July 2012 - 12:31 AM
Really? I'm completely stock with lots of things syncing and without using WiFi I can leave my phone sitting for 12 hours easy. If I'm on WiFi I get closer to 16, 17. I'd imagine with setCPU for screen off, noop, interactiveX, juiceDefender, you could easily get 15-24 hrs...Just letting you know since you wanted updated. After running the interactiveX governor, using noop for the I/O Scheduler, and NOT USING MY PHONE FOR ANYTHING. I managed to squeeze 8 hours of life out of my phone.
#355 Guest_BDH_*
Posted 09 July 2012 - 12:43 AM
Yeah I really don't get it man. A few other people are having the same issue, although not as bad as mine. Her is my latest. I managed to get 9 1/2 hours. As you can see, the absolute ONLY thing I used on my phone, was facebook and even then I only used it twice for about 2 minutes each time.
#356
Posted 09 July 2012 - 02:25 AM
I'm getting just as bad as you are with my OG razr...I'm probably going to go back to .211 today. It seemed like the very first day on .211, my battery did wayyyy better than any other day since. As soon as I went to .214, my battery life is terrible, more or less on par with yours. I do some moderate usage, like fb'ing, calls, texts, but nothing spectacular like streaming videos....and I'm lucky to pull 6 hours without needing a re-charge...if I wasn't going to Korea in a couple months, I probably would have splurged on the maxx
#357
Posted 09 July 2012 - 03:56 AM
Attempted update via moto recovery and utility, no go, still .211 Thur jun 14...any ideas?
Safestrap, running Eclipse 1.1
Don't look at the Build date information in your About Phone. Look at the Kernel version. It should say the following:
Kernel version
3.0.8-g39388c6
hudsoncm@il93lnxdroid84 #1
SMP PREEMPT Fri Jun 29 22:33:44 CDT 2012
I've attached a screenshot from my phone showing how the build date and System version show the information from .211 but the kernel version shows the information for .214.
#358
Posted 09 July 2012 - 03:58 AM
Eric
#359
Posted 09 July 2012 - 08:01 AM
#360 Guest_BDH_*
Posted 09 July 2012 - 08:41 AM
I wonder if there is something keeping your processor from ramping down. Have you used cpu spy or anything to see what you processor is running at most of the time? Also have you tried hotplugX scheduler? I think it will turn off one cpu even with the screen on if the usage is low enough.
Eric
I ran CPU Spy and even it is saying that 90% of the time my phone was on, it ran at 300mHz lol. Clocked all the way down, still draining battery life somehow. I'll try out the hotplugX governor but considering what I've already tried, I'll be surprised if I see good results lol. This is driving me insane.
