I`ve been ping ponging back and forth between interactivex with noop vs hotplugX with sio for a couple days now. Trying to find the sweet spot in battery and performance.
How did you get sio? My only scheduler options are noop, deadline, and cfq. I flashed the the two zips from XDA to get the interactiveX governor, but my scheduler still doesn't show sio. Not that I know what the difference is in the schedulers, anyway, LOL.
Can you install free setcpu and look at your CPU's frequency? I had your results also and found out this kernel was sticking at 1200! Thus draining my battery.
I fastbooted back to .211 and did the full upgrade to .214, then rerooted and installed Simplex 1.0.1 over it. I'm using setCPU and have the governor set to InteractiveX with the noop scheduler. I didn't alter anything else, and my phone shows over the last six hours, it has spent 94.5% at 300mhz, around 4% at 1200, and the rest in between, so I'm not having the issue of getting "stuck" at 1200.
I'm curious if the people that are getting stuck did the full install from a stock .211, or if they used the utility to just flash the kernel, which could possibly be leaving out some small, seeming insignificant file. Not even a theory, more of a curiosity.
